A Question for the Linux Crowd
  • KeriJane
    Mac Enthusiast
    • Sep 2008
    • 681
    Hello.
    I'm thinking that there's something that I want to do and Linux might be the way to do it.
    Situation:
    Friends and relatives have Windows boxes but lack the skill or inclination to do a re-install. These are mostly XP machines with a couple of Vista ones.
    Store-bought PC's often have a restore partition where one can activate the Windows Pre-Installation program at boot and restore the computer to Day One. These typically call out the Windows Installation routine.
    So...
    How would one set up a Linux Bootloader and have an option to boot to a variant of Linux with a simple Graphical Interface so as to offer the option of restoring the main Windows Partition to a pre-configured arrangement?
    Let's just call it Day One, with Windows all nice and installed, updated and with certain programs all installed, ready to go..
    This would have to be very simplified with basically two options: Restore Windows to Day One or Quit and return to Windows.(normal boot)
    Could one Install Windows, get it all set, install Linux, copy the Windows Partition to a hidden partition that the normal Windows installation cannot see and also hide the Linux partition?
    The end result would be something like:
    320GB Hard drive, 298GB total available, maybe 250GB available to Windows which treats the drive as a 250GB drive with no evidence of Linux or Day One visible to the User.
    With one exception: During Boot the option to "Press Whatever Key" to restore Computer to original settings should be displayed for a second or two. That part is pretty easy I think, as it would just call up the bootloader which would be set to default Windows quickly.
    Obviously a nice, full install of Linux is possible, but what I would like is a very limited and simplified variant. Just enough to copy over a partition and being extremely User-Friendly.
    Is there any Variant of Linus already set to do such a thing?
    Thanks for any info,
    Keri
    The More You Learn The Less You Know!
  • washu
    • Jul 2009
    • 310
    Re: A Question for the Linux Crowd
    The closest to what you are looking for is Wubi
    http://wubi-installer.org/
    It installs Ubuntu (or a variant) into a file and can then boot it from the normal XP bootloader. If you give it a 10 GB file, Ubuntu will think it's installed onto a 10 GB HD. No partitions to mess with.
    If you don't like it, just run the uninstall in Windows and you are back the way you were.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      do that. its slower than a full install but its a good intro. the installer for ubuntu is improved with 9.10, as is the new app manager, software center.
      sigpic
      (Insert witty quote here)
      • etnietering
        • Apr 2009
        • 379
        If you want something good an easy to use for messing with partitions, I recommend http://partedmagic.com/ I ran it off of the CD, and that's what it's designed for, but there's probably a way to do a real install of it to a hard drive.
        • Bookworm
          • Nov 2007
          • 123
          I do computers for a living. I'm a heavy Linux user and administrator.
          Don't try it. You're looking at a world of hurt if you do. If you want them to be able to _try_ a Linux distribution without actually accessing their hard drives, use flash drives. Yes, they're slower, but you can put a Kubuntu/Ubuntu/Xubuntu/whatever install on a 4 gig flash drive, and leave a couple of gigs for 'personal files and settings'. Let them get used to it, and if it works out, just install on their machine and copy the settings over from the flash drive.
          The reason I'm saying this is that it sounds like you want to be able to 'explode' the windows partition into full size on the hard drive if they want to give up on Linux. You could script something (maybe) from a flash drive to do it, but from the boot loader itself would be harder. Also, Vista and later OSes are VERY picky about partition sizing.
          • Junk Parts
            Court Jester
            • Jun 2006
            • 8953
            I'm a fan of Mint Gloria Linux. Its installer works great with Xp Home. All you do is cold boot the PC with the Mint cd that you burnt from your download in the PC. During the install pick the option to install the Linux side by side with windows. Give it 10 gigs of hard drive space. Now after its installed, on the boot you just pick wich OS you want to run for that session and it boots it. Keep in mind that Linux can be broken too if you try hard enough.
            "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
            Mark Twain
            "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
            John Paul Jones
            There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
            Rod Serling
            • NxB
              • Feb 2009
              • 1595
              You are going to have to let them dual boot. OEMs write custom software for stuff like that. Most restores wipe your disk too. I try not to use them so people can keep their files.
              • KeriJane
                Mac Enthusiast
                • Sep 2008
                • 681
                Hi NxB
                I'm OK with wiping out files.
                But the part about writing custom software might slow me down a little.
                Funny thing is, my late father probably could have wrote something that would work. He used to write his own DOS programs!
                Or at least extensively modify existing ones.
                He would have loved Linux, especially at the Command Line.
                Oddly, he couldn't get used to point 'n click Windows. Or figure out the VCR.
                WWDD,
                Keri
                • bgavin
                  • Jan 2007
                  • 1355
                  What about a virtual machine?
                  • NxB
                    • Feb 2009
                    • 1595
                    You can try modifying one of the OEM's restore programs but you have to figure out how it works. They mostly just decompress an archive with all of the files. The bootloader only loads their program. Something like BartPE might help you. Its a lot of work when dual booting will be just fine.
                    • gonzo0815
                      • Feb 2006
                      • 1600
                      Acronis Truen Image does all what you want, and it isn`t that expensive. Some oem use it too.
                      • toastygoodness
                        • Jul 2005
                        • 813
                        yeah i like acronis... or you could getem a vm like bgavin says... or better yet virtualize windows?
                        • i4004
                          • Oct 2006
                          • 2029
                          keri, you want linux to restore windows?
                          hehe...
                          and if they can't do reinstall, i doubt virtual machine or acronis are solutions either....
