Dim Clock LCD on Jenn-Air wall oven
  • RoadsterZ4
    • Dec 2021
    • 5
    Re: Dim Clock LCD on Jenn-Air wall oven
    Thanks for the feedback. I'll look at it deeper after work in a few days. I'll gather some parts.
    • RoadsterZ4
      • Dec 2021
      • 5
      Originally posted by redwire
      The resistor does not dissipate even 0.5W normally.
      I would replace C3 and C4 and test the old parts, one of them should have failed short. That's a bit weird, unless you have high mains voltage or power surges/lightning. I wonder what their operating voltage is. Test diodes D3 and D4 too.
      I went down the rabbit hole a little into the circuit. Capacitor C3 feeds C4, so if C3 or C4 fail (low value) it will give a dim display. If either shorts, no display and it would burnt up the resistor.
      The board has already been refurb'ed so it will be extra fragile, the PCB pads.
      Update:
      I received my order from Digikey -- the replacement capacitors. I ordered a few extra caps since I had to pay for shipping anyway
      I removed the burnt resistor and 220uf; along with the neighboring 470uf.
      Soldered in a new 470uf along with a new 68uf in the C3 position (I had to clean up the joint and contact from the burnt side). All soldered in and tested for continuity.
      I reassembled and it works perfectly!! Brighter that it ever has been and all modes work. YAY!!!!!
      A huge THANK YOU for all of the great information on this site and the awesome detailed responses from you - the experts. I am very grateful.
      I am so glad I took electronics classes in high school back in the late 80s. It made this task a simple one.
      I will keep an eye on it and I am hoping it lasts for another 20 years -- but I am sure we will replace it for a bigger and nicer one at some point.
      Safe holidays!
        • Jul 2011
        • 6069
        I am glad you got it working again and for the time being it does not end up in the landfill or someplace like that for now
        • RoadsterZ4
          • Dec 2021
          • 5
          Here is a quick pic from this morning. Wife loves it. Just in time for holiday cooking!
          Thanks again!
          • redwire
            • Dec 2010
            • 3912
            That's great, I think some turkey gonna be cooking soon
            To summarize, fixing Jenn-Air oven display:
            Replace C3 68uF 35V (refurbished/newer boards upsized it to 220uF and added a resistor 27R 3W, for longer life... but they use cheap parts)
            Replace C4 470uF 35V
            It's a Digi-Key or Mouser parts order for under $20 incl. shipping, to fix an expensive wall-oven, keeping it out of landfill.
            • Longbow
              • Jun 2011
              • 623
              I see that this specific subject has generated amazing interest over the years. Certainly, replacing electrolytics on the display pcb will bring back the Jenn Air (and others) display brightness.
              However...these things are getting old by anyone's standards, so we have to be practical and realize that the VFD (the display tube itself) slowly ages and as it does, it becomes dimmer and dimmer. Nothing can be done about that.
              The second very common problem on these stoves is that various functions begin to start up and stop by themselves. Broiler fan starts to run all the time is the usual. I have examined the control pcb minutely and found no obvious part failures. A new control pcb fixes the ghost problems. No differences can be found between a bad board and a good board. Therefore I am 99% sure that the EEPROM on the original control boards also ages (from heat) and the software finally becomes corrupted. Since it is easy to burn an 8 pin EEPROM, I would recommend that someone do just that while your control board is still working.
              Then, the next problem worth mentioning is that the front panel membrane strip slowly absorbs grease, spray cleaners, etc. One or more of the functions stop working. The membrane can't be fixed and is no longer available. FYI there are several different part numbers for this membrane. The parts all look alike, but have subtle differences that can prevent them from mounting on your stove.
              The final award goes to the burners themselves. The glass-covered heating elements fail after some number of years. The pull-out heating units can't be disassembled without destroying them. It is sometimes possible to find plug in units with coil-style burners. All these parts are quite expensive. Pretty soon, the price of new stove starts looking attractive. Depends upon how creative you want to be.
              Good Luck,
              Longbow
              Is it plugged in?
              • bluto
                • Oct 2007
                • 560
                #247
                You could test this theory by dumping the EEPROM on your new board and replacing/flashing the EEPROM on your old board.
                • JohnJones
                  • Jul 2021
                  Dim display on Jenn-Air double wall oven
                  Hi, the display on my JennAir JJW9827DDS double wall oven appears to be dim, so I was looking for ideas on which parts to replace. I found these images of the board from eBay.
