Dim Clock LCD on Jenn-Air wall oven
  • Longbow
    • Jun 2011
    • 623
    • Breaking Things, Losing Parts, Being Ingenious
    #61
    Re: Dim Clock LCD on Jenn-Air wall oven
    The code FC means "communication error between boards". Mostly likely the flexible plastic connector is not plugged in correctly to the timer board, or the wired connector is in the wrong position. Pressing "Cancel/Off" will stop the beeping, but if the error is still present the beeping will continue. Re-check your connectors. The flexible cable is a bit difficult to install.
    Is it plugged in?
    • tshirk
      • Oct 2011
      #62
      My sincere thanks to everyone who posted on this forum. I just repaired my Jenn-Air model SVD48600B stove for essentially 0.34 cents. The stove was experiencing the symptoms of very dim clock and no temperature display. I ordered the capacitors from Digi-Key Corp. (www.digikey.com) on Friday and they were delivered on Monday (today). This was a very easy repair. Though I replaced all four capacitors on the clock control board only the C3 capacitor required replacement. The soldering iron I used was a Black & Decker C1500S dual temp. With it's pencil point this is an ideal circuit board soldering iron. For the money, (less than $20) the Stahl Tools SSVT Variable Temperature Soldering Station is another good choice. Also useful is a desoldering bulb (Model:64-2086 Radio Shack) or desoldering braid to aid removal of circuit board solder holding the capacitors to the board.
      • thebrainfarm
        • Nov 2011
        #63
        Thanks for posting Bluto and Webtalk for your very concise pics.
        I was surprised at how common a problem this is.
        Thankfully I have all of my repair instructions in this forum.
        Love the net!
        • arrowdad
          • Dec 2011
          #64
          I have a JennAir SVE47500 oven. The display is extremely dim for the clock; the temp and other controls don't display at all. I think I need to replace the caps, but when I look at them they look OK. They are not bubbled on the top. Could they still be bad? Attached is a picture of the board, if that is helpful to anyone. Thanks in advance for your help.
          arrowdad
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • electronics and DJing/producing music
            #65
            Yes, they could have dried out without bloating. Replacing them should fix the issue.
            A working TV? How boring!
            • arrowdad
              • Dec 2011
              #66
              Thanks for your quick reply. I will try to get the caps replaced and see what happens.
              • bluto
                • Oct 2007
                • 560
                #67
                On mine the small 68uf was bad only one totally bad (causing the problem). It is so small that it did not bulge. There was a small dot of electrolyte underneath it. I replaced all the other caps at the same time as a precaution. But the path of least resistance would be to just do the one.
                • primeq
                  • Dec 2011
                  #68
                  Originally posted by bluto
                  I actually fixed this bugger a while ago, but though it would document it now so someone else with the same problem might be able to Google this and save some $.
                  Bluto - you saved me $100 (or $170) . Some guy on eBay is offering repair of these units for $100 a pop. Good margin I think.
                  C3 was in fact bad on my board. I never had a 68uF/35V lying around so I tried a 100uF/50V and it works well (fair warning - I tested the 100uF and it measured 100uF, so you mileage may vary).
                  • IthinkIcan
                    • Dec 2011
                    • Fixing it right the first time.
                    #69
                    Another thanks to Bluto for the repair instructions and everyone else’s trials and tribulations. My situation:
                    Jenn-Air JJW9630BAW Double Oven
                    Clock # 71003401 with dim readout (second time in 9 years).
                    C4* 470uF 35v
                    C3 68uF 35v
                    C7 22uF 50v
                    *= No access to C1 soldering points as the display is in the way (possibly guitarman66 comment)…no matter, didn’t need to replace to repair it.
                    I picked up all 3 pieces for $3 at my local electronics store, and ½ hour from shutting off the breaker to turning the breaker back on. I’m uncomfortable with electronics but capable of soldering (I could have just as easily put the cap in backwards like the other guy).
                    You helped save me $150+…THANK YOU!
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      • Linux, hardware, bicycles, pet rats (formerly), did i mention LINUX?
                      #70
                      this thread deserves an award... maybe a sticky?
                      sigpic
                      (Insert witty quote here)
                      • bluto
                        • Oct 2007
                        • 560
                        #71
                        @IthinkIcan: Congratulations on the repair!
                        @primeq: It looks like the ebay repair deal is for an old style mechanical clock wherein the refurbisher procured a quantity of NOS parts to accomplish the repair. Although I have seen some examples of our clocks on ebay that were refurb'd. Or more like fubar'd? There is a picture of one earlier in the thread where the replaced C3 was sticking out like a sore thumb.
