Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
  • Ven
    • Jul 2016
    • 46
    I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
    The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
    I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
    If you've done a similar upgrade, I'd love to hear about your experience and any challenges you faced.
    Thanks in advance for your help!
  • harp
    • Jun 2022
    • 599
    • Planet Earth
    I have a small second hand TV, that I rarely used as a filming monitor. When I open it for initial cleaning and inspection, I noticed that for main IC is used very small heatsink which was directly glued on IC (just like on yours), not side suport on pcb whatsoever... On other side of pcb, the board was starting browning from heat, so, any mess around with glued heatsink or IC is not anymore option due to pobably ripped pad under bga... I use a small thin turbine (side type, with partialy housing) fan from old graphics card like attachment and connect it to usb power, so it is on while is TV on, and stay on a couple minutes after shuts down. It is not too loud, because work on half of power. I fixing it very closely and hope it lower some degree more. All other options is too risky to me, because TV is still in working condition, and if I screw it up, there is nothing good... better to do nothing.
    • Ven
      • Jul 2016
      • 46
      Thank you for your reply, I will take your comment into consideration.
      • nobbnobb1
        • Nov 2019
        • 76
        I picked up a top of the line LG plasma for free which was in mint condition, but had a failed chip on the mainboard. All I did was reflow the BGA with a heat gun, and added a fan to the chip which I found a 12V take off point somewhere off the power supply. The BGA problem is well known on this TV, but after the heatgun trick it's been holding just fine for the last 4+ years. So well worth it to add the extra cooling IMO as it minimizes the thermal stresses on the chip on each on/off cycle.
        • Borse2008
          by Borse2008
          • There’s
          07-15-2025, 04:55 AM
        • cheeky2
          by cheeky2
          05-25-2024, 03:27 AM
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • JSin21
          Compatibility of main boards between different variations of samsung MU6100
          by JSin21
          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
          I have Samsung Smart TV UA65MU6100WXXY version DA01
          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
          11-27-2023, 04:54 AM
        • harp
          Metod for removing glued heatsink from fragile component
          by harp
          I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
          06-23-2025, 02:01 PM
