820-02020 A2338 Restore/Revive Failed
  • iMuhtaseb
    • Jan 2017
    • 125
    • Palesine
    A2338 - Pristine condition.. I took out of the board and inspected it.. nothing.. as if the computer is barely used even.
    Anyway, customer said they tried erasing/formatting it and it got stuck on Apple logo preventing to go further.. I asked them why they tried to erase it from the first place? They said it turned off randomly once.. then they erased it and it worked out for a few days then it shut off again..
    I put the computer in DFU; I downloaded the latest Ventura IPSW and restored it.. during the "Installing.." it restarts then it shows the exclamation mark with Apple link to restore..
    I got numerous error codes among them: 4013, 4010, 21..
    I reprogrammed SoC ROM with clean BIN. After restore it gave me error 6 (while I think it lasted longer in "Installing..").. I restored another time and it gave me error 100.
    (still refusing to enter boot select)
    I tried erasing the SoC ROM and still not completing the DFU restore/install.. getting error 4010..
    One thing I have completely skipped out during the troubleshooting process is that it takes 5v 0 amps or 20v 0 amps.. it's not drawing whatsoever.. in this situation is should draw 0.05 to 0.1
    One thing I've noticed before I return the original ROM data is that the ROM is still erased as it is.. the restore/install has not even reached the process or the segment where it writes on ROM.
    Both ports behaving the same. 20V 0.0A
    PPBUS (with battery) = 13v
    PPBUS (without battery) = 12v
    PP3v8_AON = 3.3v
    PP3v3_S2 = 3.3v
    PP3v3_S2_UPC = 3.3v
    PP5v_S2 = 5.1v
    PP1v25_S2 = 1.25v
    PPBUS is being low where it should be around 12.6 and above if I remember correctly.
  • yheriatovych
    A2338 820-02020-A 5V, no screen, unable to revive/restore
    by yheriatovych
    Hi. I need some help troubleshooting the issue (which is a bit odd to my limited experience) with the A2338 Macbook.
    Initial symptoms:
    One day the laptop refused to wake up (as it seemed at first), spinning the fan on full blast, with no picture on the screen.
    Force rebooting didn't help. To check if it boots at all I connected the external display and surprisingly it booted to the system, and I was able to log in to the system.
    However, I noticed that it was in some weird state:
    • The fan was still blasting at full speed. It's blasting even when the system
    01-31-2024, 10:22 AM
  • Stephen
    A2338 MacBook Pro M1 Issue with DFU Restore or revive.
    by Stephen
    Customer came in with a board issue, board looks clean, board turns on, he did a software update and he got the infamous Apple boot loop logo. He took it to Apple and Apple said he needed a new board. They attempted to DFU revive restore etc no luck. The board is stuck on the (!) point. I tried DFU myself and no luck. Nothing, board boots up goes into DFU computer turns on with Apple logo when applying the patch and nothing it gets stuck at halfway point and hangs on. I was wondering if anyone has had any experience with this particular issue. Board isn't liquid damage from what I can tell...
    10-11-2024, 11:14 AM
  • kjchatman
    820-02020 a2338 motherboard has a ppbus short to ground
    by kjchatman
    this machine came to me as DOA and immediately found the issue as a 12v short to ground. Is it okay to inject voltage into that rail or does it have a potential path to the cpu or something?
    08-21-2025, 12:13 PM
  • lab10.haifa
    Macbook Pro A2338 820-02020 Stuck on RESTORE MODE
    by lab10.haifa
    Good day, friends. Got this problem with M1 macbook - it starts, chimes, tries to boot and stuck with a message "support.apple.com/mac/restore"
    It works with DFU mode, but it's cannot be restored. With "revive" function - same problem. Internal restore mode doesn't work, as well as Internet Recovery.
    There is no damage on the motherboard. No short circuits.
    Could it be a NAND problem? (but usually, if NAND is dead - mac simply wouldn't turn on)
    Thanks....
    10-08-2025, 02:55 AM
  • Simplebeans
    MacBook Pro A2338 keeps restarting when attempting to install macOS
    by Simplebeans
    I have just got in a MacBook Pro A2338 which was initially displaying the Apple logo followed by an explanation mark in a circle as described here:- https://support.apple.com/en-gb/102164.
    After some error messages attempting to revive and restore the machine via DFU mode i have finally got the machine revived however now the issue seems to be when attempting to install macOS Sequoia via a bootable USB installer or via macOS recovery the machine just keeps freezing and restarting before the installation is complete, usually the installation has just started or is mid way trough before...
    08-10-2025, 11:04 AM
