iMac M1 DFU restore issue
This topic has been answered.
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 676
    iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
    this is the message it gives me with the error
    Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
    Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't use batteries and the power is working. Any suggestions.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Answer selected by Stephen at 03-14-2025, 11:37 AM.
    Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 676
    mon2 Just wanted to update the issue with this, pulled the screen apart, it was a board related issue, HOWEVER it was not the Main Logic board, it was the Daughter USB C IO board that connects to the USB ports and the main logic board, I replaced it and now it fully restored. That was my first initial thought so I went ahead and swapped it out with another iMac daughter board we had in stock and VOILA restored without issue.
    • mon2
      • 15279
      Is it under warranty? What does Apple say? They created this product so they must know how to fix it. Start with hem first. We should not have to hack their crap everytime.
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 676
        Most likely not under warranty. I would assume this is why it ended up here. They said it was ruled a faulty logic board. I was wondering if you had any thoughts on what that message means. I was going to open it up and do a little investigation but nothing shows as of yet to do so until I get an idea what that message means.
        sigpic
        • mon2
          • 15279
          Are you able to boot using an external media? USB stick or internet boot? Just amazing how a multi-billion dollar company can produce such unreliable crap hardware.
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 676
            that is where you are wrong...multi trillion dollar company LOL but yeah sadly it won't let me boot at all since I tried the restore process I am assuming it won't let me but let me see if it sees something. I try to go into options but it just restarts over and over.
            sigpic
            • mon2
              • 15279
              Yeah. I am confident that I have seen this '!' symbol fault in my many readings over the years. Is the client ok with you carving up the screen to peak inside? If the warranty is gone that would be the next step. Just be very very very careful on how deep you go with the cutting wheel. If you go too deep, the LCD will be history. The edge flex cables are just past the glue strips. Ideally use IPA (alcohol) dipped round cutting wheels from Apple (or similar on Amazon / MobileSentrix).
              • Stephen
                Meow Meow MEOW!
                • Apr 2020
                • 676
                Oh I have opened plenty of iMac 24" M1 and done board repair those were easier because I found shorts on them and fixed them I found a common short on all the M1 iMacs. I have repaired the same issue over and over a few times with ease, but this one actually turns on and doesn't let me restore it. I was considering replacing the SOC chip with a good donor board SOC chip that would have a good OS on it and maybe it would boot?
                sigpic
                • Stephen
                  Meow Meow MEOW!
                  • Apr 2020
                  • 676
                  sigpic
                  • teokarafou
                    • Feb 2018
                    • 46
                    • Greece
                    can you tell us the common short?
                    • zklgfs
                      Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                      by zklgfs
                      I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                      08-11-2025, 02:14 PM
                    • riko 656
                      Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                      by riko 656
                      I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                      Laptop Model:
                      • Model: Lenovo Legion Slim 5 16APH8
                      • GPU: NVIDIA GeForce RTX 4070
                      • Main BIOS chip size: 32MB
                      • VBIOS chip size: 16MB
                      Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                      What I Have Tried So Far:
                      1. I
                      11-04-2025, 05:14 AM
                    • Stephen
                      iMac 27” 2020 Boot issue
                      by Stephen
                      Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
                      08-16-2024, 09:32 AM
                    • Stephen
                      A1466 MacBook Air 13" 2017 Backlight issue works but then turns off
                      by Stephen
                      Hello, got a weird MacBook Air here
                      board looks fresh and no water damage, backlight works and turns on and stays on when installing OS etc. However, when the os is installed and when the system files are loaded before the login page the backlight goes out. I have wiped it, NVRAM reset, etc and even took some other instances and this blows my mind, never seen this before. Backlight just turns off once the OS is loaded. Anyone come across this and if so what would be the cause? I am certain its a board issue since I tested the LCD on another board and it stays on. Again the backlight works...
                      08-23-2023, 09:12 AM
                    • cajoeg
                      Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                      by cajoeg
                      Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                      The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                      02-10-2025, 04:01 PM