                          what YOU could do(obviously not them) is install anew, clone to external hdd(yeap., they would need to buy external hdds) and restore when needed....
                          restore partition is good...untill whole hdd goes to hell....
                          aldo, you do know of system restore option, in xp, right?
                          start->programs->accessories->system tools...
                          just make restore point on day one...
                          • KeriJane
                            Mac Enthusiast
                            • Sep 2008
                            • 681
                            Hi i4004
                            Oh yes, I'm very aware of Windows System Restore.
                            Unfortunately, nearly all modern viruses erase all the Restore points and go on to disable System restore!
                            At least on all the stuff I've had to fix for people lately. Only ONE system still had System Restore functional.
                            I suspect that there's been a recent rash of bad stuff out because all these systems had AVG, Norton or McAffee running. Even my manager at work got the "Windows AntiVirus Pro" on his office computer!
                            He asked me what that popup ballon was.... I replied, Better call IT!
                            Glad that isn't me.
                            So, I'd really like to have a NON-Windows OS available to just copy over a whole working copy of the Windows drive.
                            Thanks for the info,
                            Keri
                            • Junk Parts
                              Court Jester
                              • Jun 2006
                              • 8953
                              Keri I used a progie in the past called "File Protect 2000." I used it in windows to make files invisible and unaccessable by any user who didn't know the password for the fp2000. I don't know but you may be able to use this progie to protect windows system files from a rude user too. It may also be possible to run this progie outside of windows to protect everything on the HD. I just had another thought! Is there any setting in their bios to block them out of making changes to the Root programs on the HD? I bought a used work station that was set up this way in the past and it drove me nuts until I found the setting to gain access to the HD for reprogramming.
                              Mark Twain
                              John Paul Jones
                              Rod Serling
                              • seanc
                                • Nov 2008
                                • 1319
                                Glad that isn't me.
                                No, that's me! Ugh, it's such a pain to remove.
                                I spent a day tidying up a laptop for a customer, had it all working nicely.
                                Next day they call "Windows says I have a virus".
                                I know that isn't Windows
                                AVG, McAfee and Norton 360 have failed me so far.
                                NOD32 Antivirus is fairing well.
                                Edit: I got distracted with virus trauma.
                                Here's how things kind of work for imaging at my office:
                                Windows deployment server, network boot Windows PE, image, done.
                                What you could do is put Windows PE on a separate partition, let the user run through the wizard to re-image their PC.
                                Setting it all up is a faff, but once setup, it works.
                                Another anecdote I just remembered - I was called out to replace a machine that was having trouble booting, the hard drive sounded like it was failing, it was a horrible cheap machine.
                                I got there and the machine was running fine.
                                I asked the customer when it started working, he said "I kept pressing buttons and it started working, I didn't know what I was doing, I just kept pressing next."
                                The customer had managed to press F11, enter the restore partition, format his HDD and restore it to the factory image and lose all of the work that he hadn't backed up. He had been given a pen drive to back up to, of course, this had lapsed... for a few years.
                                • bgavin
                                  • Jan 2007
                                  • 1355
                                  It is much simpler to use an external USB drive and Ghost.
                                  Before the system is corrupted, split the volume into System and Data.
                                  Move the user MyDocuments to D:\Users\<idsid>\MyDocuments and leave their profile on System.
                                  When the system becomes corrupt, restore it from a Ghost image.
                                  You can keep the image on the D:\Ghosts directory if you choose, but this exposes the system to the hard drive as single point of failure.
                                  It all depends upon how much redundancy is required in the system.
                                  I personally prefer two internal drives.
                                  • Flasman90
                                    Macbook Pro DFU Restore Issues
                                    by Flasman90
                                    I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                                    - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                                    - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                                    08-30-2025, 10:27 AM
                                  • iMuhtaseb
                                    820-02020 A2338 Restore/Revive Failed
                                    by iMuhtaseb
                                    A2338 - Pristine condition.. I took out of the board and inspected it.. nothing.. as if the computer is barely used even.
                                    Anyway, customer said they tried erasing/formatting it and it got stuck on Apple logo preventing to go further.. I asked them why they tried to erase it from the first place? They said it turned off randomly once.. then they erased it and it worked out for a few days then it shut off again..
                                    I put the computer in DFU; I downloaded the latest Ventura IPSW and restored it.. during the "Installing.." it restarts then it shows the exclamation...
                                    09-11-2023, 08:43 AM
                                  • yheriatovych
                                    A2338 820-02020-A 5V, no screen, unable to revive/restore
                                    by yheriatovych
                                    Hi. I need some help troubleshooting the issue (which is a bit odd to my limited experience) with the A2338 Macbook.
                                    Initial symptoms:
                                    One day the laptop refused to wake up (as it seemed at first), spinning the fan on full blast, with no picture on the screen.
                                    Force rebooting didn't help. To check if it boots at all I connected the external display and surprisingly it booted to the system, and I was able to log in to the system.
                                    However, I noticed that it was in some weird state:
                                    • The fan was still blasting at full speed. It's blasting even when the system
                                    01-31-2024, 10:22 AM
                                  • Stephen
                                    iMac M1 DFU restore issue
                                    by Stephen
                                    iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                                    this is the message it gives me with the error
                                    Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                                    Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                                    03-07-2025, 12:19 PM
                                  • iulik17d
                                    Intel Arc A380 videocard power limit remove - BIOS needed
                                    by iulik17d
                                    Hello everyone!
                                    The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
                                    The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...
                                    01-10-2025, 02:33 PM
