what is the correct way solder a coin battery?
  • theOracle
    • Nov 2012
    • 163
    I sometimes encounter laptop batteries that use coin type batteries, and the full part with connectors is no longer manufactured, and I need to replace the battery, and the actual battery portion is an easily available type. So I want to reuse the original connector and wires, or else use a well made battery holder.
    So if I was going to reuse the original connector and wires, what is the trick to soldering wires to a coin type battery, without damaging the battery and also getting a strong physical connection so that the wires will not fall off of the coin battery?
    or perhaps a well made battery holder is a better option? (not sure if well made and coin battery holder belong in the same sentence!)
    here is a photo of a battery I need to replace, for clarity:
    __________________
    the BIG 4
    ~~~ the top tier of low-ESR electrolytic capacitors ~~~
  • larrymoencurly
    • Oct 2004
    • 960
    Re: what is the correct way solder a coin battery?
    I sand the surfaces (about #300 to #400 paper), apply flux, tin them, and then I tin the wires before soldering them to the battery.
    Is that a rechargeable battery? My Toshiba A205 (Compal) uses a rechargeable lithium.
    • theOracle
      • Nov 2012
      • 163
      no, it is basically similar to a CR2032
      __________________
      the BIG 4
      • JJR
        • Mar 2013
        • 171
        Be careful applying heat to these cells, I blew one up once trying to solder tabs on, luckily I had my specs on or I would have been hit in the eye.
        nowadays I just fix the tabs to the cell with tightly wrapped insulation tape or heat shrink.
        • Uniballer
          • Jul 2013
          • 334
          Pretty sure you will not find any of these batteries factory soldered. They spot weld them (less overall heat to dissipate).
            • 31017
            for fucks sake - your all trying to hurt yourselves.
            first remove the plastic and see if it's lithium disposeable, or lithium-thionyl-chloride rechargeable.
            once you know, get one with tabs.
            or if you have room, fit a low profile holder.
            • selldoor
              Slow Learner
              • 7870
              Perhaps even easier than that if you are in the US
              http://www.amazon.com/dp/B00IWK9FUG/...G&linkCode=asn
              Also available on ebay search GC02000KH00
              • mariushm
                • May 2011
                • 3799
                You can get batteries with tabs already soldered to them. Here's an example: http://www.digikey.com/product-detai...657-ND/2404062
                You can solder wires to those tabs easily.
                You can spot weld wires and tabs to batteries but the equipment is not cheap...it's cheaper to just get a battery holder and once you solder the wires to the iron holder, you can just use some heatshrink material to prevent the battery holder from shorting something.
                Holders: http://www.digikey.com/product-searc...=0&pageSize=25
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4953
                  • New Zealand
                  Another thing you could do is get *any* model of battery that is the right chemistry\voltage, which comes with *any* leads pre-attached, then cut them off and splice the old wires on. Don't forget the heatshrink!
                  -David VanHorn
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    I bought some cheap battery holders from dx.
                    I've seen a few hacks where a spot welder has been made using a transformer from a microwave. Looks very dangerous to me though.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      I just tape them together tightly. Works fine.
                      A working TV? How boring!
                      • Mr.Orange
                        • Aug 2014
                        • 12
                        • Ireland
                        Thanks for info, assume same principle for laptop power batteries which are also used in power tools battery packs. I replaced a dead cell in a powerpack for a handheld trimmers from with a laptop cell (same power specs), next time will just try heat resistant tape.
                        If done right a glue-gun might also work.
                        A simple cheap SMD airflow tool is a handheld gas soldering iron without the iron :. is a selective hot airflow which can be regulated by turning up/down gas, also no onerous air lead. I have replaced many components without damaging them or the solder pads all within seconds... can also be used as a soldering iron & on heat shrink
                        • dellxps15
                          • Feb 2014
                          • 1588
                          • italy
                          i would cut the wire from old battery and with a solder iron and some solder flux paste (the acid ones) i would solder the new battery in and cover with some kapton.
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            +1
                              • 31017
                              dont do stupid shit with big lithium ion cells - that's how things blow up.
                              those cells must be replaced as a set or they will be out of balance when you charge them.
                              there was some foto's on candlepower forums of what can happen when they fail.
                              a guy had one explode in an aluminium torch,
                              it blasted the aluminium shrapnal across his kitchen so hard that it punctured the stainless-steel body of a coffee pot!!!
                              lucky for him, he was out when it blew!
                              • keeney123
                                Lauren
                                • Sep 2014
                                • 2536
                                There are many conductive epoxies that will work. The best is Silver epoxy, but is expensive. Other have nickel or some other form of metal to reduce the cost, but still offer low resistivity. Some epoxies set with high temperature and others set at 77 degrees F. If you buy some make sure at what temp. it sets up at.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4953
                                  • New Zealand
                                  Just buy one that already has solder tabs or wires spot welded to it... they're not hard to get...
                                  -David VanHorn
                                  • mkdj
                                    ASUS X571 no power : battery issue?
                                    by mkdj
                                    Mark and model: ASUS X571
                                    Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                    Tests already made:
                                    - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                    - I have removed...
                                    07-14-2025, 09:16 AM
                                  • techfreak9356
                                    Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                    by techfreak9356
                                    I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                    09-14-2023, 11:10 PM
                                    NVDC charger configuration...
                                    11-05-2024, 03:28 PM
                                  • ferah831208
                                    Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                                    by ferah831208
                                    Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                                    03-18-2025, 01:18 AM
                                  • huzo
                                    HP ELITE X2 1013 G3 weird battery issue
                                    by huzo
                                    Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                                    01-31-2025, 12:09 AM
