Hotpoint FFA47X Fridge Freezer
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Hotpoint FFA47X Fridge Freezer
    Here is something online that may help you in your repair. http://www.appliancerepair.net/refri...-contents.html
    • Rhothgar
      • May 2015
      • 109
      #122
      I've seen that somewhere before. Perhaps on this forum I cannot remember but thanks for bringing it to my attention anyway. Keeps all info in one place if it gets posted as a post in a thread.
      My issues are more fundamental at the moment in that the PCB is not working so I'm a long way off solving this it feels.
      I was wondering yesterday if any wires could have melted near to the PCB slot which accepts the PCB.
      For the life of me I cannot see how to take any of the casings off.
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        Most likely the problem will be on the board as that is more fragile then wire with insulation on it.
        • Rhothgar
          • May 2015
          • 109
          #124
          It's good to know that the wiring may be unaffected but I take it you didn't look back at Post 71 as previously suggested!!!
          • Rhothgar
            • May 2015
            • 109
            #125
            Guys. I've found the technical manual online for the fridge. It's taken a lot of rooting around and I have managed to find a login and password for indecent, ariston, etc. service site.
            However, I do not want to post copyrighted material if it breaks the forum rules.
            What to do?
            Having read through some pertinent pages in the manual, it seems that neither the freezer or fridge air sensors are replaceable. So if I happen to have blown them when the PCB blew up, then I need to end my quest here rather than continue to waste time on it.
            The SMD ceramic resistors, still didn't arrive today, so thank you RS Online for letting me down two days on the trot.
            From the tech manual, I can see that J3 on the PCB receives the information from the 3 sensors. Presumably this is just a case of metering for Ohms here so see if I get a reading that looks relevant?
              • 31249
              pm me the details to get the manual.
              • Rhothgar
                • May 2015
                • 109
                #127
                Just managed to desolder a 103 SMD resistor. It gives 10 Ohms. Shouldn't it be 10,000 Ohms?
                10 x (10*3)?
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #128
                  10 x (10*3)?
                  I thought 103 was 10k ohms?
                  • keeney123
                    Lauren
                    • Sep 2014
                    • 2536
                    10 x (10*3)?
                    Yes it should be 10000 ohms. If this board was made in China they could of gotten it wrong in two ways. They could of mis-marked the resistor and installed them anyway or the resistor is the wrong resistor and it should be a 10K ohm. I have run into this problem with color coding where the resistor color code was different from what the resistor was. The resistor was actually correct but had the wrong code marking.
                    • Rhothgar
                      • May 2015
                      • 109
                      #130
                      The crux of this issue appears to be my measurement instruments.
                      On the board it measured open circuit user Peak Atlas ESR+ 70.
                      Off the board, the Peak states 10.0 whereas my Precision Gold PG017 DMM states OL if set on the 2K scale and 9.96 on the 20K scale.
                      I found an online manual for my multimeter and it doesn't explain the scales but to my mind if it doesn't read on a low scale but does in the high scale then it must be over the lower value.
                      Does anyone have a similar meter and can confirm?
                      The resistor is not 10 x (10*3). The code stands for 10 with 3 zeros after it according to a website alled mds975. After it all it amounts to the same but it is an easier way to think of it.
                      • Behemot
                        • 4845
                        • CZ
                        #131
                        The only theoretical exmplanation I can think of is the resistor has huge parasitic capacity so it lowers the ESR with high-frequency current applied.
                        But as Occams razor dictates, it most likely just measures BS.
                          • 31249
                          that's fine.
                          the peak ESR meter is only designed to read upto a couple of ohms - after that any capacitor is considered totally fucked.
                          the maplin meter is working fine.
                          the resistor is 10k
                          the 20k scale gave you 9.96k which is within the 1% spec.
                          the 2k scale wont work because you cant read a 10k part with the meter set to only read upto 2k
                          btw, i just grabbed the manual - so i'll start reading through it.
                          re-upped for others to read.
                          • Rhothgar
                            • May 2015
                            • 109
                            #133
                            Originally posted by stj
                            that's fine.
                            the resistor is 10k
                            I thought my obs were right but needed reassurance as I am new to all this.
                            That's the correct file that you have 'upped'. I may be worth sequesting to another area of the forum also for future reference and also grabbing all the models it covers - not just FFA47X.
                            Useful resource, eh?
                            Bamboozled by the resistor as it read zero on the board whereas the other 103's read 10,000 Ohms!
                            It's getting swapped out now it is off for a new one this afternoon.
                              • 31249
                              now looking at the wiring diagram,
                              there are 2 thermal fuses - but it does not say if they are self-resetting or if they have a button on them.
