Vostro 3400 (LA-K033P) won't charge battery, everything else ok
  • techfreak9356
    • Dec 2022
    • 11
    • Philippines
    I temporarily resorted to taking apart the laptop every time and then moving the charging port and battery into the old board and charging it bare from there, since that's the only way I can charge it. However, recently the old board started refusing the charge the battery, and I got it accidentally run down to the point the new board wont even turn on anymore on battery power. Tried to charge the battery cells directly charged from 3.1v up to 4.1v each but still it is being reported as 0%. The battery I am using is a YRDD6. I also tried using the replacement WDX0R from my dead Inspiron 5570, which was a backup for my old 5593 board, but it was also identified as "Not a dell battery", even though laptop uses it no problem, provided battery had power. Both batteries got discharged to 0%, but I revived them both now, though still no joy
    Is there any way I can somehow trick the laptop into thinking my replacement battery is a dell battery? Or at least make it use either battery, which is obviously fully charged now? Or is it really the case that if these batteries reach a critically low voltage, the BMS disconnects the battery permanently and will not re-connect even if you re-charge the cells directly? I would like to rule out the battery is really not usable anymore before I start wasting my time trying to find a 3rd party "dell" battery which my laptop will identify and charge properly.
    I checked voltage on battery socket, with battery connected, I get 12.4v on pin 8-10, and 3.3v on pin 6-7 for both batteries. I got their voltages within 4.1v per cell.
  • mon2
    • 16807
    Re: Vostro 3400 (LA-K033P) won't charge battery, everything else ok
    Update the bios to the latest and test again.
    • techfreak9356
      • Dec 2022
      • 11
      • Philippines
      I am on 1.25.0 bios, and I cannot update to 1.26.0 anymore since it wants 10% battery but for some reason it can't identify my full charged battery.
      I observed that for a few seconds after shutting down, I get 0v on the battery socket and then back to 12.4v
      • mon2
        • 16807
        I would suggest to seek out a known compatible battery for this model of laptop to test again. The BMS may not be compatible with this laptop.
        • piernov
          • Jan 2016
          • 4438
          • France
          I don't recommend it as a power failure will brick the BIOS, but you can generally force update without battery using the BIOS Update utility in the UEFI Boot Menu and passing the "/forceit" parameter. I don't really see why that would fix the problem of incompatible battery though.
          • techfreak9356
            • Dec 2022
            • 11
            • Philippines
            I managed to get these details for the battery with HWInfo.
            General Properties
            Device Name: DELL CYMGM68
            Manufacturer Name: Samsung SDI
            Serial Number: 2322
            Unique ID: 2322Samsung SDIDELL CYMGM68
            Chemistry: Lithium Ion
            Designed Capacity: 41998 mWh
            Full Charged Capacity: 37894 mWh
            Wear Level: 9.8 %
            Current Power Status
            Power Status: Critical On AC Power
            Current Capacity: 0 mWh (0.0 %)
            Current Voltage: 12.123 V
            For some reason the battery reports 0% even though the voltage is about 12v, full charge territory since battery was rated to 11.4v. Battery was fine and can be recharged just fine using my 5593 board but after the deep discharge, it just keeps saying 0% even if it is fully charged. Is this because the IC in the BMS locked out the battery from further use? Also, after the discharge, the 5593 board refuses to boot with this battery anymore, or maybe I guess that board's MOSFETs finally gave in
            • MahmoudNasser
              Dell Vostro 3400 battery does not charge beyond 55%
              by MahmoudNasser
              I have a Dell Vostro 3400 battery does not charge beyond 55%
              I tried another file... the battery charge exceeded 55%, but it entered manufacturing mode and it did not count from it.
              - I rebuilt the basic BIOS and Clear Me, but without results
              What if the same situation does not charge the battery more than 55%?
              Can someone help me?
              The original BIOS file is attached
              Device Data
              Model Dell Vostro 3400
              CPU:i5-11th
              SN 7G4BRF3
              MP PartNumper:LA-K032P REV 1.0 (A00)
              Bios Chips:XM25QH64A...
              10-09-2023, 03:58 PM
            • razenxd
              How can I charge that battery pack?
              by razenxd
              it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
              At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
              Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
              Now, I have noticed a few things.
              The "dead" battery, while connected to charger and NOT Charging will...
              12-05-2024, 06:11 AM
            • ruletero
              Acer a515-43 low battery charge voltage
              by ruletero
              Hi
              Acer A515-43
              LA-H801P
              Fail: Does not charge battery, has low voltaje on connector.
              Laptop didn't want to turn on, only charge led blinked.
              I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
              I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
              Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
              10-24-2022, 02:31 PM
            • megacap
              MacBook Pro Retina 15.4-inch (2018) A1990 820-01041 No charge, no power after letting battery die and not using for a bit
              by megacap
              So I this MacBook Pro Retina 15.4-inch (2018) A1990 laptop that suddenly will not charge or start. It was working fine before. It would charge and was starting up normally from sleep. The only thing abnormal is that it seemed to be getting battery health warnings. Maybe a precursor of what was to come. Let it sit in sleep mode for about a week. Now it seems completely dead. Seems like no power at all. No lights, no fans, no screen, no touchpad clicks. Battery charger, which is apple 87w, doesn't get hot at all when plugged in. Charger will charge an iphone just fine though....
              06-05-2026, 12:38 PM
            • CWX
              CyberPower PR1500LCD will not charge battery.
              by CWX
              I have three CyberPower PR1500LCD units, i bought a used one without the battery and bought a new battery for it. The unit will not charge the battery. I know it's not the battery since i placed into one of the other UPS and it charged up just fine.
              I have replaced a bunch of caps on the two PCBs hoping that would fix it but it did not. All the PCBs look fine i am not sure what is responsible for charging the battery as the UPS works the battery just never goes above 10% and only gets charged to 23 volts as it should be 27
              CyberPower actually has the PCBs labeled as to...
              04-10-2026, 06:18 PM
