Help needed getting an ESR meter...
    • 31183
    Re: Help needed getting an ESR meter...
    http://www.ebay.co.uk/itm/401011373901
    • Behemot
      • 4845
      • CZ
      #82
      Still does not make it any good measuring in curcuit, which means its utter useless.
      • SgtRock
        • Feb 2012
        • 175
        Dear Joe:
        --I use a kit built and modified Bob Parker blue. Mine is modified to accept standard 5mm Fluke Type test leads. I am also able to connect an SMD tweezer which can be helpful at times. The Bob Parker Blue is very accurate as opposed to the $15 HK cheapie, which oddly enough is very accurate for capacitance.
        --Measuring ESR in circuit, as with measuring resistance in circuit, is sometimes determinative and sometimes not, on a case by case basis. See pics.
        Cheers!
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          For the AVR tester use of the menu can get you to this...
          "C+ESR@TP1:3 The additional function ”C+ESR@TP1:3” selects a stand-alone capacity mea-
          surement with ESR (Equivalent Series Resistance) measurement at the test pins TP1 and
          TP3. Capacities from 2 μF up to 50 mF can be measured. Because the measurement volt-
          age is only about 300 mV , in most cases the capacitor can be measured ”in circuit” without
          previous disassembling."
          It really depends on the circuit the cap is part of.
          • Behemot
            • 4845
            • CZ
            #85
            Yes because it uses different measurement method.
            ESR Micro, originally based on the Blue meter as well, uses short pulses thus inductors don't affect it at all. The only disadvantage is - because of how it also measures capacitance - that small caps (10 uF and less) show higher capacity, about 10 % or so. Also when reading small capacities in curcuit, especially things like display signal boards, you should take into consideration all the ceramic caps in parallel can achieve capacities of tens or even hundres uF in there. While when measuring VRM, 100 uF under CPU socket does not affect those 10 mF at all…
            BTW I have the feeling Mikhail has lowered his prices, at least in roubles though. So if I finally get response from him, I should have it even cheaper next time. Especially when I'd like to get rather big batch next time. I think 70 USD incl. shipping is possible (at the moment 89.99 on Bonanza but there are fees included)…so it will be half the price of Atlas for the same functionality, with somewhat wider range of both ESR and capacity.
            Also his version of that german meter went down as well, I think about 30 bucks may be possible as well.
            • SteveNielsen
              Retired Tech
              • Jun 2012
              • 2327
              I wonder what sequence is used for determining what the part is when in default mode? I've seen caps test as one or more diodes in circuit and out of circuit they test fine. Could that be because the tester sensed diodes in circuit first?
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                #87
                is there any instructions how to get into this menu setting?
                • Behemot
                  • 4845
                  • CZ
                  #88
                  Yes. Unless somebody adds function selector, the device is very limited in use. It will still be somewhat limited because of measuring technique (I think it uses frequency current?), but it still could somewhat compete with many lower-priced LCR metres as those are even much worse.
                  Now it just can not and specialized metres are always better. Or for some 50 % more than Atlas you can get Applent device which is in different league (high-res touchscreen, very wide ranges, integrated memory and USB connectivity).
                  • SteveNielsen
                    Retired Tech
                    • Jun 2012
                    • 2327
                    Yes, in the documentation (attached).
                    3.2
                    Optional menu functions for the ATmega328
                    If the menu function is selected, the tester start a selection menu after a long key press (>500ms)
                    for additional functions. This function is also available for other processors with at least 32K flash
                    memory. The selectable functions are shown in row two of a 2-line display or as marked function
                    in row 3 of a 4-line display. The previous and next function is also shown in row 2 and 4 of the
                    display in this case. After a longer wait time without any interaction the program leave the menu
                    and returns to the normal transistor tester function. With a short key press the next selection can
                    be shown. A longer key press starts the shown or marked function. After showing the last function
                    ”switch off”, the first function will be shown next.
                    If your tester has also the rotary pulse encoder installed, you can call the menu with the additional
                    functions also with a fast rotation of the encoder during the result of a previous test is shown. The
                    menu functions can be selected with slow rotation of the encoder in every direction. Starting of the
                    selected menu function can only be done with a key press. Within a selected function parameters
                    can be selected with slow rotation of the encoder. A fast rotarion of the encoder will return to the
                    selection menu.
