UPS and inverter questions
  • starfury1
    • May 2006
    • 1256
    #121
    Re: UPS and inverter questions
    if you are intending to put this thing into service..yeah new batteries wouldn't go astray.
    Id make sure its charging correctly .....stating the obvious they say
    good luck with it and keep us posted andrew77
    (wish I could have been of more help)
    Cheers all
    • andrew77
      • Jan 2008
      • 81
      #122
      Well, I guess the charging circuit is working normally. When I first plugged in the UPS the current across F1 started at 330mA and gradually went down to 3mA. When I turned on the power it went up to 100mA and then it started it's self diagnostics on the inverter. It was 300mA on the inverter and when it went to normal operation it was at 600mA and gradually went back down to 4mA.
      So the battery is probably just showing it's age after being out of use for a year.
      Apparently the microcontroller does some kind of test on the battery because I was seeing the current reverse every few seconds.
      The microcontroller seems to be pretty powerful for being used like it is. It's ST72F324J6T5 datasheet. 8-bit, 32K of flash for program storage, 1K of RAM, 4 timers, 10-bit ADC, ...etc.
      I guess I'll just run these batteries till they die, new replacements looked to be about $40 with shipping included.
      I know Davmax gave me some pointers on the parts, but I'm still having problems. Do you have some more suggestions about a good place to get all the parts I need, so I don't have to order from all over the place? I'm thinking about replacing all of the MOSFET's on the broken UPS and have enough spares left to do it again if needed.
      STP19NB20 is supposed to be a direct fit, I guess. IRF540NSTRL is another equivalent and this one has to be D2PAK. The last one I'm not sure about, but I saw this one mentioned on a Russian forum IRFZ44N .
      I think that just about covers it for now.
      • davmax
        • Dec 2005
        • 899
        #123
        Andrew, You talk of replacing all MOSFETs. Really all?
        that is 11 MOSFETs I believe. Please confirm.
        160Gb WD SATAII Server grade
        Nvidia 8500GT 256Mb
        Samsung 18x DVD writer
        33 way card reader
        Windows XP Pro SP3
        17" Benq FP737s LCD monitor
        • andrew77
          • Jan 2008
          • 81
          #124
          That's my plan.
          But, only on the one that is missing parts at the moment.
          • davmax
            • Dec 2005
            • 899
            #125
            Right I have great replacements for you . All at Mouser.com
            94-2358 replace with FQB33N10TM @ 99c ea (D2PAK)
            IRF3205 replace with NTE2991 @ $4.51 ea (TO220)
            IRF630 replace with FQP32N20C @ $1.70 ea (TO220)
            Note that IRF540NL (94-2358) is not logic level gate.
            When searching at Mouser or DigiKey use format
            MOSFET 100V 33A
            to bring up required devices
            Nvidia 8500GT 256Mb
            33 way card reader
            Windows XP Pro SP3
            • andrew77
              • Jan 2008
              • 81
              #126
              MOSFET 100V 33A
              Thank you! That's exactly what I was looking for.
              • davmax
                • Dec 2005
                • 899
                #127
                On further consideration replace 94-2358 with FQB33N10LTM a logic level gate device. This is because we are not too certain about the original device and a logic level device will make absolutely sure all possibilities are covered.
                Nvidia 8500GT 256Mb
                33 way card reader
                Windows XP Pro SP3
                • aquaman8
                  • Jan 2011
                  • 6
                  #128
                  I know that it has been a while, but just wondering if the photos and attachments from this thread are available somewhere, as they don't come up when I read the thread? Reference to photos, drawings and attachments, but no images!
                  I am in process of repairing the same unit and the photos and schematics would be very very useful!
                  Thanks,
                  Mitch
                  • sengh
                    • May 2011
                    #129
                    hello ,
                    I ve an APC RT 10000 , it display "" Internal Fault ""
                    What is the solution for this problem ,
                    • cb92
                      • Jul 2008
                      • 174
                      Welcome, Aquaman and Seng, to the site most likely to help you repair your units. I've looked a lot elsewhere, this is the best.
                      Nontheless, UPS repair is a real tough one. I have gotten lucky a couple of times finding a loose connection on a battery, and a blown diode on another unit. Blown diodes are easy, they split down the middle! Everything else hides.....
                      There are some APC schematics available, but little else. The manufacturers don't want these units fixed, they want to sell new ones. As far as I'm concerned, anything below 500 watts is disposable. I'll look at one for an easy fix, but will not waste time on a small unit.
                      Personally, I would love to find a shop manual for some units, especially APC, which is the most common one I see. I'm expecting a shop manual to direct the repairman to the most likely parts to go bad, give clues, etc. It would be absolutely super if there were a diagnostic program and a serial hookup to a computer!
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        #131
                        sengh: Oh wow, that's a really nice UPS!
                        Tell you what, create a new dedicated thread for it.
                        And Welcome to Badcaps
                        btw, we wont be able to help much without some internal pictures and a longer description, what happened, did it work before etc?
                        Oh, and be sure to be very careful when doing the disassembly, those batteries contain a very big charge and could damage the UPS if shorted (or kill you for that matter)
                        • sengh
                          • May 2011
                          #132
                          yes it works before ( 9 month ) and stop and display " internal fault'
                          • chhoton
                            • Jun 2011
                            #133
                            In One SUKAM Falcon i Home UPS, the problem is that when I select the UPS mode, the inverter runs ok but when the mains AC supply comes back, the inverter does not run on MAINS, and it continues to run in inverters. plz help me out. I am a newbie here.........
                            thanks in advance
                            • Tariq4402
                              • Apr 2014
                              • Pakistan
                              #134
                              Thanks for all
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                thanks in advance
                                Hi, please create a new dedicated thread for your problems.
                                However, maybe this is helpful:
                                One of my three cyberpower ups's was suddently not noticing it was being plugged in. It would always run on battery. I realized it has a little red button on the back. Pressed it, and now it's fine. Might want to check if yours has this feature too!
                                  That is the push to reset Thremal circuit breaker for the Main AC input.
                                  • bandici
                                    • Aug 2014
                                    • ro
                                    #137
                                    hi
                                    please help me with a APC Smart UPS 750 or 500 schematic!
                                    thanks
                                    • cb92
                                      • Jul 2008
                                      • 174
                                      The Rooskies have schematics, just Google your item.This is an example, I think it's the 500 Smart UPS.
                                      • BurnInMyLight
                                        • Feb 2021
                                        • Italia
                                        #139
                                        MOSFET 100V 33A
                                        Hello, I replaced the 94-2358 with the FQB33N10TM and doesn't work.
                                        I have to search another problem or may be is not compatible this Mosfet? I bought 2 from a Chinese shop, so may be these are poor quality but i tested 2.
                                        FQB33N10TM has worked to someone instead of 94-2358?
                                        Thanks for reply
                                        • eccerr0r
                                          inverter H tree driver imbalance in an AC inverter
                                          by eccerr0r
                                          My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                                          Today, 12:34 PM
                                        • x_orange90_x
                                          Vizio E55-E1 bad backlights or bad inverter?
                                          by x_orange90_x
                                          I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                          I don't know how exactly to test the inverter itself. Is it...
                                          01-29-2025, 09:24 PM
                                        • Gentian
                                          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                          by Gentian
                                          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                          03-06-2023, 07:07 AM
                                        • valvashon
                                          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                          by valvashon
                                          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                          01-04-2024, 01:44 PM
                                        • eccerr0r
                                          A modified sine wave inverter + a grid tie inverter?
                                          by eccerr0r
                                          If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                          Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                          08-31-2023, 09:14 PM
