Help needed getting an ESR meter...
    • 31077
    Re: Help needed getting an ESR meter...
    Originally posted by Andrew F. Ali
    I purchased the Bob Parker 'BLUE ESR Meter' from Alltronics LLC/Ana Tek Instruments earlier this year. I am very happy with its performance and accuracy. Yes, you can test caps in-circuit, though I prefer to test out-circuit, with accurate results. One of the best pieces of test equipment I own now. My repair success rate has increased since caps that would give good uF test readings CAN give bad ESR readings, causing circuit malfunction.
    you could still get caught.
    my new tester gives me capacitance, ESR, and Vloss (leakage)
    i'v found a number of used caps in my stash with good capacitance and ESR, but high Vloss.
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      Originally posted by stj
      Seller's 4th pic shows a three headed test probe noted as Not Included
      Do you know if that's a standard item ?
      And if so, where to get it / what to search for ?
      better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
        • 31077
        the cable is included, the test-clips on the end arent.
        test clips
        http://www.ebay.co.uk/itm/371193424125
        hell that seller has everything imaginable!
        http://stores.ebay.co.uk/t-happy?
        • csh
          • Mar 2015
          • 38
          • Croatia
          Originally posted by Joe Black
          OK, deffo getting some el-cheapo from Ebay.
          If it's good for stj and csh (*waves to neighbour*) it's more than good for me.
          I bought this one because of ZIF socket.
          If desoldered cap has really short leads you have to hold it on the contacts for SMD elements. Kinda pain in the ass to work with.
          Interesting.
          Was checking some datasheets, is vloss the same as "Dissipation factor"?
          I see some models have leads with hooks. Would that help with measuring desoldered caps with short legs?
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            @stj: Do you have schematics/info for the rotary selector and/or zener testing?
              • 31077
              rotary encoder schem is in the pdf, it also needs 4 resistors.
              the zener circuit is on the forum i think was linked in a previous thread.
              or a seperate one i posted about in a previous thread that works with your multimeter.
                • 31077
                Interesting.
                they dont come wih the hooks - only the wires.
                it's more usefull with big transistors & stuff, but you could use it for caps.
                keep in mind the cable length may effect the esr reading.
                • SteveNielsen
                  Retired Tech
                  • Jun 2012
                  • 2327
                  Ok, I see that, thanks. I guess I don't understand what a rotary encoder actually is. Some kind of dual-pole switch with a knob? I'm sure I must have seen one on something or somewhere and didn't pay attention but I'm in dense-mode and drawing a blank here... getting older sucks.
                  Ok, let me re-ask, what TYPE of rotary encoder will work?
                    • 31077
                    rotary encoder looks like a pot but goes 360' and often clicks as you turn it.
                    it has a pair of switch contacts in it.
                    the good ones also have a switch in them that is under the shaft so you push the knob to "select" stuff.
                    • SteveNielsen
                      Retired Tech
                      • Jun 2012
                      • 2327
                      Thanks. I guess the question should be can you give me an example of one I can get that would work with the tester when I get it?
                        • 31077
                        they arent cheap, half the cost of the tester for a cheap one.
                        atleast from suppliers - i have not checked ebay. (yet)
                        • ivtec
                          • Dec 2008
                          • 1967
                          I use this one and it's pretty good.
                          https://www.youtube.com/watch?v=Rkzj9Z4GQ7c
                            Rotary Encoder.
                            • SteveNielsen
                              Retired Tech
                              • Jun 2012
                              • 2327
                              Thank you. Wouldn't a DPST momentary-on pushbutton switch do the same thing?
                                • 31077
                                no.
                                i found this:
                                http://www.ebay.co.uk/itm/231241921964
                                will order one and see how well it fits - and if it's enabled in the firmware!
                                • SteveNielsen
                                  Retired Tech
                                  • Jun 2012
                                  • 2327
                                  Ok, so it's not a passive device then. There isn't a lot of explanation that I can find online as to how such a device actually works. I am left to assume it produces some sort of timed logic pulses?
                                  BTW, the part you linked to does not ship to the US.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    #37
                                    once stj has verified its in the firmware etc i bet a few of us will do the mod if stj gets it working and dosntmind posting pics and how to do the mod.I need to learn how to use my old tester first better yes im fine on testing capacitors and resistors but when it comes to testing transitors etc im still learning what a good or bad reading should be.
                                      • 31077
                                      it's a passive device, but it's not a case of up / down contacts.
                                      the contacts switch in order based on the direction you spin it.
                                      as for ebay, search the part "ec11 a617" there are a number of sellers.
                                      there are cheaper ones sold in 5's but they look like shit.
                                      here:
                                      http://www.ebay.com/itm/181361695762
                                        • 31077
                                        btw, it just dawned on me you can find a rotary encoder in a mouse wheel - although not the type for fitting to the board.
                                          Digikey sells them.
                                          http://www.digikey.com/product-searc...coders/1966131
                                          http://www.digikey.com/product-searc...=0&pageSize=25
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • Stephan Mathers
                                            EDMI ATLAS MK10 Electronic Meter Discussion
                                            by Stephan Mathers
                                            Greetings, new guy here but always interested in the crazy universe of modding
                                            We just finished construction of around 25 vacation houses, all inside the same private area.
                                            Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                                            The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                                            Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                                            05-20-2025, 09:09 AM
                                            Bought a volt multi meter that is capable of data logging Hantek 365C USB/Bluetooth Data Logger
                                            I have had this in my wish list for quite a while now and I might need to test BMS protection board with this device because of the limitations of the battery testing machine that I have been using
                                            https://www.aliexpress.us/item/32568...yAdapt=glo2usa
                                            What this will allow me to do is use my load testing machine that is having issues with the voltage cutoff set/ current meter monitoring system and I decided not to try to replace it or repair it I just going to use a very primitive load testing...
                                            03-30-2025, 11:05 AM