                    • SteveNielsen
                      Retired Tech
                      • Jun 2012
                      • 2327
                      Rotary selector is not necessary to get and use the menu, it makes it easier though.
                      A specialized meter should do a better job I would think in general. For the price the AVR testers are pretty damn cool.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #91
                        3.2
                        selection menu.
                        Thanks for the information.
                        • Behemot
                          • 4845
                          • CZ
                          #92
                          Yes because that guy made it open-source so every last chinese fool just hammers that in a garage. I would never buy those cheap craps. As I said, some of the better ones may be usefull for some things, but a combination of ESR Micro and digital multimeter makes its use limited to some induction measurements and very small caps measurement. Everything else is just redundant for me or does not work the way I would like to.
                          Now if somebody took the design and made it a proper meter, either multifunction or even cut the unneccessary crap and make it proper LCR, that would be fine. But there is nobody there either capable or at least willing of modifying both the software and the HW, they just all copy that like monkeys. It's laughable…
                          That thing you described is like building a rocket! All I want is to press once for L, press twice for R, press tripple for C. Not some crazy shit…I think paying even twice the price for a device which has interface for normal people and not crazy nerds (no offense) is still damn worth it.
                          • SteveNielsen
                            Retired Tech
                            • Jun 2012
                            • 2327
                            I suppose if you had no interest in it then you likely wouldn't know if there was anyone working on improving it or not.
                              • 31183
                              shows how much you know,
                              one of the main contributors on the german forum is one of those "monkeys".
                              he goes by the name of Zhq.
                              • Behemot
                                • 4845
                                • CZ
                                #95
                                Haven't gone far I suppose so I don't really care. This thing exists for how long, maybe a decade now? It's falling so hard against proprietary chinese metres…I would pay for Applent AT825 any day of the week over this.
                                • SteveNielsen
                                  Retired Tech
                                  • Jun 2012
                                  • 2327
                                  That's fine for you, it's your choice. It's also your choice to cop a snobby attitude about it. It's a good choice for some people. The whole gamut of experience runs among the members here.
                                  • goodpsusearch
                                    • Oct 2009
                                    • 2850
                                    • Greece
                                    #97
                                    Originally posted by goodpsusearch
                                    My response:
                                    Hello. I saw the picture and only the BATTERY and the CLIPS were stated as NOT INCLUDED. The rest of the cable should have been in package.
                                    The tester doesn't work as stated because I cannot connect to it any CLIPS or PROBES. Please tell me how I am going to do in circuit testing when I cannot connect probes to that 3 pin plug, because I don't have any cable to match THE PLUG!!!!
                                    Please refund or send me the cable that I show in BLACK CIRCLE: https://www.dropbox.com/s/foq15zsdoa...20see.jpg?dl=0
                                    Very disappointed with not honest treatment.
                                    His reply:
                                    HOW ABOUT SENT YOU AGIAN TEST CABLE .IS THAT OK ?
                                    Originally posted by lookimback
                                    I think he's offering to send you the cables.
                                    Today I received the cable! It came with test clips attached too! I am satisfied
                                    • SteveNielsen
                                      Retired Tech
                                      • Jun 2012
                                      • 2327
                                      Cool!
                                      • Behemot
                                        • 4845
                                        • CZ
                                        #99
                                        …meanwhile, Behemot dropped the price of ESR Micro v4.0si to 79.99@Bonanza or about 70 bucks direct, incl. shipping and 2y warranty…
                                        • goodpsusearch
                                          • Oct 2009
                                          • 2850
                                          • Greece
                                          #100
                                          70 euros?
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • Stephan Mathers
                                            EDMI ATLAS MK10 Electronic Meter Discussion
                                            by Stephan Mathers
                                            Greetings, new guy here but always interested in the crazy universe of modding
                                            We just finished construction of around 25 vacation houses, all inside the same private area.
                                            Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                                            The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                                            Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                                            05-20-2025, 09:09 AM
                                            Bought a volt multi meter that is capable of data logging Hantek 365C USB/Bluetooth Data Logger
                                            I have had this in my wish list for quite a while now and I might need to test BMS protection board with this device because of the limitations of the battery testing machine that I have been using
                                            https://www.aliexpress.us/item/32568...yAdapt=glo2usa
                                            What this will allow me to do is use my load testing machine that is having issues with the voltage cutoff set/ current meter monitoring system and I decided not to try to replace it or repair it I just going to use a very primitive load testing...
                                            03-30-2025, 11:05 AM
