Vintage SONY Digital Clock Radio ICF-C12W no audio
  • Agent24
    I see dead caps
    • Oct 2007
    • 4977
    • New Zealand
    #161
    Originally posted by UserXP
    Thanks, Stj and CapLeaker. So, you don't think it's Q2. But, if I am to remove it and it turns out to be bad, I'd have to have a replacement part as there is no point in swapping them as I'd be still left with a faulty one in the circuit... Removing Q2 is something I don't how I'll manage to do. It is immersed in some kind of hardened paste. Can I buy a few 2SC930 transistors and just put the leads of the new one onto the pads where the existing Q2 is soldered? If the old one was bad, would the new one in parallel "take over"? This would save me the trouble of actually removing Q2 if it wouldn't be necessary - but, I am willing to try here whatever you guys suggest.
    However, Q1 wouldn't be too difficult to remove.
    If you do buy a new transistor you may find BF495 easier to get as a substitute. But be aware the pinout may be different.
    -David VanHorn
    • Agent24
      I see dead caps
      • Oct 2007
      • 4977
      • New Zealand
      #162
      Originally posted by stj
      need a 455KHz source,
      i wonder how cheap one can be made!
      https://electronbunker.ca/eb/SignalGen455.html ?
      -David VanHorn
      • UserXP
        • Apr 2012
        • 418
        • Serbia
        #163
        Thank you, all. Yes, I found a list of substitutes/equivalents of certain phased out components. While we were troubleshooting the low voltage issue, I found replacements for Q5-Q7, having the idea of changing them back then to see what would happen. There is a local electronics shop where I live and their website actually offers an available substitute part for the item searched. So finding a replacement locally isn't impossible.
        I can buy some and try with Q1 first as it is easy to remove. I really hope it won't be in vain like with other unsoldered original components that turned out fine - which would leave us with no solution yet. I still hope for that "Aha!" moment. 🙂
          • 31079
          you could "borrow" parts from a working radio to see what actually is needed
          • UserXP
            • Apr 2012
            • 418
            • Serbia
            #165
            Nnno... I wouldn't want to disassemble it that far. I fear I might end up with two inoperative units. 😃
            it is safer for me to buy a few of those transistors and see if they would change anything in the faulty unit. 🙂
            • UserXP
              • Apr 2012
              • 418
              • Serbia
              #166
              I checked the soldered Q1 and Q2, they are 2SC1675 IF signal amplifier.
              I found these equivalents: BF241, BF255 and BF495 as Agent24 has already suggested. I also found 2SC930 new old stock.
              • UserXP
                • Apr 2012
                • 418
                • Serbia
                #167
                OK, this is the C930 that I was able to find. Will it match for Q1, should I go with the replacement?
                Also, how to check which pin is E and which is C? I know I can determine the base, it should have positive to negative probe voltage drop of ~0.7V to both C and E. There should be no flow between C and E. But how will I know which one is which?
                This transistor is flat on both sides.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4977
                  • New Zealand
                  #168
                  If it's the same model as the old one, it should be the same pinout.
                  The text marking should be on the same side.
                  So just put it in the same way around as the original one, with the text facing the same way.
                  Otherwise, you can check with the datasheet, which will tell you the pinout.
                  In the datasheet stj posted, you can see the pinout.
                  Yes the case is flat on both sides but there is a bevel edge on one side, that is how you can reference the pinout.
                  -David VanHorn
                  • UserXP
                    • Apr 2012
                    • 418
                    • Serbia
                    #169
                    This radio is driving me crazy. I found 2SC930 transistors. But the ones soldered at Q1 and Q2 are 2SC1675. Thinking that they are interchangeable, since the manual offers one, I went for it. And - the radio doesn't sound any different even with C930 soldered.
                    I also tested the removed one, 2SC1675, it seems OK. Voltage drop is about 756mV from B to C and 761mV from B to E. This appears normal, right?
                    I wouldn't be surprised if yet another original component turned out to be fine. What a bunch of dead ends this radio is throwing at us! 🙁
                    • UserXP
                      • Apr 2012
                      • 418
                      • Serbia
                      #170
                      Is it possible to test the signal frequency with the Hz setting on the multimeter? Can we test the CF that way?
                      • CapLeaker
                        Leaking Member
                        • 8210
                        In one word: nope.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4977
                          • New Zealand
                          #172
                          Normal for the basic diode-junction test, yes, but that will only show you if the part is short or open circuit.
                          It won't tell you if the transistor is degraded, if the junctions are leaky, or anything else.
                          For that you would ideally want a curve tracer.
                          Some multimeters do have a basic DC gain/HFE measurement function, but that won't tell you if the gain is degraded at high frequencies, which is important in an FM circuit.
                          But anyway, if you replaced it with a brand new one, and got no change, then probably the original was okay, and the fault lies elsewhere.
                          Not unless your multimeter can measure over 10Mhz frequencies, which I highly doubt it.
                          In any case, you could just buy a new filter from AliExpress or such, they are cheap there, if the filter has drifted in frequency or is outputting low amplitude maybe it would cause this problem? (again, I don't know enough about radio circuits to say for sure), although other parts are probably more likely to fail - I think it was the lower-frequency ceramic filters that sometimes go bad - but yours is crystal so less likely. Still not impossible though.
                          An oscilloscope would be great at this point, but if you don't have one, I think the only real option is to start swapping parts until you get lucky.
                          -David VanHorn
                          • UserXP
                            • Apr 2012
                            • 418
                            • Serbia
                            #173
                            Yes, I soldered it back and the volume is absolutely identical as with the new one. Another original Sony part that proved OK.
                            But, this unit demonstrates difficulty in receiving radio stations at maximum possible loudness (such that is at this time) without the antenna - something that the working unit does without issues. The faulty one plays a station, and if I start moving my finger towards the antenna solder pad, the volume starts to increase. If I am holding a screwdriver, the same happens, and when I actually touch the pad with it, the volume increases to the same level it works as with the antena wire. Still wuieter than AM, though.
                            The working unit doesn't behave this way, when it senses a station without the antenna, it tunes in and plays it at the maximum loudness without this "metal help".
                            There must be something in the faulty unit that makes the received signal "lower" or weaker, and maybe making it quieter in the process.
                            Yeah, trial and error method. I fear I would end up replacing every replacable component (except the adjustable ones) and still getting the same results. It has been quite discouraging so far. 😃
                            I don't know anymore... I am this close to giving up... 🙁 But on the other hand, everything else is so OK with the radio that makes me feel sorry to scrap it, it's just this one stubborn fault.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4977
                              • New Zealand
                              #174
                              You could try replacing the other transistor, of course...
                              Don't have scrap it, if it works other wise you can keep it, one day you will probably have the right tools and it will be nice to finally find out what was wrong.
                              I've done that with things before.
                              -David VanHorn
                              • UserXP
                                • Apr 2012
                                • 418
                                • Serbia
                                #175
                                I ordered the E10.7A filters, some Murata brand, sounds Japanese. They are in a lot of 10, so I will have spares should I ever need them, if it turns to be yet another dead end on this radio.
                                Now, about that other transistor... As I mentioned before, it would be very difficult to remove it as it is engulfed in some kind of hardened paste. But, I noticed that touching any of its pads with an isolated piece of metal lowers the volume further. And, if I touch the Base, the volume goes completelely silent, like it "drains away". What do you think, is this a sign of expected behaviour, or there may be something going on with this Q2?
                                  • 31079
                                  knowing the age of the device, the "paste" is probably bees wax.
                                  try touching it with the iron
