heatsinks on northbridges/chipsets
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8716
    Has anyone messed with the heatsink/fans on northbridges?
    Well, they're there for a reason but anyone know what kinds of reversable/unreversable damage can happen when the heatsink or thermal compound fails?
    And which NB have you had experience with?
  • shadow
    • Feb 2007
    • 732
    Re: heatsinks on northbridges/chipsets
    Not too sure what you are looking for. However I used to own a AMD Athlon based system (Socket A) and the motherboard included a small tiny 40mm fan that squealed (since it ran so fast to push the little air it could). I decided to disconnect and remove it. Nothing bad happened to it, I did make sure the chipset was not overheating at the start. I had decent airflow and as such I never had an issue. The motherboard was a Gigabyte GA-7VA. The chipset was a VIA KT400. Later revisions of the same motherboard ended up having passive heatsinks on the chipset.
    • mariushm
      • May 2011
      • 3799
      Northbridges usually consume about 8-12 watts and they dissipate about 2-4 watts of heat.
      The chipset dissipates half a watt to a watt through the motherboard and the bga balls but they usually need heatsinks to dissipate the rest.
      Some chipsets needed actively cooled heatsinks because they had integrated video cards but generally no fan is required.
      As for what consequence you'd have for not actively cooling? Chipsets usually have thermal protection so you may get system shutting down.. if not, you may get corrupted transfers between cpu and video card or other cards ... corrupt transfers between northbridge and southbridge (which handles sata, ide etc)...
      • SuperDuty
        • Mar 2011
        • 299
        • France
        I would put an active heatsink over any nVidia based chipset, as they're notorious for overheating. A large heatsink that gets a good airflow might do the trick as well.
        And yes, most chipsets with integrated video will run hotter.
        Some very old chipsets didn't need any cooling, I have some i815 boards like that. But the i815EP (with video) all have passive cooling.
        I don't think any chipsets younger than Pentium III have no heatsink actually.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          I usually recompound the heatsinks on any lower quality boards... I never did on my workstation boards...
          sigpic
          (Insert witty quote here)
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16959
            It still dries out.......scrape that older crud off and butter them up with arctic silver....that'll last the life of the board. I've scraped plenty of dried out compound off high end boards....they still use the junk goop.
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8716
              I have that Gigabyte board (with a large passive heatsink on its northbridge) that seems to crash randomly or consistently hang in BIOS (cold boot too). I was wondering if the heatsink compound in it ended up drying up causing hangs, and whether or not redoing is worth it, or has the damage been done - no heatsink fixing would bring the board back to life. Plus whether or not this was the problem with the board to begin with...
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                great... looks like another AS5 party at RD's...
                sigpic
                • Sweet & Spicy
                  Techie's Wife
                  • Apr 2013
                  • 281
                  Hey, if it's a party, can I join you?
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Yeah I'd say they need a heatsink, though sometimes they don't, depending on how hot the chipset is allowed to get before being damaged, and how much power it dissipates. Some are rated up to 125C, some are only 70C.
                    Oh, and be careful on the ones with the exposed silicon die, be gentle with those, especially when taking the heatsink on and off.
                    Muh-soggy-knee
                      master hoarder
                      • May 2008
                      • 12175
                      All of the i865 heat sinks I've seen on Dell PCs are inadequate. With the case sides closed, those things can go as high as 60C, or possibly even more. Good thing most of them used leaded solder. I usually put a small 40 mm fan running at 7V. It's virtually silent at that voltage and the temperatures always drop by at least 10C.
                      The ATI Southbrdiges that come with the Xpress 200 NB are often left without heat sinks by some motherboard manufacturers, and they usually run about 50C idle. On those, I always add a simple heat sink when I can. That usually brings down the temperatures by at least 5C. If there is good airflow in the case, it can be as much as 15C.
                      And when the motherboard seems to have way too many hot running parts (be it chipset heat sinks or MOSFETs or coils) I just mount a 120 mm fan pointing at the motherboard and that takes care of everything.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        i remember in the abit bx days when i would recap the board some were still a bit twitchy.
                        the heatsinks turned out to be anything but flat.a dab of compound would get them 100% 24/7/365 stable.
                        • c_hegge
                          • Sep 2009
                          • 5219
                          Some of the new B85 and H87 boards also have pretty miniscule heat sinks on the chipsets. On some, it's basically just a thick slab with no fins The chipsets get too hot to touch, even when the PC isn't doing anything.
                          • harp
                            Metod for removing glued heatsink from fragile component
                            by harp
                            I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
                            06-23-2025, 02:01 PM
                          • Ven
                            Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
                            by Ven
                            I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
                            The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
                            I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
                            If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
                            07-08-2024, 09:32 AM
                          • harp
                            can fanless heatsink replace poor original on RX26PG2
                            by harp
                            I have RX26PG2 graphic card with incomplete original heatsink, only aluminium plate... but in original solution it look like such bad termal design that I asking if is proper fanless heatsink be adequate replacement ot better... what you think? Till powering on, it is propper hot......
                            06-25-2025, 10:56 AM
                          • nobbnobb1
                            Fixed a Velodyne DPS-12 Subwoofer. Thermal Management + Heatsink Grounding Question
                            by nobbnobb1
                            I have a Velodyne DPS-12 subwoofer that was making weird noises. Upon taking it apart, I noticed there was yellow glue all over the circuit board which had turned brown, so I scraped it all off and that fixed the problem. I used hot glue instead around the various components.
                            There was also one bulging capacitor, and another that must've been in a really hot location because the labelling looked like it was scorched. You can see in the picture the circuit board has discolored over time from this heat. Could either be from the MOSFET (with heatsink), or the resistor....
                            09-08-2022, 09:58 PM
                          • bauto601
                            KDM 480W PSU upgrade succes! (opinions?)
                            by bauto601
                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                            A "nice" YoungYear unit? - Badcaps
                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                            12-26-2023, 03:05 PM
