Vintage SONY Digital Clock Radio ICF-C12W no audio
-David VanHornComment
Thank you, all. Yes, I found a list of substitutes/equivalents of certain phased out components. While we were troubleshooting the low voltage issue, I found replacements for Q5-Q7, having the idea of changing them back then to see what would happen. There is a local electronics shop where I live and their website actually offers an available substitute part for the item searched. So finding a replacement locally isn't impossible.
I can buy some and try with Q1 first as it is easy to remove. I really hope it won't be in vain like with other unsoldered original components that turned out fine - which would leave us with no solution yet. I still hope for that "Aha!" moment. 🙂
it is safer for me to buy a few of those transistors and see if they would change anything in the faulty unit. 🙂Last edited by UserXP; 08-17-2025, 12:16 PM.Comment
OK, this is the C930 that I was able to find. Will it match for Q1, should I go with the replacement?
Also, how to check which pin is E and which is C? I know I can determine the base, it should have positive to negative probe voltage drop of ~0.7V to both C and E. There should be no flow between C and E. But how will I know which one is which?
This transistor is flat on both sides.Last edited by UserXP; 08-18-2025, 06:51 AM.Comment
The text marking should be on the same side.
So just put it in the same way around as the original one, with the text facing the same way.
Otherwise, you can check with the datasheet, which will tell you the pinout.
In the datasheet stj posted, you can see the pinout.
Yes the case is flat on both sides but there is a bevel edge on one side, that is how you can reference the pinout.Last edited by Agent24; 08-18-2025, 09:39 PM."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
This radio is driving me crazy. I found 2SC930 transistors. But the ones soldered at Q1 and Q2 are 2SC1675. Thinking that they are interchangeable, since the manual offers one, I went for it. And - the radio doesn't sound any different even with C930 soldered.
I also tested the removed one, 2SC1675, it seems OK. Voltage drop is about 756mV from B to C and 761mV from B to E. This appears normal, right?
I wouldn't be surprised if yet another original component turned out to be fine. What a bunch of dead ends this radio is throwing at us! 🙁Last edited by UserXP; Yesterday, 10:02 AM.Comment
It won't tell you if the transistor is degraded, if the junctions are leaky, or anything else.
For that you would ideally want a curve tracer.
Some multimeters do have a basic DC gain/HFE measurement function, but that won't tell you if the gain is degraded at high frequencies, which is important in an FM circuit.
But anyway, if you replaced it with a brand new one, and got no change, then probably the original was okay, and the fault lies elsewhere.
In any case, you could just buy a new filter from AliExpress or such, they are cheap there, if the filter has drifted in frequency or is outputting low amplitude maybe it would cause this problem? (again, I don't know enough about radio circuits to say for sure), although other parts are probably more likely to fail - I think it was the lower-frequency ceramic filters that sometimes go bad - but yours is crystal so less likely. Still not impossible though.
An oscilloscope would be great at this point, but if you don't have one, I think the only real option is to start swapping parts until you get lucky."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
Normal for the basic diode-junction test, yes, but that will only show you if the part is short or open circuit.
But, this unit demonstrates difficulty in receiving radio stations at maximum possible loudness (such that is at this time) without the antenna - something that the working unit does without issues. The faulty one plays a station, and if I start moving my finger towards the antenna solder pad, the volume starts to increase. If I am holding a screwdriver, the same happens, and when I actually touch the pad with it, the volume increases to the same level it works as with the antena wire. Still wuieter than AM, though.
The working unit doesn't behave this way, when it senses a station without the antenna, it tunes in and plays it at the maximum loudness without this "metal help".
There must be something in the faulty unit that makes the received signal "lower" or weaker, and maybe making it quieter in the process.
I don't know anymore... I am this close to giving up... 🙁 But on the other hand, everything else is so OK with the radio that makes me feel sorry to scrap it, it's just this one stubborn fault.Last edited by UserXP; Today, 09:13 AM.Comment
by mikey5791Hi forum members,
In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
I opened the casing inside and checked for any dry solder, burned component or loose wires...-
by BOSCHNJAKABOUT ME INTRODUCTION FILE
2024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
2022 BEV, PROJECT ?
2021 BEV, PROJECT ?
2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...-
Channel: Visitor Messages
12-28-2023, 02:09 PM -
by CapSnap123I'm trying to fix a digital multimeter. It was working until I blew the fuse (actually the "buzz" for continuity wasn't working). I've now replaced the fuse but it's acting strangely. When I turn the dial to V, nothing happens. But when I turn to anything else, it makes a continuous, very fast clicking sound - like the piezo buzzer is trying to do something. And at each position of the dial (other than V) there are brief flashes of life on the LCD. It doesn't seem to matter if the probes are connected. I wasn't sure where to start, so I've tested most of the diodes and cleaned the...
Hello All,
I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
https://www.hifivision.com/threads/m...-screen.98243/
Troubleshooting Summary: Majority Internet Radio - Flash Chip...-
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
Channel: Schematic Requests ONLY!
- Loading...
