WGM2792 Arcade Monitor Resistor Burn Off On Neck Board *Need Help*
  • proaudiosoft
    • Apr 2012
    • 68
    Re: WGM2792 Arcade Monitor Resistor Burn Off On Neck Board *Need Help*
    Update, The resistor I soldered back in desoldered it self and came out again. grrr. Something is definitely making that resistors joints heat up to the point its falling out. Any and all help appreciated.
      • 30950
      what resistor is it on the pcb, so i can look at the schematics.
      • proaudiosoft
        • Apr 2012
        • 68
        It is resistor r242 (on Neck board Black spot in photo)
          Picture of the bottom side of the board? You should also remove the black stuff and the glue off the board so we can see the Green paint lines on the top side of the board.
            • 30950
            r242, then looking at the schematic,
            check d208, q211, q212 for shorts.
            also, check the resistance of r215, and r267 in the heater circuit.
            • proaudiosoft
              • Apr 2012
              • 68
              Originally posted by budm
              Picture of the bottom side of the board? You should also remove the black stuff and the glue off the board so we can see the Green paint lines on that resistor.
              ok, budm, will do when i get back from dinner
              • proaudiosoft
                • Apr 2012
                • 68
                Will check and let you know, thanks!
                • R_J
                  • Jun 2012
                  • 9529
                  That resistor is for the blue crt drive, even with it out you should get a picture, just missing blue. so I suspect once this fault is found there will be another
                  • proaudiosoft
                    • Apr 2012
                    • 68
                    r242 is measuring 1.333k, d208 test good, q211 looks good to me, its npn right? E C B is what sheet i found said.
                    r215 reads 2.5 ohms (i think its marked 2), and r267 reads 1.1 ohm.
                    Interestingly, i accidently wrote q201 down instead of q211 at first, i tested it pulled and got readings everywhere, looks bad. 201 and 211 are c35502e resistors. I am going to take pics of the board with glue off as Budm requested too... Hope this gives you more insight
                    • proaudiosoft
                      • Apr 2012
                      • 68
                      Here Are pics of the front and back of the board, I removed the glue and black junk around r242... I have a few transistors unsoldered and a resistors with a leg pulled out...
                        • 30950
                        so q212?
                          • 30950
                          q206 has broken solder joints, the narrow chip needs completely resoldering,
                          the resistor that fell out needs re-soldering.
                          by resoldering i mean remove the old solder first.
                          • proaudiosoft
                            • Apr 2012
                            • 68
                            so q212?
                            Oh left that out, q212 looked ok as far as I can tell too. About .658 B2E / B2C and open E2B and C2B
                            • proaudiosoft
                              • Apr 2012
                              • 68
                              Yes, You are correct about q206, I am aware of the joints at that Transistor/sink. I believe it from recent handling and checking parts for solid mounting. And I know the Resistor needs re-soldering as well, I will make sure to remove the old first. I am afraid the trace on one end of r242 is trying to pull away from the board as well.
                              I would rather try to figure out the issue before making all the final connections. Wouldn't this be a good idea?
                              Would having a shorted q201 cause r242 to heat up? thx
                              • proaudiosoft
                                • Apr 2012
                                • 68
                                I went ahead and pulled the Big board out too. If I cant get it, I am going to send the boards out to be repaired. Here are front/back pics if it helps anything
                                  • 30950
                                  can you meter the pins on the back of the tube,
                                  all combinations.
                                  most will show nothing.
                                  what we are looking for is if the gun related to that resistor is shorted to something else - such as the heater!
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    #37
                                    on the back picture of the mainboard theres one joint that looks bad too me ive marked it with a red arrow.
                                    • proaudiosoft
                                      • Apr 2012
                                      • 68
                                      all combinations.
                                      I checked. Any pins that show a reading together are in the Mega ohms, accept Pins 1 & 3 together, I get 1.1ohm. is this significant?
                                        • 30950
                                        1-3 is the heater, so that's all good.
                                        check q215, q220, d209 and sg204 < specially this.
                                        • proaudiosoft
                                          • Apr 2012
                                          • 68
                                          I meant to say pins 1&6 are about 1.1 ohm, is this still ok?
                                          I tested all the components you asked, all tested good.
                                            by momaka
                                            03-15-2023, 10:17 PM
                                          • ttmi100x
                                            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                            by ttmi100x
                                            Greetings everyone,
                                            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                            Upon closer inspection...
                                            07-31-2024, 06:36 PM
                                          • Safrilhg
                                            Look for the resistor value in the BenQ G922HDAL monitor's power supply
                                            by Safrilhg
                                            Hello guys, I had a problem where I didn't know the value of the burnt SMD resistor in the power supply circuit of the BenQ G922HDAL monitor.
                                            In one of the parts, there is a burnt SMD resistor which leads to the LD7560GS IC as shown in the picture below.
                                            How to determine the appropriate SMD resistor value for this condition? Thank You...
                                            11-06-2023, 12:43 PM
                                          • redbaron1007
                                            Arcade PSU blown resistor ID
                                            by redbaron1007
                                            I'm working on one of the PSU's in my backlog today that came out of an NBA Jam arcade machine a year or so ago. The PSU is a Pan Yes brand with a model number PY-TV-C. From what I remember the 12v rail wasn't outputting anything. I opened it up and was reminded that the resistor at R28 had blown it's shell off and I have no idea how to ID a replacement for it. (see pictures) The color bands that are still intact a little are brown, black, missing band/bands, and what I'm assuming is silver. When I check it with my DMM it's reading 100ohms exactly but I don't know if that's what it's supposed...
                                            01-06-2023, 04:13 PM
                                          • ant3202
                                            HP 27es - LED monitor - Monitor Flashing On - Off
                                            by ant3202
                                            Hi Everyone
                                            Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                            https://www.badcaps.net/forum/troubl...lashing-on-off
                                            The monitor is HP 27es LED Monitor
                                            https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                            The monitor will randomly blackout and display no signal and will recover again.
                                            Sometimes need to power and off again to restore the display but...
                                            03-20-2025, 07:30 PM
