After bios recovery by pen drive HP15s eq0007AU display flashing a light for short time.
  • ikelectro
    • Aug 2013
    • 20
    • India
    Schematic : DAOP5EMB6E0 REV:E​
    I have tried manually flashed the bios, also tried hp bios recovery tools to recover the bios. But no luck. Display is not coming, 3 to 4 times recovery display is coming if I tried to recover by pen drive[win+ B]. But after restarts it goes to dark screen and a light is flashing after a certain time in the display + fan speeds increasing and decreasing. I have tried almost every bios for this motherboard avaiable in the internet.
    Any help or guide to proceed?
  • pc_okay
    • May 2022
    • 244
    • FRANCE
    i had a similar problem With hp ryzen laptop, try to reflash with an older revision of bios from hp support website.
    • kenkaniff
      HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
      by kenkaniff
      Product Name: HP Pro x360 Fortis 11-inch G9
      System BIOS: U94 Ver.01.08.00 10/06/2023
      Serial Number: 5CG31946F5
      SKU Number: 85W05EC#AK8
      Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
      This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
      I needed to remove bios password...
      10-01-2025, 04:32 AM
    • David Gee
      Bios Request HP 17-CN0023DX
      by David Gee
      I am currently working on recovering my HP Laptop (Model: 17-cn0023dx) after a BIOS corruption issue. The laptop is stuck in a no-boot state, and the Caps Lock light is blinking with a 3.2 code (3 long, 2 short), which according to HP documentation indicates a BIOS corruption failure.
      I have prepared a USB stick using the HP Cloud Recovery Tool, but I confirmed that it does not include a BIOS recovery image for Crisis Recovery. I also attempted to extract the BIOS file from the spXXXXX BIOS update package provided on the HP Support site, but that update only provides...
      05-03-2025, 09:58 AM
    • The_Memory_Guy
      Dell T7820 stuck in Bios Recovery Mode
      by The_Memory_Guy
      HI,
      I have a Dell T7820 stuck in Bios recovery mode. I never get Dell Boot screen or anything visible on screen. The system just gives me 3 white lights and 3 orange lights indicating Bios recovery mode.
      What I have tried to get to recover the Bios, there seems to be some conflicting advice about recovering the system.
      All of them say to download the latest bios from the dell website which is a .exe file. I have done that
      https://www.dell.com/support/product...BUT090/drivers
      Some...
      07-07-2025, 06:52 AM
    • mikinana64
      Fujitsu U939X BIOS Recovery (EC Corrupt)
      by mikinana64
      I was clean install Windows 10 Pro without installing driver, because i believe windows will download itself.
      But 2 days later it hard bricked, just battery LED charge indicator when plugged in, no boot or even post. Unplugging the battery will result zero response, LED flicker 0.1s and then everything turned off, no response to any button. Main BIOS powered 3.3V but EC is 0V.
      So i though it just BIOS corrupted, and confirmed EC BIOS has been corrupted (First header is 55 AA 01 00 FF FF FF and the rest is always FF FF until offset 10000 with 00 00 blank and 11000 where...
      10-23-2025, 02:13 AM
    • Timeeez
      X270 - Bios flashing help
      by Timeeez
      I am still a beginner and want to learn more about flashing bios. First of all, thank you very much for the tutorials made on this forum it helps a lot.
      Lets get straight to the point. When I try to flash the bios of my Lenovo X270 it restarts several times and always returns to the bios that was there at the beginning. When I get the bios from someone on the forum and write it to the bios chip, I always have the same serial numbers. I have the feeling that the pc is reflashing itself. Where could this come from? How to avoid this problem?
      11-30-2022, 05:17 PM
