Dim Clock LCD on Jenn-Air wall oven
  • rsico
    • Jan 2011
    #41
    Re: Dim Clock LCD on Jenn-Air wall oven
    Thanks everone for your technical help. I followed the above procedure for replacing the capacitors and it worked perfectly.
    • rdevers
      • Feb 2011
      #42
      Thanks for the alternative to below:
      Called Jenn-air dealer for help they said could order part "if and when off back order status" at $250 plus s&h, with half up front.
      • rustanj
        #43
        Thanks a bunch Bluto!!! Yes people are still googling for other options instead of paying the outrageous price of a new board. 2 bucks and change for all four caps plus shipping sure beats $120 (cheapest I found online but was still questioning if it would be an exact match or not) Now I shouldnt have to worry about the wrong board either since I have no doubts as to being able to get the repair done and working properly again. Thanks again!!!!
        • delaware74b
          • Apr 2009
          • 628
          Bluto, thanks to you for your cap list on this board. My boss' wife asked me to replace the clock board in her Jenn-Air range last night. I remembered seeing this article about the board. I had to get the model number of the range and it was the same one as yours.
          I went through my stock of caps and luckily enough, I had all 5 for the clock board. The 68uF read only 17uF with ESR of 5! It now has Panny FC's.
          Boss' wife was surprised when I turned the breaker back on and the clock reappeared for the first time in 2 years. Present cost of replacement board $175USD+ S/H. Cost of 5 caps I had on hand $2.
          Many thanks to Badcaps.net and all members!
          Stupidity should be a crime, especially for drivers. I have NO patience for them.
          • bluto
            • Oct 2007
            • 560
            #45
            I bet your boss thinks you are a genius now
            • CC25
              • Jun 2011
              • 5
              #46
              Bump to an old thread... The wonders of the internet and google brought me here. First, my hats off to you all for posting the how to and the follow up confirmations of individual successes. It gave me the courage to try.... and fail?
              Bought the part from digikey, soldered it in, and at the post installation test, the clock came on very dimly, and there was a faint smell of smoke. I took the panel apart to find the capacitor top, domed and was very warm Is it possible I got a bad capacitor? I have already risked the thirty for cents on a reorder of the part....
              Thank you!
              • retiredcaps
                • Apr 2010
                • 9271
                Did you put the cap in backwards? Electrolytic caps have polarity (positive and negative). If you put it in backwards, you will hear a pop and the cap will bloat.
                Also, did you order the correct cap in terms of capacitance and voltage rating? Did you check the cap to make sure it is what you ordered?
                While it is possible that you got a bad cap, the two above scenarios are more likely.
                If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
                Subscribe to support us. It only takes 1 minute:
                https://www.badcaps.net/settings/subscriptions
                • CC25
                  • Jun 2011
                  • 5
                  #48
                  Thank you for the reply. I didn't know there was a direction of flow for capacitors. That said, I didn't check that and most likely did not install it correctly. Hopefully, I didn't cook anything else on the board. Based on cap markings, which way is correct? I did get the proper cap.
                  thanks again..
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    See
                    https://www.badcaps.net/forum/showpo...46&postcount=8
                    • CC25
                      • Jun 2011
                      • 5
                      #50
                      Thank you very much. When it comes in in a day or two, I'll have no excuse for failure!
                      • CC25
                        • Jun 2011
                        • 5
                        #51
                        Based on a comparison to the photo on page 1, and the link you posted, the capacitor was installed backwards. My college student son (engineering student) insisted that there was no right or wrong way to do this. I am billing him the 34 cents for this error!!!
                        Ok, so what are my chances of board failure due to this error? did I burn something else out?
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • electronics and DJing/producing music
                          #52
                          Since you said the clock came on dimly and stayed on as the capacitor smoked, your board is fine. Just install a new capacitor in the proper orientation and your clock will be back.
                          A working TV? How boring!
                          • seanc
                            • Nov 2008
                            • 1319
                            • Taking dead stuff apart to learn how it works and fix it
                            #53
                            If that's a picture of your board, it's definitely backwards.
                            • Longbow
                              • Jun 2011
                              • 623
                              • Breaking Things, Losing Parts, Being Ingenious
                              #54
                              Which institution of higher learning does he attend, by the way?
                              Is it plugged in?
                              • CC25
                                • Jun 2011
                                • 5
                                #55
                                Success. Part came today and we're back in action.
                                He's a Case Western Reserve Bio Med student. He did get a "B" in intro to circuits.
                                Thanks all!
                                • guitarman66
                                  • Jul 2011
                                  #56
                                  Originally posted by bluto
                                  I actually fixed this bugger a while ago, but though it would document it now so someone else with the same problem might be able to Google this and save some $. I have a Jenn-Air electric wall oven with all digital controls. At some point the VFD display module began to get dim to the point it was unreadable. Some times it would come back to life but eventually faded out completely. After much teeth gnashing I determined the problem to be a bad capacitor. C3 a 68uf 35v was bad. The was a very small dot of electrolyte on the board below it. I ended up replacing all 4 capacitors on the clock module while I was at it. It has been about 2 years now and it is still going strong. Now I just need to get around to replacing the 2 caps on the power supply/relay board before they roast and burn out the whole works!
