HP 27es - LED monitor - Monitor Flashing On - Off
+ More Options
Posts
  • ant3202
    • Jun 2006
    • 275
    • Singapore
    Hi Everyone
    Lately I am experiencing the deja-vu incident on one of the led monitor like this.
    https://www.badcaps.net/forum/troubl...lashing-on-off
    The monitor is HP 27es LED Monitor
    https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
    The monitor will randomly blackout and display no signal and will recover again.
    Sometimes need to power and off again to restore the display but it will eventually blackout and display again.
    On google, there are certain users facing this same issues, thus decided to open up and check.
    DC adapter was giving correct voltages and ESR level for the caps were acceptable
    Had narrowed to the possible suspects,
    was thinking if this BA5N10 (TO-252) is the culprit.
    FR9889 - SOP-8 power management IC Chip
    Thanks ))))
  • ant3202
    • Jun 2006
    • 275
    • Singapore
    AL3065
    https://www.mouser.com/ds/2/115/AL30...UbT1Otf39BLUL3
    4616 IC
    • ant3202
      • Jun 2006
      • 275
      • Singapore
      Need help if anyone can refer BA5N10 (TO-252) replacement, similar or better.
      • ant3202
        • Jun 2006
        • 275
        • Singapore
        Original IC:
        https://datasheet4u.com/pdf-down/E/M...llianceMOS.pdf
        Can this replacement works?
        https://docs.rs-online.com/4b03/0900766b80d2466f.pdf
        • прямо
          • Sep 2022
          • 261
          • Indonesia
          Sounds like the issue is with the graphics card if the monitor goes out with a no signal error message.
          Have you tried the monitor with other computer or a game console?
          • ant3202
            • Jun 2006
            • 275
            • Singapore
            Hi прямо
            Had tried with different hdmi devices, laptop, set top box and HDMI cables.
            The symptoms were the same. The monitor source will go out randomly and to power cycle again to display.
            Display will show for a short while around 3 mins and black out again, no signal.
            • прямо
              • Sep 2022
              • 261
              • Indonesia
              You will need a scope to trace the HDMI signals on the monitor controller PCB (where the VGA and HDMI ports are located) to see if any of them is missing when the no signal symptom is happening.
              Also, does it also happen with VGA input?
                by momaka
                03-15-2023, 10:17 PM
              • STKR123
                Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                by STKR123
                As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                I wonder if re-flashing the BIOS might be of any use here.
                As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                11-03-2024, 06:58 AM
              • wattage
                by wattage
                Hello Badcaps Community,
                07-13-2025, 04:41 PM
              • Rick_1234
                by Rick_1234
                Good evening, gentlemen.
                Things I tried
                06-22-2024, 04:44 PM
                Wise Wing F199 19'' LCD monitor - recapped
                by momaka
                Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                When I saw the Craigslist post, I wasn't...
                08-24-2020, 10:58 AM
