Anyone running SSD's yet?
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Title says it all. I find the technology interesting, but I've heard too many horror stories to bother trying one yet. Has the technology matured enough to be as stable as a mechanical hard drive?
    A man convinced against his will is of the same opinion still.
  • digge
    • Apr 2006
    • 296
    Re: Anyone running SSD's yet?
    Ive been running SSD for quite some time now, no issues whatsoever. Dont know what horror storries youve heard. If you stick to the more stable brands, in this case i think intel and samsung are among the top quality/stability wise there is not much that should go wrong. Some if not all manufacturers have had their share of firmware issues but they are usually solved quite fast and patched. So as long as you dont buy a brand spanking new model there shouldnt be any issues.
    • delaware74b
      • Apr 2009
      • 628
      I am in the process of loading Win 7 on my wife's 6 year old Compaq along with all of her files. I ordered a SanDisk Ultra SDSSDH-120G-G25 2.5" 120GB SATA II SSD along with a copy of Win 7 Home Premium 32-bit. Her machine is already maxed out at 2GB RAM, so no x64. It scores a 7.2 in the windows hard disk performance test.
      So far, the laptop is faster than the old setup, 80GB Seagate and Vista. Officially HP/Compaq does not support Windows 7 on this model (Presario C502us), but I didn't have any problems with drivers through Windows Update.
      Stupidity should be a crime, especially for drivers. I have NO patience for them.
      • smason
        • 1652
        One as the only drive in my notebook, one as the c: drive in my desktop. Both super fast and stable.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          off-topic:
          My Dell Latitude D630 currently runs a 160gb WD scorpio blue (5400RPM) hdd... how big of a speed/ battery life boost would going to an SSD have?
          other specs:
          cpu: c2d 2.4ghz (t7700)
          2gb 66mhz ddr2
          nvidia graphics
          sigpic
          (Insert witty quote here)
          • mariushm
            • May 2011
            • 3799
            Well... that scorpio blue uses about 2-5 watts constantly when motor runs.
            later edit: actually, the data is on their page, https://cdn.badcaps-static.com/pdfs/...c0ec73fc80.pdf :
            5 VDC
            Read/Write 500 mA
            Idle 400 mA
            Standby 45 mA
            Sleep 38 mA
            Power Dissipation
            Read/Write 2.50 Watts
            Idle 0.85 Watts
            Standby 0.23 Watts
            Sleep 0.19 Watts
            from pdf:
            Average power requirements (W)
            Read/Write 2.5
            Idle 0.85
            Standby/Sleep 0.20
            A ssd uses about 0.2 w idle, about 0.2-1w when reading, about 1-4w when writing. Intel 520 advertises: Power - Active - Up to 850mW (TYP), Idle: 600 mW (TYP) , so idle 0.6w, 0.85w when running.
            So you'll get some extra battery life , maybe 10-20% extra?
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              off-topic:
              other specs:
              2gb 66mhz ddr2
              nvidia graphics
              You will use -more- battery.
              The V and A ratings on you mechanical drive are max for full speed.
              Mechanical drives spin down to a low power state.
              SSD's don't so the ratings are full time.
              http://www.tomshardware.com/reviews/...ry,1955-2.html
              Mann-Made Global Warming.
              - Dr Seuss
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                I see... I am a bit of a road warrior so maybe an SSD is a poor investment...
                sigpic
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  5 VDC
                  Read/Write 500 mA
                  Idle 400 mA
                  Standby 45 mA
                  Sleep 38 mA
                  Power Dissipation
                  Idle 0.85 Watts
                  Standby 0.23 Watts
                  Sleep 0.19 Watts
                  from pdf:
                  Read/Write 2.5
                  Idle 0.85
                  Standby/Sleep 0.20
                  No you won't.
                  The wear leveling algorithms in SSD's keep them at full power nearly full time.
                  - Dr Seuss
                  • dmill89
                    • Dec 2011
                    • 2534
                    I've been running a Samsung 830 series SSD 128GB as a boot drive in my main tower since November and haven't had any problems whatsoever. It replaced an old WD Raptor, the SDD is faster and of course much quieter than the Raptor it replaced. I'm using a WD Caviar Black 1TB for as storage drive (it's been in the system since I built it). I did a clean windows install when I put the SSD in.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      I personally think they are a waste all the way around.
                      For normal tasks you just don't need one. Like you can email or browse that fast? RIGHT!
                      If you -really- need that much drive speed (say for a game) then you can get a system that takes more RAM and set up a virtual drive [RAM drive] in the extra RAM and that will get 'drive speeds' that are around 10x what an SSD can do.
                      And, unlike the SSD drive, the extra RAM isn't going to wear out.
                      - Dr Seuss
                      • smason
                        • 1652
                        off-topic:
                        My Notebook is a D830 (widescreen brother of the 630, I think)
                        The speed difference from a standard Seagate to the SSD was dramatic.
                        Boot speed, app startup and disk intensive stuff like Photoshop is waay faster.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          larger brother... the d630/20 are widescreen too.
                          maybe when SSDs use less power... the 5400rpm drive is as slow as hell...
                          sigpic
                          • Junk Parts
                            Court Jester
                            • Jun 2006
                            • 8953
                            I was toying with the idea of putting a SSD in my Hp too. It has a 1TB standard hard drive in it now. All I can tell you is that its 7200rpm. Win7 System has this to say about it. ST310005 28AS Sata. Its fast and quiet. It will also not die from a defrag. I think I will stick with it for now.
                            Mark Twain
                            John Paul Jones
                            Rod Serling
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2642
                              Here's a VERY interesting thread.
                              Basically, a bunch of people decided to sacrifice their SSD's for an extreme write endurance test. (writing data nonstop till the drives fail)
                              The results are all over the place..
