Viewsonic 19" Flashing backlight and no display.
  • ksm
    • 5
    • India
    Hi , I have got viewsonic 19 " LCD Monitor VA1918wm-2. When it starts up the backlight flashes , some sort of hissing sound and shuts down. Verified No picture under bright light. Replaced 4 Capacitors, but did not help. If only one ccfl is connected flashing stops.
  • Rtech
    • Jul 2010
    • 1095
    Re: Viewsonic 19" Flashing backlight and no display.
    'Hissing', can regularly be related to a wiring fault on Backlights,or less likely a dry joint somewhere on the Board.Would try some test backlights in place of the original first, and see if that corrects things before you start opening the Screen to check.
    • selldoor
      Slow Learner
      • 7870
      There is some scorching showing on the board - can we have a picture of the back.
      If it is not a bulb problem then I would change all the caps except the BIG one
      with Good Quality low ESR caps - panasonic or nichicon if you can get them.
      If you have no spares lamps to test with see this:
      https://www.badcaps.net/forum/showth...ght=test+lamps
      • ksm
        • 5
        • India
        All caps expect for the big one had already been replaced. I have attached pictures of backside of the board.
        A cool replacement for spare lamps .... will give it a try.
        • brgil96
          • Apr 2014
          • 6
          • Portugal
          Hi, I'm having a similar problem, actually it's exactly the same except that there IS (barely) visible picture under bright light. I've checked both power and input boards and no visible damage, for me that is. I can't post pictures today but I'll try to do so tomorrow.
          @OP, did you end up fixing your problem?
          • brgil96
            • Apr 2014
            • 6
            • Portugal
            (sorry, can't seem to find the edit button) Forgot to mention, it's a Viewsonic VX2260WM
            • brgil96
              • Apr 2014
              • 6
              • Portugal
              sorry for the triplepost. the pics are here.
              Also I should add, the hissing seems most intense at the top corners of the panel
                Hissing from top corner sounds to me like arcing from high voltage, this can be due to bad wire connection at the end of the lamp.
                See example here:
                http://s807.photobucket.com/user/bud...?sort=3&page=1
                Do you smell any ozone?
                • brgil96
                  • Apr 2014
                  • 6
                  • Portugal
                  Not really, I don't. Here's what happens a bit more detailed:
                  If I leave the screen off for a few minutes/hours, when I turn it on, it works perfectly fine. After one or two minutes, the hissing/buzzing begins, along with the backlight flashing. This gets more intense over a few minutes, until it finally stops for like a second or two, and then the backlight goes off. If I power it off and back on it will start buzzing and flashing immediatly and goes off after like 2 or 3 seconds.
                  Would this happen from a bad connection? Shouldn't it start happening right away instead of only happening when the screen gets warm? I don't know, just asking
                  And if it is indeed my best bet, how can I get to the CCFLs to see it?
                    When you have bad connection, when it gets warmer, the connection gets worst due to higher contact resistance.
                    Getting to the lamps is not easy, you will have to disassemble the panel to get to the lamps.
                    You use test lamps to verify if it is the board problem or the lamps problem.
                    • brgil96
                      • Apr 2014
                      • 6
                      • Portugal
                      Do you know where can I get test lamps locally and how much would it cost me?
                        • 30979
                        look for neons used to decorate pc's - you can get a pair with invertor for a few $ from china.
                        or from an old tv/monitor
                        • brgil96
                          • Apr 2014
                          • 6
                          • Portugal
                          Ill try to get them tomorrow or so then. One thing: the screen has two pairs of blue/pink cables, the ones for the backlight; if I disconnect one of them, the backlights dont flash BUT are only lit for about 2 seconds after I turn the screen on. Is this relevant?
                          • Lumberjack777
                            • 464
                            Yes its relevant. Backlight feedback circuitry requires all of the lamps to be plugged in.
                            What I do is.......get a set of test lamps. Unplug 1 set of lamps. Plug in the test lamps. See if it stays lit. If it goes out, move to the next plug. Once you get to the bad set of lamps it will stay lit with the test lamps plugged in. That's your bad set.
                              Make two of these:
                              https://www.badcaps.net/forum/showthread.php?t=19987
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4297
                                • Italy - Milan
                                if you don't have want you disassemble the panel and see if some lamps have darkened ends, those have to be replaced, other way you can tell me the p/n of the 16 pin chip on the right from the under side picture of the power board.
                                  • 30979
                                  btw, if the lamps are gone, you can get LED upgrade kits from china on ebay for about $15.
                                  they work very well - i'v fitted 3 sets so far.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    have you got a ebay link to the ones you recomend cheers
                                      • 30979
                                      sorry, the ebay-store has vanished!
                                      it was "creatall88" or something like that.
                                        • 30979
                                        aha - new store name!!!
                                        linky!
                                        http://stores.ebay.com/lcd-led-parts...p2047675.l2563
                                        • learnmore
                                          Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                                          by learnmore
                                          Hello Community!
                                          CASE DETAILS
                                          Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                                          13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                                          Tried inserting firmware on USB and left it in for a few hours, but no change
                                          03-03-2024, 09:49 AM
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • signal.quest
                                          Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                                          by signal.quest
                                          I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                                          03-17-2024, 10:14 AM
                                        • ikelectro
                                          After bios recovery by pen drive HP15s eq0007AU display flashing a light for short time.
                                          by ikelectro
                                          Schematic : DAOP5EMB6E0 REV:E​
                                          I have tried manually flashed the bios, also tried hp bios recovery tools to recover the bios. But no luck. Display is not coming, 3 to 4 times recovery display is coming if I tried to recover by pen drive[win+ B]. But after restarts it goes to dark screen and a light is flashing after a certain time in the display + fan speeds increasing and decreasing. I have tried almost every bios for this motherboard avaiable in the internet.
                                          Any help or guide to proceed?...
                                          03-19-2025, 08:17 PM
                                        • lanovey
                                          SF314-41 BIOS without internal display
                                          by lanovey
                                          Hello there,
                                          I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
                                          I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle...
                                          06-13-2025, 02:38 AM
