Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
  • HTR-Informatique
    • Jan 2019
    • 11
    • France
    YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
    I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
    On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
    I also changed the screen because the PC fell and the screen was broken.
    I changed the battery with a new and original battery.
    I also had corrosion/oxidation on the power supply part of the RAM, but it is cleaned, and no more worries.
    The problem I have now is that the PC works without any problems on the mains, but when I unplug the charger, the screen goes black and I have the keyboard backlight flashing, Caps Lock LED that stays on.
    I just have to reconnect the charger, so that the PC restarts and works again without problems.
    I have already exchanged the battery with the seller, always a new and original Dell battery.
    The worst thing is that the PC charges very well and is able to work on battery.
    I just have to do a CMOS clear, and the PC works without problems on battery.
    But, I do not change any BIOS settings, I put the PC on battery, after the CMOS clear, I turn it off, black screen and keyboard backlight flashing.
    I force stop it with the button, I turn it back on, on battery, same problem: black screen, keyboard backlight flashing and Caps Lock LED lit steadily.
    I put the charger, the PC works without any problems.
    The BIOS is in version 1.32.
    I tried to reinstall Windows, same problem.
    The problem also occurs when the PC is in the BIOS.
    I do all the DELL tests, no problems.
    The BIOS sees the original Dell 240W charger and the battery, charged to 100% and in excellent health.
    I tried to modify different BIOS settings but nothing works.
    I tried to downgrade to 1.31 (I can't go back further for security reasons, DELL limits), but the same.
    I do electronic repairs/microsoldering on laptop motherboards, but in this case, it's not just a problem with a MOSFET/HS charging chip because the PC charges and can still run on battery, just after a CMOS clear.
    I really don't see where the problem could come from.
    I have already tested 4 BIOS from Electronic Repair School: new BIOS, clean ME, NVRAM, as well as 2 BIOS from Badcaps.
    Only the second one from Badcaps allows you to start the PC, all the others are black screen, but I always have the same battery problem.
    The BIOS have 5 white LEDs and 3 orange in the worst case and black screen.
    Now even with a clear CMOS I can no longer start on battery.
    Thanks in advance.​
  • mon2
    • 15427
    Share the voltage to ground on each pin of the battery connector. Connect both, the battery and power adapter.
    • HTR-Informatique
      • Jan 2019
      • 11
      • France
      PINS 1, 2, 3 : 16,7V
      4 : 3,3V
      5 : 3,3V
      6 : 0V
      7: 0V
      8, 9, 10 : GND
      • HTR-Informatique
        • Jan 2019
        • 11
        • France
        Up ?
        • mon2
          • 15427
          Battery smbus lines are not shunted. Trace the same smbus lines to the charger chip pins. Confirm there is no disconnect.
          Link the schematics if available in the schematics forum.
          Is there a cmos / rtc battery onboard? If yes, test with a fresh one.
          • HTR-Informatique
            • Jan 2019
            • 11
            • France
            So yes, there is a CR2032 battery, but it's OK, I even tested with another one, or without, same.
            Afterwards, an SMBus problem, I thought about it, but I upgraded/downgraded the EC via the different BIOS on the Dell site, still the same.
            On Windows in addition, the battery communicates well, I have the charge LED, the battery charges, I have the battery level, the time remaining before full charge.
            In addition, with a CLEAR CMOS, I can immediately, after the CLEAR CMOS start on battery, and everything works, I have the remaining autonomy time.
            So well, right now even with a CLEAR CMOS I can no longer start the PC on battery.
            The PC tries to turn on on battery, the keyboard turns on/off in a loop but nothing, and as soon as I plug in the charger, the PC starts without problem.
            So that's why this problem is incomprehensible to me.
            I don't think there are any problems with SMBus communication then, but I can check yes.
            Before I just had to do a CLEAR CMOS, it worked immediately after, but if I turned off the PC and turned it back on on battery, I had the keyboard that turned on/off in a loop, and I had to put the charger in to start.​
            • the Benninger
              • Nov 2022
              • 189
              • venezulan
              In your case, I would start looking at the components with a thermal camera to see if I notice any components heating up too much before starting the light show.
              • mon2
                • 15427
                Schematics?
                What is the voltage to ground of RTC_DET#?
                EC is the MEC1416 @ UE1?
                Check the power rails when using the battery and when using the adapter.
                Test the MEC_XTAL1 / MEC_XTAL2 and XTAL for operation.
                CMOS parameters will be stored inside the EC which is battery backed by the CR2032. If you have to reset the CMOS contents to allow for a boot, the battery and/or the MEC1416 are suspects. Perhaps the EC RAM is defective? The MEC1416 appears to be available through standard distribution like Mouser / DK / Microchip online. Do not believe this EC requires to be programmed by internal flash.
                Suggest to review the voltage on each pin of the charger IC with the adapter and battery; then with the battery only. Post the list of pins with their netnames (pin function) for a review.
                • TurcoLoco
                  DELL U4320Qt Black Screen When On
                  by TurcoLoco
                  Happy New Year To All!
                  This clean Dell U4320Qt monitor has no LEDs or screen when plugged in. I didn't feel any vibrations or noise either.
                  My guess is something with the Power Board but as a noob, not sure.
                  Upon close and careful glance at both the Power and the Controller board, no obvious faulty components or marks.
                  I have not yet inject any power to the power board but when I plugged its power cord as normally done, no overheating components detected on thermal camera.
                  I tried searching for this model here and online but no schematics I could find.
                  Oddly...
                  01-04-2026, 05:50 PM
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • danielsak
                  Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
                  by danielsak
                  Hello, I have issue with Dell Inspiron 3542.
                  Motherboard marking:
                  Code:
                  PWB FX3MC REV: A00
                  The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
                  1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
                  1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
                  10-11-2024, 04:36 PM
                • tomodachi
                  Dell Precision 5510 " Not a Dell Battery"
                  by tomodachi
                  Hi
                  Dell Precision 5510
                  Mobo code : LA-C361P
                  This one came in for battery replacement but without original battery, so original battery and charging history is unknown.
                  The customer said he bought the computer several years ago second-hand and was told that there was no battery inside but that he could purchase one if he wanted.
                  So we ordered a geniune battery for customer, plugged it in
                  RTC battery was also dead and it was also replaced. First boot up brought up warning message;
                  Funny thing is Service Tag is already set.
                  And...
                  11-07-2024, 06:08 AM
                • mferna14
                  MacBook Air A2681 battery problem after Screen Replacement
                  by mferna14
                  Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
                  12-06-2024, 08:10 PM
