  • Boardview and Schematic Bot
    • 116032
    NVDC charger configuration quickly turns on BGATE to enable the
    battery to help adapter provide the system power in Turbo mode.
    The ISL88739 uses N-channel MOSFETs (NFETs) for all the
    switches to achieve the best performance and lowest BOM cost.
    The internal charge pump is capable of turning on all the NFETs
    fast or slow depending on the circumstance or need. The ability to
    quickly turn on NFETs prevents system bus voltage drop when the
    battery is suddenly removed in Turbo mode or in Battery Learn
    mode.
    The ISL88739 provides many protection features including the
    PROCHOT# indicator for system low voltage, adapter overcurrent,
    battery overcurrent or overheating, with an array of SMBus
    programmable parameters for maximum flexibility. It also
    features hardware based adapter current limit and
    battery-current limit in addition to SMBus programmable limits.
    The ISL88739 provides a high accuracy adapter current monitor,
    battery current monitor, and system power monitor outputs. To
    provide maximum flexibility for working with high power and low
    power systems, it provides several configurable current-sense
    resistor value options to achieve the best trade-off of current
    sensing accuracy vs power loss.
    The ISL88739 uses the Renesas Robust Ripple Regulator (R3)
    modulation scheme to provide excellent light-load efficiency and
    fast dynamic response. It is available in a 32 Ld 4mmx4mm QFN
    package.
    Features
    • Configurable as an HPB charger or NVDC charger
    • Compliant with Intel PROCHOT# requirements
    • Adapter current monitor and battery discharging current monitor
    - Uses NFET for all the switches
    - Supports removal of battery during Battery Learn mode
    - Actively controlled inrush current to prevent FET damage
    • SMBus programmable settings and high accuracy
    • Comprehensive protection features include
    - PROCHOT# indicator for system low voltage, adapter
    overcurrent, battery overcurrent, or system overheating
    - Hardware-based adapter-current and battery-current limits
    - Supports sudden removal of battery in system Turbo mode
    • 16 switching frequency options from 350kHz to 1MHz
    • Low quiescent current
    • SMBus and auto-increment I2C compatible
    • Robust Ripple Regulator (R3) modulation scheme provides excellent light-load efficiency and fast dynamic response
    • 32 Ld 4mmx4mm QFN package
    • Pb-free (RoHS compliant)
    Applications
    • Devices with rechargeable 2-, 3- or 4-cell batteries​
    Our boardview and schematic bot.
    ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
    Highly Integrated Narrow VDC Battery Charger for Notebook Computers
    The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
    for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
    Narrow VDC applications where the system power source is
    either the battery pack or the regulated output of the charger.
    This makes the max voltage to the system equal to the max
    battery voltage instead of the max adapter voltage. Operating
    at lower system voltage can improve...
    11-05-2024, 04:43 PM
  • flat-earther
    how to prevent a connected charger from draining battery when not charging?
    by flat-earther
    I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
    So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
    but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
    So the battery is backfeeding the charger and being drained.
    How can I prevent...
    08-07-2025, 01:04 PM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
    Bauer tool battery pack charging with a HERCULES charger modification
    The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
    Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
    05-06-2023, 12:17 PM
    Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
    I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
    So I have put them on the battery testing machine to drain each battery cell down to...
    09-04-2022, 04:45 PM
