Help repair Panasonic fridge not cooling
  • mikey5791
    • 521
    • Malaysia
    Hi all forum members,
    Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
    After shut off, i dismantle the rear water pan holder and reached to the compressor wiring. Tested the resistance on the 3 connectors, there seems to be resistance of about 10-12 ohms between those 3 connectors.
    Next i went to check components on the power board, no burn mark or anything suspicious visually. I got dc5v at check point J27, dc 12v at J37. Flipping to the rear side of board, when tested D5(mini black diode) on the bottom of relay RY2, i found the resistance reading of 171 on both side. Could this open diode be the cause of compressor not running? Fyi, D6 diode has different resistance reading after flipping my multimeter probes.
    Kindly advise and suggest what are the component testing i can perform to check and bring back life to this old fridge since hiring a technician to repair is not in my budget. I would like to repair this board to good working condition with all your kind assistance and guidance. Thank you in advance.
  • lotas
    • Jan 2016
    • 4854
    • Russia
    Check the capacity of the starting capacitor, check whether the contacts on the compressor relay close when 12v is supplied to the relay.
    • mikey5791
      • 521
      • Malaysia
      The starting capacitor is 4uF 400vac, it is reading about 3.79uF from a capacitor meter.
      Sorry i do not know how to check whether the contacts on the compressor relay close when 12v is supplied to the relay. Is it possible to test it using external 12vdc? Kindly guide on how to check.
      • CapLeaker
        Leaking Member
        • 8351
        Look at the starter cap and the safety relay on the compressor first. To test the windings in the compressor, you really need a Megger, not a DMM. It also needs a resistance measurement, not on diode or continuity mode if you are already using a DMM. The winding should not be open, and should not be shorted to case gnd.
        If you find a diode across a relay coil like D5 annd D6 and reads funny, well you are reading the coil, not the diode. It is actually there to protect the coil drive from EMF.
        If you do find something fishy in circuit, always lift a leg or take the component out and check again.
        • lotas
          • Jan 2016
          • 4854
          • Russia
          Yes, you can check the relay without unsoldering it from the board. Apply a voltage of 10-12v to these terminals with a small current, OBSERVING POLARITY!, just don’t mix them up!, and use a multimeter to check the continuity of the closing contacts.
          • CapLeaker
            Leaking Member
            • 8351
            Google “compressor start relay” and there are plenty vids to show you.
            • redwire
              • 3912
              It might not be the control board or the compressor starter.
              Happens to me- Whirlpool refrigerator freezer door not fully closed and compressor is running constantly, food inside thaws out.
              I'll find the freezer evaporator covered in ice. So it takes a day to thaw out using a small fan blowing in. Lots of water mess. Cheap Whirlpool can't add an alarm beeper, AND it has 40W light bulb to add heat lol.
              My point is the ice can trash the temperature sensor or its wiring. If it goes open-circuit or high resistance, the fridge can think the freezer is plenty cold and not run.
              My friend, he always puts food in his fridge freezer and hits the sensor and wiring and unplugs it or it is hanging in the air.
              Check the evaporator temperature sensor and it's wiring/connector. It might be located on the tubing. The defrost heater is also there.
              I'm not sure where the freezer temperature sensor is, or maybe there is just the one thermistor.
              • mikey5791
                • 521
                • Malaysia
                I applied dc12v(300ma),negative to terminal with diode image and positive to terminal near D5 marking. Immediately i can hear the relay one click sound.
                But you mentioned about checking the continuity of the closing contacts, is it the opposite two separate terminals(near RY2 marking)? I didn't get any continuity from the two contacts as per your picture.
                • lotas
                  • Jan 2016
                  • 4854
                  • Russia
                  Well, if when power is supplied to the relay it operates, but its contacts do not close (the contacts are burnt), replace the relay with a new one.
                  To check if the compressor is working, temporarily install a jumper for testing, and when the mains power is supplied, the compressor should start immediately.
                  • mikey5791
                    • 521
                    • Malaysia
                    Hi lotas,
                    Thank you for your kind assistance and guidance. I will order the needed relay. Fyi, i did installed a jumper for testing and the compressor starts and running. Running it for an hour, the half glass water become semi solid ice. After that i shut it off.
                    Will update this forum soon after installing the new relay.
                    Once again, thank you to those forum members who had contributed with helpful comments.
                    • CapLeaker
                      Leaking Member
                      • 8351
                      Take the relay out of circuit and test it again, just to be sure.
                      • mikey5791
                        • 521
                        • Malaysia
                        Hi to all forum members,
                        Yesterday i received the new relay from our local online store and installed on the fridge pcb at RY2.
                        The fridge has been working normal again since last night. The freezer compartment has ice cube solid frozen this morning and the fruit compartment is cooling too.
                        Hope this fridge will work for many years to come.
                        Cheers to everyone who had contributed their kind assistance and patience to help me revive this old fridge to working condition.
                        • Th3_uN1Qu3
                          Cooling upgrade on refrigerator. If it works, it ain't stupid!
                          by Th3_uN1Qu3
                          I had this refrigerator at my old folks which I noticed I would put my beer or soda in and take it out warmer than I'd brought it from the store.
                          Now, I don't know much about refrigerators or HVAC but to me it seemed like we have a problem. I threw a thermometer in... 20 deg C in the fridge. WHAT THE... Freezer worked fine with temperatures way below zero, as it should, and it has only one compressor for both sides so it got me scratching my head for a while.
                          Only other things that seemed a bit odd was that the heatsink on the back was barely warm and the...
                          09-03-2023, 06:29 AM
                        • Liam.25
                          Beko fridge compressor clicking
                          by Liam.25
                          our fridge and freezer stopped cooling last weekend, it’s a Beko fridge.
                          looking at the bottom, I can hear the relay clicking on the plug attached to the compressor.
                          There is also a 3uf capacitor, I’m thinking this is a run capacitor, I tested this with my fluke and and it measured at 1.5uf, so I replaced this (new one tested just over 3uf) so that’s where it should be.
                          I was thinking this was the issue. The compressor seem to run for like a minute then shutoff again.
                          inside the relay, there is a Klixon 4tm thermistor,...
                          03-23-2024, 07:42 AM
                        • mon2
                          bad linear compressor on my LG fridge
                          by mon2
                          Singing the blues with a bad linear compressor on my LG fridge so the house is in turmoil. LG was apparently sued over the '10 year warranty' that we fell for as the best in the market but then they want to charge (locally) ~$700 CAD to install the new 'under warranty' compressor. After major complaining about ethics, they may be granting us a service favor @ ~$250 (CAD) for the same service. Spoiled food and no fridge. Fun times.
                          12-29-2021, 09:28 PM
                        • BigPete
                          Panasonic Heatpump Dryer Repair
                          by BigPete
                          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                          Unfortunately the whole machine has to come apart to fix it.
                          I have...
                          11-01-2025, 06:40 PM
                        • Ace Perception
                          Samsung R530 Bremen motherboard cooling
                          by Ace Perception
                          I'm wondering if anybody out there has much knowledge of Samsung Bremen motherboards.
                          I've got a Samsung R530 which is about 10 years old, over the last 12 months it developed a worsening problem where when asked to do much work it would shut itself down. I had a good idea this was due to overheating which was confirmed by a temperature monitor programme which showed little balls of fire next to the various internal temperature readings. I could also prevent it shutting down if I placed a huge fan running at full speed in front of its air intake!
                          So I went in pursuit of...
                          07-21-2020, 03:05 PM
