Help needed getting an ESR meter...
    • 31087
    Re: Help needed getting an ESR meter...
    most suppliers sell them, but not with prices that can compete with ebay.
      https://www.badcaps.net/forum/showpo...1&postcount=14
      See page 13 of the PDF on the rotary encoder.
      • SteveNielsen
        Retired Tech
        • Jun 2012
        • 2327
        Oh! (light bulb flickers on above head) I know what one is now. They are on some a/v editing gear for scrolling fwd/rev for example but I never realized how they worked.
        • awyatt2
          • Feb 2012
          • 407
          • america
          #44
          I have the peak esr60 and 70. the 60 is the stby for the 70. never had either to lie in or out of circuit, maybe can happen but hasn't on any radio or tv I have used it on. I work on amateur radios as well and it just doesn't lie.
          • Heihachi_73
            • Jun 2012
            • 713
            I got my ESR70 from eBay for $130 (AUD, which would be a lot more now since the USD has since risen from its low point, and I'm sure Mr. Abbott helped make the AUD plunge all by himself), bought brand new from US seller despite the devices being made in the UK.
              • 31087
              Originally posted by csh
              Nice.
              I got this one a couple of days ago:
              www.ebay.com/itm/251563800953
              For me as an amateur and hobbyist it will do.
              Seems to be working, i tested a couple of known good/bad caps and the results are ok. Even found some caps to be bad that i was not planning to replace
              Is any calibration on this things needed?
              How do you get this menu for special functions like frequency generator?
              Nice job with the acrylic shield btw
              so you have a T3 or T4.
              found some stuff for that.
              • csh
                • Mar 2015
                • 38
                • Croatia
                #47
                That's the one. No any markings or logo ond the PCB.
                Found some links in this thread:
                http://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/
                All models (link can be found in the forum above):
                https://yadi.sk/d/yW8xa5NJgUo5z
                Youtube:
                https://www.youtube.com/watch?v=GfJizkJB21M
                Unfortunately, have no time to fiddle with this tester
                What interface is needed to upload firmware into this?
                  • 31087
                  AVR programmer - preferably a chinese USBasp
                  http://www.ebay.co.uk/itm/261574745774
                  you will need to make a cable for the tester,
                  asp is 10pin, the tester is 6 and there is a second problem.
                  the T4 tester has the display right behind the pcb, so you need to lift the display a bit for safety before trying to solder to the board.
                  if it was me, i would get a right-angle 6pin connector or pinstrips, and cut them so they will be flush on the board, then lift the display and solder the pins.
                  then put the display back.
                  • Joe Black
                    eager to learn
                    • Sep 2015
                    • 173
                    • southeastern europe
                    #49
                    Finally arrived
                    http://www.ebay.co.uk/itm/2015-newes...item27fb7e75f0
                    But I can't understand one part:
                    optional resistance and zero offset calibration of measuring equipment self-test capability of the port output (ATmega168 and ATmega328). Need a 100nF to 20uF capacitor connected to compensate the analog comparator between pins 1 and 3 of the offset voltage. This can reduce the measurement error 40uF above capacitor. With the same internal calibration capacitor voltage reference voltage is found to internal adjustment reference measurement ADC gain.
                    Help please
                    stay classy
                    • csh
                      • Mar 2015
                      • 38
                      • Croatia
                      #50
                      Looks interesting. Any pictures of the bottom side, what are those white plastic pins?
                        • 31087
                        what are you refering to? the esr meter?
                        the display has plastic locating pins going through the board that are melted-flat on the underside.
                          • 31087
                          Originally posted by Joe Black
                          Finally arrived
                          Help please
                          you can probably ignore that.
                          if you want to recalibrate it, link all 3 wires together and push the button.
                          it will tell you when to put the cap in and when to remove it.
                          • csh
                            • Mar 2015
                            • 38
                            • Croatia
                            #53
                            This marked in red rectangles on the attached pic.
                              • 31087
                              pcb standoff's
                              either there is something on the other side, or they have been fitted to raise the components off the table.
                              btw, it looks like a flexable design - i bet a rotary encoder would be easy to fit.
                              • Joe Black
                                eager to learn
                                • Sep 2015
                                • 173
                                #55
                                pcb standoff's
                                Exactly. Just plastic pins to raise PCB of the table.
                                I bet it would (for you, of course )
                                stay classy
                                  • 31087
                                  removing the button, 4 pins.
                                  fitting the encoder, bending up one extra pin, cutting 2 tracks - maybe.
                                  other than that - it fits directly onto the same footprint.
                                  here's one.
                                  http://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/msg690137/?#msg690137
                                  • goodpsusearch
                                    • Oct 2009
                                    • 2850
                                    • Greece
                                    #57
                                    Something went wrong.
                                    I ordered this:
                                    http://www.ebay.com/itm/181861030068
                                    I've seen the following pic showing that the Test Clips are not included and was going to buy them separately...
                                    https://www.badcaps.net/forum/attach...1&d=1446559550
                                    I could get them from here for example:
                                    http://www.ebay.com/itm/5-Pcs-5-Colo...item419a26c354
                                    I got it yesterday. Turns out that the whole cable and the 3 pin plug were not included. I don't know how to search for it, is it proprietary plug?
                                    Right now the only thing I could do is order the mini clips and then solder the cables direct on PCB.
                                    If anyone knows where to buy it, please reply.
                                    • SteveNielsen
                                      Retired Tech
                                      • Jun 2012
                                      • 2327
                                      The one I got is exactly the same but came with the connector and three leads but no clips. I got it here:
                                      http://www.aliexpress.com/snapshot/6...69560471073177
                                      I don't know what the exact spec is on the white connector but it looks like some I've seen for fans on video cards. The plug tends to work loose a little in handling but not a big deal.
                                        • 31087
                                        T-happy probably made a mistake, i got one from them with the cable included in the packet.
                                        contact them - they will probably send you the cable to keep good feedback.
                                          • 31087
                                          cheaper clips - where i got mine
                                          http://www.ebay.com/itm/371193424125
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • Stephan Mathers
                                            EDMI ATLAS MK10 Electronic Meter Discussion
                                            by Stephan Mathers
                                            Greetings, new guy here but always interested in the crazy universe of modding
                                            We just finished construction of around 25 vacation houses, all inside the same private area.
                                            Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                                            The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                                            Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                                            05-20-2025, 09:09 AM
                                            Bought a volt multi meter that is capable of data logging Hantek 365C USB/Bluetooth Data Logger
                                            I have had this in my wish list for quite a while now and I might need to test BMS protection board with this device because of the limitations of the battery testing machine that I have been using
                                            https://www.aliexpress.us/item/32568...yAdapt=glo2usa
                                            What this will allow me to do is use my load testing machine that is having issues with the voltage cutoff set/ current meter monitoring system and I decided not to try to replace it or repair it I just going to use a very primitive load testing...
                                            03-30-2025, 11:05 AM
