Every folder on my harddrive is EMPTY!!! WTF?
  • gabik111
    ORD spotter
    • 142
    • USA / Poland
    Re: Every folder on my harddrive is EMPTY!!! WTF?
    I had similar problem in my brothers' laptop. It was a virus that made hidden attributes to all jpg files and made them invisible. I removed hdd and connected to another computer, removed virus , change attributed and everything comes back to normal.
    You can try that that way.
    Laptops and computers repair.
    • smason
      • 1652
      Originally posted by mattpd
      I hear that...
      after you let malwarebytes do its thing, make sure you clean out any and all temp files on the PC and then reboot. That has killed every FBI/ransom virus I have seen. I use this:
      http://www.geekstogo.com/forum/files...r-by-oldtimer/
      I nuke temp files first, no point in wasting time scanning them, though lately I don't bother scanning, takes too long.
      • Gariarto
        • Jul 2012
        • 151
        Just read this thread, sorry. I get rid of those 'FBI hijack' attacks with Malwarebytes very easily. Boot into "Safemode with command prompt" for example, on an XP PC and run a fully updated portable version Malwarebytes from a flash drive.
        IE; when in safemode with command prompt, CRTL-ALT-DEL for task manager and call Malwarebytes as a new task.
        Works for me every time, its a 5 min job. The whole scam is 2 files. No need for radical drive wiping sheesh. Its like junking your car for hard to get at spark plugs.
        • zioricci
          Folder Is empty
          by zioricci
          My Toshiba laptop stopped at the Toshiba logo when starting up, I flashed the bios and fixed it. Fortunately I had also backed up the data folder on an HP laptop with which in the meantime I reinstalled Windows 10 on the Toshiba hard drive using it as an external drive with which I am able to start the Toshiba after the problems solved.
          The real problem now is when I copy and paste the data folder from the HP back to the Toshiba hard drive, again using it as an external drive on the HP. In fact, when I put the disk back in the Toshiba, it tells me that The folder is empty but in...
          04-05-2023, 01:51 AM
        • EpicFix
          Where is the "Desktop" folder located in Windows 11?
          by EpicFix
          At the risk of sounding like a total noob I'm asking If anyone can help me locate the "Desktop" folder on Windows 11. I am trying to make a backup of all the user data from an SSD (mounted externally) that has Windows 11 installed. I was able to do this before up to Windows 10 by navigating to the User folder --> Username and there I would see the individual folders, Documents, Downloads etc. Attached is a screenshot of the folders I do see within the Users / Username folder. Any help locating the desktop folder will be greatly appreciated. Thanks in advance to the community. ...
          07-12-2025, 07:14 AM
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
        • Hinkz
          Lenovo m90q gen 4 hidden BIOS settings.
          by Hinkz
          Hello All,
          I recently upgraded my Lenovo m920q to a m90q gen4 (13th gen intel).
          I had much success following some very helpful guides on unpacking the m920q BIOS that Lenovo had on their website to find out hidden options such as cfg lock & overclocking lock, then using grub to change these settings.
          I'm having much less success with the m90q gen4 and latest BIOS on the Lenovo website (https://support.lenovo.com/us/en/dow...tation-p3-tiny), when I unpack this BIOS and use UEFITool to browse its contents I can't seem...
          06-28-2024, 05:37 PM
        • zlr8r
          Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
          by zlr8r
          Greetings
          I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
          Serial Number: 5CG3202C16
          Product #/SKU: 739P0AV
          CT Number: PRTUE00WBI30YX
          Description: HP ZBook Firefly 14 inch G10
          BuildID: 23WWWGAZ602#SABU#DABU
          Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
          MAC address not found.
          • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
          10-28-2025, 01:56 PM
