  • throwaway327
    • Jun 2025
    • 5
    Model No: RC72LA
    Serial No: SBNVKD001014459
    I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For example, I changed 'USB4 Bus Reserved' from 96, 'USB4 IO reserved (KB) from 16, 'USB4 Non-Prefetch Memory Reserved' from 384 and 'USB4 - non-Prefetch MMIO align' from 64. I think I also changed USB4 ACPI _DEP Support. Since then it won't boot and sticks on the ROG logo despite resets/battery removal etc.
    After finally getting to the point of having a (verified via md5) backup of my bad BIOS, taking the ASUS bios from their site and figuring out how to get it the right file size, I've got the two open in Tiny Hexer and on seeing how much differs between them I'm not confident what I need to copy from mine to the other to make sure all works ok without copying over whatever I broke and maintaining as full a functionality as possible. For example I've read about issues with ASUS cloud restore with a bad bios and I'll likely need to use it after this, and I stumbled across lines in the bios dump mentioning cloud certificates or something similar, so I don't want to make it worse.... I'm feeling a bit 'in too deep'!
    I've attached my backup of the bad Bios - from what I gather the serial, win key, and I'm assuming other bits of info I can see in it like cloud recovery certificates etc. all get transplanted to the ASUS bios? Is this the 'DMI' I'm trying to wrap my head around?
    Also attached is the altered ASUS bios to correct the file size, removing the first 2KB from the original file. This was downloaded from their site and edited by me in Tiny Hexer. I've put in the untouched bios also.
    Thank you for your help
  • hoaca388
    Badcaps
    • Jan 2022
    • 12356
    Model No: RC72LA
    RC72LA
    • throwaway327
      • Jun 2025
      • 5
      Thanks for your help - I've tried flashing this a few times but it keeps failing to verify, the error is repeatedly: "Verification error on address: 0x01000010, Device: 0x00, Buffer: 0x78"
      I thought it was just bad contact with the chip, but it's failed at that exact point multiple times now?
      • hoaca388
        Badcaps
        • Jan 2022
        • 12356
        Programmer error.
        • throwaway327
          • Jun 2025
          • 5
          Yep - had to come back to it after a day or two to let my hands rest - I must've been losing contact with the chip on some of the pogo pins it was a real struggle to keep myself steady for that long.
          Flashed and now booting, and bios updated happily to the latest version.
          Thank you so much for your help!
          • Hinkz
            Lenovo m90q gen 4 hidden BIOS settings.
            by Hinkz
            Hello All,
            I recently upgraded my Lenovo m920q to a m90q gen4 (13th gen intel).
            I had much success following some very helpful guides on unpacking the m920q BIOS that Lenovo had on their website to find out hidden options such as cfg lock & overclocking lock, then using grub to change these settings.
            I'm having much less success with the m90q gen4 and latest BIOS on the Lenovo website (https://support.lenovo.com/us/en/dow...tation-p3-tiny), when I unpack this BIOS and use UEFITool to browse its contents I can't seem...
            06-28-2024, 05:37 PM
          • AquaMan Ua
            Problem with PANASONIC CF53 laptop after changing BIOS settings
            by AquaMan Ua
            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
            05-17-2025, 09:40 AM
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
          • chudofermer
            Asus Ally rc71l bios
            by chudofermer
            Hello!
            Received Asus Ally rc71l with the wrong bios.
            Have the original package and all serial numbers.
            Can anyone help me understand what is wrong?
            Condition:
            Received with an original box with all serial numbers
            Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
            Got the flash dump, nothing found on DMI section
            No Windows key, just key ID on the box
            What is done:
            1. Flash the latest bios version with serial numbers...
            03-05-2025, 05:42 AM
          • juergenb
            Dell Precision 3660 - BIOS Image, Hidden Settings, Thermal Settings ?
            by juergenb
            I got my self a new Dell Workstation (Dell Precision 3660, i5-13500).
            Unfortunately, Dell has fixed the front fan´s settings in the BIOS.
            Both the speed and the presence of the fan are fixed.
            There seems to be no hidden setting.
            The thermal tables for the speeds were changed in one of the last BIOS updates.
            Do you see a possibility to change these tables from the BIOS update file?
            Precision_3660_2.1.0 -> Release Notes
            Updated the thermal table to reduce fan noise.
            Updated Intel Management...
            08-12-2023, 03:50 AM