                        @RD: Its currently #6 with the most views under "Other Devices". If only Dell W1700 LCD Rev00 were moved to "Computer Displays", I would have a crack at the top spot
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          #72
                          well, so what?
                          thats not what makes the thread notable.
                          what does is the number of people who were not orginally members being helped by it is.
                          Especially considering it is not a device normally thought of as recappible, makes this a rather unique thread. LCD's, yeah, most do need a recap eventually. Wall ovens on the other hand are a tad obscure not what comes to mind as "needs a recap".
                          way to got Bluto for a great thread!
                          sigpic
                          • buni
                            • Dec 2011
                            #73
                            Well, I tried it too -- went ahead and replaced all 4 of the caps --- and now nothing works. (Before, I could at least operate things with the buttons even tho I couldn't see what I was doing.) Who knows what I did wrong - it's my first time trying something like this (tho I am very handy). Maybe I injured the board somehow when I was putting it back together? I dunno.
                            But that said, I wouldn't have been happy replacing the board without trying - so I guess it's all part of the game. Only problem I had is I foolishly attempted the repair while some cookies were "resting" for 2 hours -- and I ended up having to go to a friend's to bake all the cookies.
                            Plan ahea . . .
                            .............d!
                            Thx for your good info - it was, at least interesting, and I learned something even tho my efforts failed. I now know I can replace the board. So -- that's the next task. I'm going to buy a used one off ebay (guaranteed)- $75 -- hopefully it will work. Not sure I'm willing to sink a couple hundred $$ for a new board on an older range. Time will tell.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              1) Caps have polarity (positive and negative). Check to see that you put it in right.
                              2) Check your soldering. Give the caps a gentle tug. They should be held in firmly.
                              3) Post a clear focused picture of your work and maybe we can tell you if the solder is good or not. See my sig file below for instructions.
                              If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
                              Subscribe to support us. It only takes 1 minute:
                              https://www.badcaps.net/settings/subscriptions
                              • BobDel
                                • Jan 2012
                                #75
                                Hi All, great thread, my stove display went dark about 5 years ago and drives me nuts. The caps from DigiKey arrived today and hopefully by tomorrow I will be able to see what my stove is actually doing for the first time in awhile. Thanks for all the info!
                                Bob
                                • bvig
                                  • Jan 2012
                                  #76
                                  Thank you for all the great information in this thread. If you are reading this and afraid to replace the badcap, don't be. You can do it. Just be aware of the positive and negative sides of the caps (see video below)
                                  I moved into a house which had a "Dim display" Jenn-Air double oven model JJW9630AAW.
                                  1. Purchased a cap from Fry's Electronics for replacement of C3 cap. Used 100uF 35v (High Temp) 105 deg.
                                  Mfr: NTE, Model: VHT100M35, FRYS.com #1005393, UPC: 768249103936
                                  2. Purchased solder iron ~$15, 35Watt cheapest version
                                  3. Purchased solder ~$3
                                  4. Turned off power to Oven from breaker panel
                                  5. Removed oven faceplace (see other pictures in previous threads). I took digital picture of board before I did anything (just in case for reference).
                                  6. Used sharpie to mark back side of C3
                                  7. Watched youtube videos
                                  http://www.youtube.com/watch?v=YCSNWi3UHf4 "Cap Replacement"
                                  http://www.youtube.com/watch?v=ieoM_40nRVs "How to solder"
                                  8. Removed bad cap, added new cap w/ negative side matching other caps
                                  9. Bingo, works like a charm
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    • PC's, The Experts Exchange (same name there), Gardening, Hot Rods.
                                    #77
                                    NTE are rebranded generic Chinese junk.
                                    It will last a while but you'll be doing it again.
                                    • BobK
                                      • Feb 2012
                                      • canada
                                      #78
                                      I had the same prob. with my Jenn-air wall mount oven Model # W156.
                                      It has a slightly different PCM board than what has been dicussed here but I thought I'd try to recap it.
                                      The problems were the digital readout was going dim, at times needing a "TAP" to come back on.
                                      Finally the readout went blank and didn't come back on.
                                      here is the oven.
                                      The digital readout after removal from the oven.
                                      The touch screen buttons are connected to the board via this ribbon. It simply pulls out to disconnect.
                                      The date code reads 9223 which equals 1992, week 23 of the year.
