Every folder on my harddrive is EMPTY!!! WTF?
  • mattpd
    • Oct 2012
    • 302
    A customer brought in a laptop with an interesting problem. She complained it would not boot. I tried to boot it and it came up with a STOP screen and said something about "OS mismatch". I hooked the hard drive up to another computer and EVERY SINGLE FOLDER IS EMPTY. All of the folders are still intact, but their contents does not exist. The only files that I actually see are a few log files that are on the ROOT. Other than that there are NO files. The hard drive properties only report 2GB being used when I know there should be more.
    The files are not hidden. I have the computer set to show hidden files and I also un-hid all the files on the computer. Any sugestions?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Every folder on my harddrive is EMPTY!!! WTF?
    Maybe because you don't have permission to view their files?
    • mattpd
      • Oct 2012
      • 302
      Doubt it as it lets me drill down into the folders. If I didn't have permission, the folders would not open. I do this on a daily basis with customers computers and have never seen this problem. I'm afraid that maybe the file system is damaged. So far all of the recovery programs I have run are seeing the same empty folders.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        It was just a suggestion Getdataback for NTFS has been a great program for me for recovering files from issues like that. I highly recommend it
        • mattpd
          • Oct 2012
          • 302
          Any suggestions are welcome, I was just saying that its not a common problem to the best of my knowledge Would that be GetDataBack for NTFS you speak of? I love it too, unfortunately it does see any files either.
          • selldoor
            Slow Learner
            • 7870
            Perhaps its what she didnt tell you that is the problem? make a few enquiries
            had she or anyone tried to fix it. Picked up a file wiping virus.
            • smason
              • 1652
              Check to make sure you have enabled show hidden files.
              There's a ton of malware out there that changes all your files to hidden.
              • lti
                • May 2011
                • 2557
                I had a strange hard drive failure where the only thing Windows could see was a single empty folder. However, that drive still reported the same amount of space being used that it reported before the failure.
                In your case, I think something removed all of those files since the amount of space being used is so low. The hard drive could be bad as well because a few log files and a bunch of empty folders would not take up 2GB.
                • Kiriakos GR
                  Banned
                  • May 2012
                  • 940
                  • Greece
                  An laptop ... what brand ?
                  OS ... what OS ?
                  Are those files encrypted ? by what software they was protected ?
                  Is it XP Pro ? Use the recovery console !!
                  Make the right questions so to get a proper answer.
                  • eppidrummer
                    • Jan 2011
                    • 65
                    Believe it or not its a virus. Seen this exact thing many times before with windows 7. There is a program called "unhide" that will fix your problem. I sent you a link.
                    -Eppidrummer
                    • mattpd
                      • Oct 2012
                      • 302
                      -Eppidrummer
                      It may be a virus, but its not the common one that hides files. The files are not hidden, they are literally gone.
                      • Time2Retire
                        • Aug 2012
                        • 256
                        I say hook the HD to a Linux PC and see what's on it. A Windows virus or trojan can't do shit in Linux. If nothing else, you may be able to recover some personal files.
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          look in temp and make sure you can view hidden.there is a hostageware going around the hides stuff in temp and sets them hidden.but iirc its just the users folder.it usually contains the stuff folks care about.
                          • delaware74b
                            • Apr 2009
                            • 628
                            Time2Retire has the right idea. I have had 3 computers with the same bug on them in the past month. No files visible in Windows, unable to get to customers' documents connecting the drive to a windows PC through USB adapter.
                            I have my netbook dual-booting with Ubuntu. Simple fix: boot into Ubuntu, connect customer's hard drive via USB, copy and paste to an external hard drive for reload. Burn copy and give it to customer. Dump customer's hard drive and reload Windows and customer's data.
                            BTW, this bug blows the mbr and boot managers, causing a new inaccessible 10GB empty partition that Windows cannot see or access. Installed programs on the affected drive start disappearing until Windows won't lead.
                            My latest on was the FBI/ransom trojan. Couldn't kill it with Malwarebytes or Spybot. Wiping the drive was the only option.......