                              http://www.xtremesystems.org/forums/...e-25nm-Vs-34nm
                              First post contains a sort of overview so you don't have to read all 3611 posts on 145 pages
                              The testing was done as close to real life scenarios as possible (with random data on the drive, some space left free for wear levelling, etc.)
                              The Samsung 470 series was the most predictable IMO, but clearly not the best in terms of amount of data written etc.
                              • b700029
                                Banned
                                • Sep 2010
                                • 640
                                First of all, that article is nearing 4 years old now. SSDs were quite power-hungry at the time, compared to now (although the situation is starting to change a little, see below).
                                Secondly, they're comparing battery life while continuously running benchmarks - not a typical use case. The CPU uses much more power than a regular disk when it's running at full load --- because SSDs are faster, the CPU spends less time waiting in idle for the drive to complete a read/write operation, and more time doing processing. With a hard drive, even though the drive does consume more power, the CPU spends more time waiting in an idle state, and CPU power consumption dwarfs everything else (the CPU they used in that test can consume up to 35W).
                                SSDs can have lower power consumption - see here:
                                http://www.tomshardware.com/reviews/...ve,1968-9.html
                                Keep in mind that these drives are also nearly 4 years old.
                                Intel was the first to really push the power consumption down with their X25-M : 150mW active and 60mW idle. But the later models are clearly not intended for laptop use as the power consumption is creeping up again...
                                I have an X25-M in my laptop so I can speak from experience: it does increase battery life by a noticeable amount. I upgraded from a rather old Fujitsu MHV2060BH (600mW idle, 2.1W active) and it increased battery life from ~6.5 to over 7 hours.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  I'm not buying it.
                                  If anything the algorithms have gotten more intensive so on average they are using more power than before.
                                  And choosing one of the crappiest disc drives as a basis for your argument isn't going to fly.
                                  Neither is a single sample example.
                                  There's also that they don't have room for much bulk storage so if you need to to keep things you don't use much available [photos, programs] when on the road you end up needing a second drive.
                                  - Dr Seuss
                                  • cheapie
                                    null
                                    • Jul 2010
                                    • 849
                                    I once got a Wintec 64GB SSD. It developed several thousand bad sectors within a month. I went back to hard drives.
                                    • Mad_Professor
                                      A Mech Warrior
                                      • Feb 2011
                                      • 1587
                                      That's because you bought a wintec. Stick with INTEL or SAMSUNG!
                                      My intel 320 series 160GB SSD still going strong, it's nearly a year old. I bought it in may 2011, I never had a problem with it.
                                      • Wrog
                                        • Oct 2009
                                        • 472
                                        I've been running a couple of Kingston V100+ 64GB SSDs as OS drives (two different desktop systems and one laptop) for a few years now with zero issues. They do their own wear leveling (not OS dependent) and although they are not nearly as fast as today's SSDs, they are still a huge step up performance-wise over magnetic drives. We store our documents, pictures, media etc. on a dedicated file server so the only things local are the OS and installed apps, so we don't need much local space. We recently added a new desktop to the network with a Patriot Pyro 120GB SATA III, and it definitely seems much faster than the Kingstons. Time will tell how long it will last!
                                        • FALKLAN
                                          Running Line Voltage and Integrating LED Pods - Automotive
                                          by FALKLAN
                                          Howdy everyone! I hope all is well where ever you are!
                                          I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                                          I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                                          02-05-2025, 12:30 AM
                                        • rumpumpel1
                                          ThinkPad X1 Carbon 4th Gen running only at 400 MHz
                                          by rumpumpel1
                                          Oberservation:
                                          X1 Carbon 4th Gen runs very slowly. Task manager shows the CPU running at 400 MHz.
                                          In rare cases (1 out of 20) it runs at normal speed.
                                          It does so when running on battery or only with the charger.
                                          When both are connected - charger and battery (50% charged) - the system switches between charger and battery once per second.
                                          The laptop does exactly the same thing when running Windows or Linux, so OS level problems can be ruled out.
                                          Flashing CleanME and a different BIOS made no difference.
                                          Intel's XTU utility...
                                          09-18-2023, 06:13 AM
                                        • Kambi13
                                          Samsung NP370E4K No backlight running on battery
                                          by Kambi13
                                          Hi all, need some help. I have a Samsung NP370E4K-KD2BR, which as a 5th Gen Intel CPU that works fine when running with the charger plugged in, but has soon as I remove it and it's running on battery the screen backlight goes off.
                                          Tried different battery - no change
                                          Tried different screen - no change
                                          Removed the plastic film from the screen inverter and looked for pwm signal which as about 3.3v when running with the charger plugged in, when I take it off the voltage drops down to 2.232v, so my best guess is that the EC is not providing the correct voltage....
                                          09-04-2023, 11:06 AM
                                        • Skgod
                                          Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu
                                          by Skgod
                                          Hey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
                                          Black screen, freeze
                                          The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
                                          When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
                                          So can anyone tell me what would be the possible cause?...
                                          10-16-2024, 08:11 PM
                                        • Comp_Pro
                                          820-01949 Running Slow Fast Fan ASD Software Download?
                                          by Comp_Pro
                                          Hello all,
                                          I'm trying to repair this A2251 macbook pro. Board is 820-01949. The original issue was liquid damage which all cleaned up well and the board was not heavily damaged. Unfortunately after liquid damage cleaning the computer is running extremely slow and the fan is running at full speed. Even the cursor is lagging. Because of this I can't use the built in hardware diagnostic to give me a clue as to what is happening. Does anyone know if Apple Service Diagnostic software is available for this model? Any other clues which could help me out? Seems to me there is an issue with...
                                          11-30-2023, 05:33 PM