                    • Jul 2011
                    • 6069
                    The first picture it looks like there are two caps between the two displays and they look like are swollen at the tops of them it hard to tell from the pictures that you provided but that would be the best place to start if your caps look like them
                    • joltman
                      • Dec 2021
                      I also found this thread earlier this year. We have a Maytag MEW6630BAB. A friend was selling his house that had this oven in it. No one was buying the house. The potential buyers all said they wanted stainless appliances in the home. So, my friend went out and bought not as nice stainless appliances. He was going to have Best Buy take them away, but I swooped in and saved this double oven and a Maytag fridge (which now lives in my garage). The kitchen at my house didn't even have a cabinet for a double oven, but my wife and I were patient. We finally got some cash together to update our kitchen. New counter tops, removed old slide in stove and replaced with gas cook top, and a new cabinet for a double oven! I ran the electrical to the panel, installed the breaker in the panel. That oven was sitting in our garage for over 3 years at that point. It worked first try! Oven was doing great for about 6 months, then the display went very dark. Oven still works. Today, I finally found the motivation to crack open the front panel (much easier than I had feared, just 4 screws under the front panel). I found that the board is refurbished (confirmed by my friend who replaced the original with this). I've placed the order for the 4 caps. I'll get to mess around with my solder station, which is always fun!
                      • redwire
                        • Dec 2010
                        • 3912
                        Let us know what parts you bought... and don't put the new caps in backwards lol. (take pics).
                        Older beige boards have C3 68uF 35V and missing 27R 3W surge resistor - which gets added during a refurb. Newer boards increased C3 to 220uF. Is this list right:
                        C3 220uF 35V
                        C4,C5: 470uF 35VDC
                        C7 2.2uF 50V
                        C11 tantalum - people leave it alone
                        Whirlpool 71001799 Oven Control Board
                        Whirlpool 71001872 Oven Control Board
                        I can't believe the ripoff pricing for these oven control boards.
                          • Jul 2011
                          • 6069
                          I can not believe the price of control boards in general are a lot higher than they should be
                          This is the reason I will try to repair one before I would consider buying a new control board for any device
                          • GeorgeT
                            • Sep 2010
                            • 11
                            Click image for larger version  Name:	jenn air working2.jpg Views:	0 Size:	111.7 KB ID:	3176312
                            My friend brought me over the display control board for his Jenn-Air SVD48600P oven because the display was no longer lighting up. Just like the original post from Bluto, the problem was C3. It measured completely open with my ESR cap meter. What is strange is that the capacitor was a high quality Nichicon. There must be something wrong with the display board circuit to cause such failures. I replaced the 68uF 50 volt cap with a 100uF 50 volt. Thank you bluto for taking the time to document this repair. As you can see in the photo, it's working great now!
                            • RDC55
                              • Dec 2017
                              • 180
                              So is there a good explanation of why a single segments can have varying brightness as in the OP's pic? Nice fix by the way OP and others who followed the advice - it is so nice to see some of these items get repaired and not thrown away.
                              Click image for larger version  Name:	image.png Views:	0 Size:	183.7 KB ID:	3333532
                              When each segment should be the same brightness like the one below Click image for larger version  Name:	image.png Views:	0 Size:	219.1 KB ID:	3333534
                              Click image for larger version  Name:	image.png Views:	0 Size:	64.4 KB ID:	3333533
                              • asuwish824
                                Jenn Air Wall Oven Dim LCD
                                by asuwish824
                                I recently purchased a Jenn Air Wall Oven model number jjs2730ws00. It functions properly except that the lcd display is rather dim. No adjustment in the settings seems to improve or even change the dimming/brightness of the display. My hope is I can repair the current display instead of purchasing a new or used unit to replace. I prefer to fix at the lowest point for the joy of the repair. Also throwing out what would otherwise be a perfectly good part just because perhaps a capacitor or other small part is bad seems obviously wasteful. Any guidance would be appreciated.
                                PS It...
                                05-18-2022, 10:30 PM
                              • Fsufan1391
                                LG Oven model LREL6325F
                                by Fsufan1391
                                Hello everyone my oven is less than 2 years old and all of a sudden recently when i run the oven for 15 minutes or so and i am done with it and shut it off. after about 10 minutes it starts chiming and randomly putting it in different modes like the touch screen is being touched but no one is around it. I have tried to reset it by unplugging it multiple times and no luck. I took it apart to see the main board and everything looks fine. I am wondering if i should replace the main board or if its in the control panel. the touch screen is very responsive and works like it should. its only acting...
                                04-23-2025, 05:42 AM
                              • Joe24
                                Maytag Whirlpool Kenmore clothes dryer data bus
                                by Joe24
                                Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
                                Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
                                I've been over the board looking for...
                                01-13-2025, 06:50 PM
                              • bpjl
                                SEF 551.10 - Error starting the reflow oven.
                                by bpjl
                                When starting the SEF 551.10 reflow oven, the following problem occurs:
                                It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
                                PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
                                10-17-2024, 06:30 AM
                              • goodpsusearch
                                Daewoo microwave oven repair
                                by goodpsusearch
                                One day my microwave oven stopped heating.
                                It would turn on and rotate the plate but no heat.
                                I removed the cover and checked components with digital multimeter.
                                Found that the high voltage fuse was blown.
                                This is not the AC fuse, if the AC fuse was blown then the oven would appear totally dead.
                                Then I tried to find replacement fuse on local electronic parts stores and this specific value was not available so I got the closest I could find.
                                I replaced fuse and tried to heat up a glass of water.
                                Strange noise...
                                01-24-2021, 03:56 PM