                              so check those just incase.
                              and now i know the wiring i'll have another look at the pcb foto's
                              • Rhothgar
                                • May 2015
                                • 109
                                #135
                                No way of checking them. They are sealed in a block but interestingly I get no continuity but not sure which wires to be checking. Two yellow. Two blue. Manual States two yellow two brown I think.
                                Got resistors from RS. The 103's are marked as 1002's so I guess they are the same if you add two zeros into 100 it gives 10000 and they measure 9.96 on 20K scale.
                                • Rhothgar
                                  • May 2015
                                  • 109
                                  #136
                                  Damn!
                                  Just desolder end the one which measured 1000 Ohm on the board and it measures 10000 Ohms off.
                                  So it would seem that the reason the display does not light up anymore is nothing to do with those resistors.
                                  As the triacs were higher rated, are we absolutely 110% sure that they couolld not be causing the display to light up?
                                  I'm at a serious crossroads now. Missus is back off holiday and she's looking to buy a new fridge! Don't know how much longer I can convince her that I can get it working again.
                                    • 31249
                                    triacs are for driving the fan / lights.
                                    that 10k that read 0 on the board - sounds like something in parallel with it may be shorted - follow the tracks and see what's there.
                                      Using ESR meter to check the resistance is not going to work, for example, if there is cap connect in parallel with resistor, what do you think the the ESR meter is going to show?
                                      • Rhothgar
                                        • May 2015
                                        • 109
                                        #139
                                        Absolutely no idea other than not the right figure and that's an educated guess based in the fact that you are highlighting it to me.
                                        I am new to this so I have no idea how I would know if something is in parallel on a PCB.
                                        I assume if in series the components would be on the same track.
                                        • Rhothgar
                                          • May 2015
                                          • 109
                                          #140
                                          If I follow the tracks wouldn't that be in series?
                                          • CG2
                                            Liebherr Fridge Freezer KGT 3456 not working
                                            by CG2
                                            To be a bit more specific, I've got a 20-ish year old Liebherr that has just stopped working. This was quite a sophisticated beast for its time. It's a twin compressor model, and you set the desired temperatures of the fridge and freezer parts from a couple of little control panels above the door. It displays the actual temps on some eight segment displays there, flashing if it's working to get to where you want it. There's a control board with a microprocessor on it that read the temperature from a couple of sensors, switches the compressors on as necessary, and runs the display. There's also...
                                            01-25-2023, 02:12 PM
                                          • mikey5791
                                            Help repair Panasonic fridge not cooling
                                            by mikey5791
                                            Hi all forum members,
                                            Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
                                            After shut off, i dismantle the rear water pan holder and reached to the compressor wiring....
                                            07-16-2025, 02:01 AM
                                          • tmcw
                                            Fridge - Gram
                                            by tmcw
                                            Have this fridge, laboratory grade unit, not working fully.
                                            It's designed with a chilling unit at the top, on the inside, and a fan just below that. When the door is closed, the fan blows the cold air down through the fridge, and when the door opens, the fan switches off, presumably so that it doesn't blow all the cold air out.
                                            The fan isn't switching on, so in addition to not having uniform cold throughout the fridge, the chilling tubes tend to ice up. I took the lid off the top, electronics are in the lid, and when the door is opened and closed, I can hear the relevant...
                                            10-10-2023, 05:00 AM
                                          • unimatrix93
                                            Replacement transformer for Samsung fridge
                                            by unimatrix93
                                            Dear forum
                                            My Samsung fridge died from a fault on the mainline and the transformer (https://www.hqelektronika.hu/hu/halo...-w8-da2600009k) died.
                                            No voltage on the secondary, measuring resistance shows open circuit. I concluded a blown fuse which is deep inside the transformer, I don't think I can disassemble it to replace the fuse.
                                            The second problem is that I cannot find an original replacement part anywhere or even If I do it's pretty expensive.
                                            My question is: Can I replace this transformer with a generic 230V to 17V one? The output has 4...
                                            07-14-2025, 02:16 AM
                                          • lapfix
                                            Dell latitude 5320 South peak 13 not power on.
                                            by lapfix
                                            Hello friends
                                            Got this laptop dell 5320 not power on , just a fast and a dim blink amber light at the power on led indicator.
                                            motherboard south peak 13 mb 213252-1
                                            i'm using schema and Bvd similair to this motherboard. https://www.badcaps.net/forum/troubl...-latitude-5320
                                            i don't have a type-c meter for the moment , so i m taking the voltage using his original charger.
                                            As i undestand from many topic here ,...
                                            04-29-2025, 06:22 AM