                                      Here are my soldering jobs. Except for the 1st cap I replaced(guess which one) The soldering job looks o.k.
                                      I replaced all 5 of the caps that were on the board. The 2 large ones are rated at 105c 1000uf at 35v. the smaller cap by the pins on the right side is 105c, 0.47uf at 50v
                                      2nd of 3 of the 105c,0.47uf, 50v cap
                                      3 of 3 of the 105c,0.47uf, 50v cap on the left and one cap rated at 105c, 47uf at 35v on the right.
                                      Old cap. All 5 had no signs of leakage or bulging.
                                      So I reinstalled everything and it works great!
                                      Total fix cost...$3.23 in caps,$2.80 shipping via the postal service. Got the parts from Digi-Key
                                      www.digikey.com
                                      The cheapest replacement board was $260 and the most expensive was about $360.00
                                      I thought spending $3.23 for caps was worth a try. I had nothing to loose and at the least $257 to gain.
                                      The wife is back in the kitchen where she belongs
                                      I Just want to thank the board for the great info.
                                      Bob.
                                      • olamp
                                        • May 2012
                                        I just did this repair before finding this website. If you look at each cap while it's mounted you will see a heavy black line on the board next to the negative stripe on the cap indicating polarity. Making sure these two indicators match up when installing the new cap makes it goofproof.
                                        • davnjax
                                          • Jul 2012
                                          • 9
                                          • usa
                                          #80
                                          I attempted to replace the C3 capacitor in my jenn air ww27430p double oven. Before I did the "repair", the clock display was visible and I could use the timer and ovens. After my "repair", I get nothing. No display at all and there are no beeps when I try to press the buttons to start an oven. The capacitor I put in was from digikey 68uf 35v. I bought more than one capacitor because my daughter's range has the same problem. I get the same readings with an ohm meter on my board as I get from a capacitor I have not installed. Any suggestions how I trouble shoot this? I was so excited to fix this oven for a reasonable price. I have had a few circuitry classes when I was working on my comp sci degree(years ago, I'm now retired so you know it's been a while) Any suggestions would be greatly appreciated. (I'm new to the forum) Thanks
                                          • asuwish824
                                            Jenn Air Wall Oven Dim LCD
                                            by asuwish824
                                            I recently purchased a Jenn Air Wall Oven model number jjs2730ws00. It functions properly except that the lcd display is rather dim. No adjustment in the settings seems to improve or even change the dimming/brightness of the display. My hope is I can repair the current display instead of purchasing a new or used unit to replace. I prefer to fix at the lowest point for the joy of the repair. Also throwing out what would otherwise be a perfectly good part just because perhaps a capacitor or other small part is bad seems obviously wasteful. Any guidance would be appreciated.
                                            PS It...
                                            05-18-2022, 10:30 PM
                                          • Fsufan1391
                                            LG Oven model LREL6325F
                                            by Fsufan1391
                                            Hello everyone my oven is less than 2 years old and all of a sudden recently when i run the oven for 15 minutes or so and i am done with it and shut it off. after about 10 minutes it starts chiming and randomly putting it in different modes like the touch screen is being touched but no one is around it. I have tried to reset it by unplugging it multiple times and no luck. I took it apart to see the main board and everything looks fine. I am wondering if i should replace the main board or if its in the control panel. the touch screen is very responsive and works like it should. its only acting...
                                            04-23-2025, 05:42 AM
                                          • Joe24
                                            Maytag Whirlpool Kenmore clothes dryer data bus
                                            by Joe24
                                            Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
                                            Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
                                            I've been over the board looking for...
                                            01-13-2025, 06:50 PM
                                          • bpjl
                                            SEF 551.10 - Error starting the reflow oven.
                                            by bpjl
                                            When starting the SEF 551.10 reflow oven, the following problem occurs:
                                            It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
                                            PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
                                            10-17-2024, 06:30 AM
                                          • KYBOSH
                                            Trying to Revive - Eufy Security Wired Wall Light Cam S100 - No Power
                                            by KYBOSH
                                            This found its way to my workbench this week.
                                            The buyer thought he got a great deal but it turns out it was likely dead and the seller tried to get anything they could for it by passing it off on an unsuspecting buyer.
                                            Rather than tossing it in the bin he gave it to me to play with as he knows how much I love to try to solve problems like these.
                                            The camera portion of this device worked fine when powered via USB but when on the mains it would not work at all.
                                            This reminded me of the eufy floodlight...
                                            09-06-2024, 09:09 PM