                                  The clock module has the following numbers on it: 100-00695-20 CN 7601P483-60. The maytag part number is 71001799. The part costs around $170. May also be used on other Maytag made brands (Maytag, KitchenAid, Amana, Magic Chef, Kenmore, Whirlpool, etc).
                                  Pics attached:
                                  Hi Nice work how did you move the display out of the way to solder the parts? please post pictures....
                                  • bluto
                                    • Oct 2007
                                    • 560
                                    #57
                                    The glass vfd display piece was not an impediment to replacing all 4 capacitors on the board. The capacitors are far enough to the side of the board that they are not covered by the display. Removing the plastic shroud is all that is necessary. I don't really feel like opening up the oven again to take a picture.
                                    • P10292
                                      • Sep 2011
                                      #58
                                      Welcome to the badcaps forums!
                                      I guess I should have put all of that information in my original post. So after one more peek inside the oven, here are the specs and part numbers to order from Digikey. All part numbers listed are for Panasonic FC series capacitors. FM series part number shown in parenthesis where the FC series cap is out of stock at the time of this post.
                                      On the clock module:
                                      C1 & C4 470uF 35v P10301-ND (or the FM series: P12400-ND)
                                      C3 68uF 35v P10292-ND
                                      C7 22uF 50v P10318-ND
                                      On my oven I also replaced the two caps on the power supply/relay board as a precaution. They were as follows:
                                      3300uf 16v P10260-ND [filter cap] (or the FM series: P12373-ND)
                                      47uf 50v P10321-ND [the only other cap on the board]
                                      Question: are FC and FM series interchangeable? it looks like FM series have longer life at 105 degree C. So could I all use FM series instead? (I do notice that ripple current and impedance are different between FC and FM series, does that matter?) Thank you for your help.
                                      • marcottefamily
                                        • May 2011
                                        #59
                                        Hi - I ordered and replaced the caps as instructed. The panel lights up now, but I'm getting a beeping sound with FC displayed. Any advice? Thank you.
                                        • bluto
                                          • Oct 2007
                                          • 560
                                          #60
                                          @P10292: In this case FC and FM should work the same.
                                          @marcottefamily: You should verify that all the connectors were re-installed properly. If it still won't work, post some pictures of both sides of the board for our experts to look at.
                                          • asuwish824
                                            Jenn Air Wall Oven Dim LCD
                                            by asuwish824
                                            I recently purchased a Jenn Air Wall Oven model number jjs2730ws00. It functions properly except that the lcd display is rather dim. No adjustment in the settings seems to improve or even change the dimming/brightness of the display. My hope is I can repair the current display instead of purchasing a new or used unit to replace. I prefer to fix at the lowest point for the joy of the repair. Also throwing out what would otherwise be a perfectly good part just because perhaps a capacitor or other small part is bad seems obviously wasteful. Any guidance would be appreciated.
                                            PS It...
                                            05-18-2022, 10:30 PM
                                          • Fsufan1391
                                            LG Oven model LREL6325F
                                            by Fsufan1391
                                            Hello everyone my oven is less than 2 years old and all of a sudden recently when i run the oven for 15 minutes or so and i am done with it and shut it off. after about 10 minutes it starts chiming and randomly putting it in different modes like the touch screen is being touched but no one is around it. I have tried to reset it by unplugging it multiple times and no luck. I took it apart to see the main board and everything looks fine. I am wondering if i should replace the main board or if its in the control panel. the touch screen is very responsive and works like it should. its only acting...
                                            04-23-2025, 05:42 AM
                                          • Joe24
                                            Maytag Whirlpool Kenmore clothes dryer data bus
                                            by Joe24
                                            Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
                                            Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
                                            I've been over the board looking for...
                                            01-13-2025, 06:50 PM
                                          • bpjl
                                            SEF 551.10 - Error starting the reflow oven.
                                            by bpjl
                                            When starting the SEF 551.10 reflow oven, the following problem occurs:
                                            It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
                                            PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
                                            10-17-2024, 06:30 AM
                                          • KYBOSH
                                            Trying to Revive - Eufy Security Wired Wall Light Cam S100 - No Power
                                            by KYBOSH
                                            This found its way to my workbench this week.
                                            The buyer thought he got a great deal but it turns out it was likely dead and the seller tried to get anything they could for it by passing it off on an unsuspecting buyer.
                                            Rather than tossing it in the bin he gave it to me to play with as he knows how much I love to try to solve problems like these.
                                            The camera portion of this device worked fine when powered via USB but when on the mains it would not work at all.
                                            This reminded me of the eufy floodlight...
                                            09-06-2024, 09:09 PM