                            Stupidity should be a crime, especially for drivers. I have NO patience for them.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              Wow, usually Malwarebytes is really good at removing that stuff.
                              --- begin sig file ---
                              --- end sig file ---
                              • mattpd
                                • Oct 2012
                                • 302
                                Thanks, I will give Ubuntu live cd a try. Is this caused by a virus or something else? It's especially nasty whatever it is.
                                That is strange that malware didn't get the FBI/random virus. I have seen about 10 of these and usually just a quick scan will remove it. I guess they got smarter.
                                • mattpd
                                  • Oct 2012
                                  • 302
                                  Just tried in Ubuntu. Files are non existent. Luckily I will be able to restore her computer from a backup so it's not a big deal, but what the heck caused this?
                                  • delaware74b
                                    • Apr 2009
                                    • 628
                                    The bug kept reloading itself in the registry after removing the threats while in safe mode. I ran a full system scan, remove the bug, reboot into safe mode and comes up clean. I then reboot into regular mode, run a full system scan with Malwarebytes and the bug is back.....
                                    After the third time and 2 hours, I chose to to a drive wipe and reinstall the OS.
                                    • smason
                                      • 1652
                                      Yeah, life's too short. At work if we can't kill it manually in 15 minutes (which I usually can), we grab any personal data, then wipe and reload.
                                      • mattpd
                                        • Oct 2012
                                        • 302
                                        I hear that...
                                        after you let malwarebytes do its thing, make sure you clean out any and all temp files on the PC and then reboot. That has killed every FBI/ransom virus I have seen. I use this:
                                        http://www.geekstogo.com/forum/files...r-by-oldtimer/
                                        • zioricci
                                          Folder Is empty
                                          by zioricci
                                          My Toshiba laptop stopped at the Toshiba logo when starting up, I flashed the bios and fixed it. Fortunately I had also backed up the data folder on an HP laptop with which in the meantime I reinstalled Windows 10 on the Toshiba hard drive using it as an external drive with which I am able to start the Toshiba after the problems solved.
                                          The real problem now is when I copy and paste the data folder from the HP back to the Toshiba hard drive, again using it as an external drive on the HP. In fact, when I put the disk back in the Toshiba, it tells me that The folder is empty but in...
                                          04-05-2023, 01:51 AM
                                        • EpicFix
                                          Where is the "Desktop" folder located in Windows 11?
                                          by EpicFix
                                          At the risk of sounding like a total noob I'm asking If anyone can help me locate the "Desktop" folder on Windows 11. I am trying to make a backup of all the user data from an SSD (mounted externally) that has Windows 11 installed. I was able to do this before up to Windows 10 by navigating to the User folder --> Username and there I would see the individual folders, Documents, Downloads etc. Attached is a screenshot of the folders I do see within the Users / Username folder. Any help locating the desktop folder will be greatly appreciated. Thanks in advance to the community. ...
                                          07-12-2025, 07:14 AM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • Hinkz
                                          Lenovo m90q gen 4 hidden BIOS settings.
                                          by Hinkz
                                          Hello All,
                                          I recently upgraded my Lenovo m920q to a m90q gen4 (13th gen intel).
                                          I had much success following some very helpful guides on unpacking the m920q BIOS that Lenovo had on their website to find out hidden options such as cfg lock & overclocking lock, then using grub to change these settings.
                                          I'm having much less success with the m90q gen4 and latest BIOS on the Lenovo website (https://support.lenovo.com/us/en/dow...tation-p3-tiny), when I unpack this BIOS and use UEFITool to browse its contents I can't seem...
                                          06-28-2024, 05:37 PM
                                        • zlr8r
                                          Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                                          by zlr8r
                                          Greetings
                                          I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                                          Serial Number: 5CG3202C16
                                          Product #/SKU: 739P0AV
                                          CT Number: PRTUE00WBI30YX
                                          Description: HP ZBook Firefly 14 inch G10
                                          BuildID: 23WWWGAZ602#SABU#DABU
                                          Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                                          MAC address not found.
                                          • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                                          10-28-2025, 01:56 PM
