Dim Clock LCD on Jenn-Air wall oven
  • pbrabner
    • 6
    Re: Dim Clock LCD on Jenn-Air wall oven
    Here is a photo of my display board. Model# JJW9530DDS. Which caps do I replace?
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      #162
      All.
      Follow the white rabbit.
      • pbrabner
        • 6
        I got the all part. What did the other comment mean?
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          #164
          both of these. if not the display itself could be bad.
          • pbrabner
            • 6
            Now when I push Bake I am getting a message that says "Feature Not Available" I looked that up and it says that there is a fault that is keeping the cantroller from working. Any suggestions?
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              #166
              let me lookup thee reset procedure for the model.
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                #167
                Press and hold the BACK and ENTER pads simultaneously for five seconds.
                • pbrabner
                  • 6
                  All that did was lock and unlock the door. When the "feature not available" message shows up there are two timers and timer #2 shows "1c2c" when the above message shows up.
                  • pbrabner
                    • 6
                    Also I when I had the panel off I touched the top end of two of the caps and they shocked me. That is not normal is it?
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      #170
                      IIRC they are not isolated, so yes.
                      • goontron
                        5000!
                        • Dec 2011
                        • 4108
                        • US
                        #171
                        1c2c is a touchpad error... Strange. Can I get a pic of the front and back of the touchpad.
                        • large9
                          My board just went out for the fourth time and the last board I put in has the resistor in series with the C3. I have three replaced bad boards plus a bad board in the stove and I ordered parts to cover all four boards. No one has mentioned a desolder pump so I guess I won't need one. I am repairing a 71003424 board.
                          • large9
                            I ordered the parts for all the boards and now have the stove display is back. Two bad caps on the one board and resistors were used on two of the c3 slots for the other boards. I was surprised to see this but at least I will have a spare when the present board fails again.
                            • mbutle1
                              • Jan 2015
                              All I can say is Thanks bluto and the members on this forum! I became a member just because of this topic. My Jenn-Aire oven's display over the last few weeks began dimming. I found this thread through a Google search. Read through it with great interest. This was my exact issue! I ordered the recommended parts from Digi-Key. After taking the oven face off. I replaced all the caps on the board. I have never replaced caps, ever. I was pretty confident after reading this post and watching several youtube videos about the subject. After putting my oven back together and turning the power back on to it. The display worked like brand new. The cost was under $10 and the time was one morning. Thank you for everything here!
                              • khs
                                • Mar 2015
                                Thanks .... just repaired my Jenn-Air SVE47600WC using the info in this forum. I had plenty of experience with soldering components so it was a breeze. My solder sucker makes removal simple. Those without experience should keep in mind not to use too much heat as it will damage the traces on the board.
                                • Remidetroit
                                  • Sep 2015
                                  Jenn-Air JDS9865BDP Range
                                  Display became very dim about one week ago. It's very dim as you must have lights out or hand over display to tell it even works. Reading forums I learned that C3 capacitor is likely the cause but my model is newer different. I planned to replace the capacitor anyway but was unable to find a 57u rated 250V locally. I went to a TV repair store to see if they stocked them and they put a quick tester on them (while still on circuit board) and they said “that's not the problem”…. I had him put the same tester on C3, C6 and C7 which all tested good for what that's worth. So now I don't know if it's a waste of time to still replace them or if this is a different problem. Advice?
                                  • goontron
                                    5000!
                                    • Dec 2011
                                    • 4108
                                    • US
                                    #177
                                    did they test them with the board physically hot? if not, replace them. it could show up when the board warms.
                                    • fzabkar
                                      • Mar 2009
                                      • 772
                                      Check the capacitor on pins 2 and 3 of ST7.
                                      • clearchris
                                        • Dec 2013
                                        • 687
                                        If the board is anywhere near heat, just replace all the caps. If they arent cooked yet, they will be soon. Caps are cheap.
                                        I did this for my oven this year. Oven was only a few years old too.
                                        • weisj
                                          • Sep 2015
                                          • usa
                                          #180
                                          Just wanted to say thanks to Bluto and this site! Just successfully replaced the bad capacitor for my dimmed out oven clock. I have never soldered anything in my life or, sorry to say, even knew what a capacitor was but dammed if I was going to buy a new board without trying. Read the post, watched the video, bought all the equipment and voila!
                                          Aint the internet great....
                                          • asuwish824
                                            Jenn Air Wall Oven Dim LCD
                                            by asuwish824
                                            I recently purchased a Jenn Air Wall Oven model number jjs2730ws00. It functions properly except that the lcd display is rather dim. No adjustment in the settings seems to improve or even change the dimming/brightness of the display. My hope is I can repair the current display instead of purchasing a new or used unit to replace. I prefer to fix at the lowest point for the joy of the repair. Also throwing out what would otherwise be a perfectly good part just because perhaps a capacitor or other small part is bad seems obviously wasteful. Any guidance would be appreciated.
                                            PS It...
                                            05-18-2022, 10:30 PM
                                          • Fsufan1391
                                            LG Oven model LREL6325F
                                            by Fsufan1391
                                            Hello everyone my oven is less than 2 years old and all of a sudden recently when i run the oven for 15 minutes or so and i am done with it and shut it off. after about 10 minutes it starts chiming and randomly putting it in different modes like the touch screen is being touched but no one is around it. I have tried to reset it by unplugging it multiple times and no luck. I took it apart to see the main board and everything looks fine. I am wondering if i should replace the main board or if its in the control panel. the touch screen is very responsive and works like it should. its only acting...
                                            04-23-2025, 05:42 AM
                                          • Joe24
                                            Maytag Whirlpool Kenmore clothes dryer data bus
                                            by Joe24
                                            Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
                                            Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
                                            I've been over the board looking for...
                                            01-13-2025, 06:50 PM
                                          • bpjl
                                            SEF 551.10 - Error starting the reflow oven.
                                            by bpjl
                                            When starting the SEF 551.10 reflow oven, the following problem occurs:
                                            It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
                                            PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
                                            10-17-2024, 06:30 AM
                                          • goodpsusearch
                                            Daewoo microwave oven repair
                                            by goodpsusearch
                                            One day my microwave oven stopped heating.
                                            It would turn on and rotate the plate but no heat.
                                            I removed the cover and checked components with digital multimeter.
                                            Found that the high voltage fuse was blown.
                                            This is not the AC fuse, if the AC fuse was blown then the oven would appear totally dead.
                                            Then I tried to find replacement fuse on local electronic parts stores and this specific value was not available so I got the closest I could find.
                                            I replaced fuse and tried to heat up a glass of water.
                                            Strange noise...
                                            01-24-2021, 03:56 PM
