Anyone running SSD's yet?
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    #81
    Re: Anyone running SSD's yet?
    I recently had an AMAZINGLY fucked up time with a SSD just a few days ago
    customer had bad sectors appearing on her old drive, lock ups and wait times, took the computer home, it was seagate going bad (seatool confirmed it with basic test)
    Had to get a new drive for this system (HP /w Phenom II X4 8xx series). Frys had a 860 Pro 512GB for $149 (also had a 1TB on sale for $199! but I didn't take it, they weren't using much space, mainly used the computer for email (outlook) and facebook (chrome). Win10 upgrade
    Installed Win10 fresh from flash drive. Used windows built-in driver finder on the ahci controller (update driver button) an it installed as I expected the usual "AMD SATA Controller". Driver from 2010. This is when problems started. It seems with this motherboard (AMD 785G/SB 700), loading the driver on an SSD will cause a bus "reset", or in other words, cause windows and programs to freeze for 20 seconds, every minute or so. So I tried an even more updated driver (2013). When I tried to load it, it failed saying "invalid data". Well damn, ok, so I tried to reinstall the original generic ahci driver. Same thing, "invalid data". Deleted the driver. Booted back with it (after this I attempted to restore the original generic ahci driver...invalid data). Set a restore point and set to "delete the driver". I've had windows 7 in the past boot to generic doing this. But it didn't work. Took a few seconds of the wheel to get the dreaded "invalid_boot_device". Booted to USB win 10 installed to go back to a restore point I specifically set before doing this. Unable to set restore point. Hooked the ssd up to my other system to try to copy the "regback" registry files....they were all 0b. aaaand fuck
    wiped and re-installed win-10, this time installing with the latest sb700 driver from amd (2017)....Same fucking lockups.
    But this time, It let me go back to the generic driver and work flawlessly. Only a little slower than the AMD driver on boot. Still very fast.
    I think this system was not built for the kind of SSD bandwidth this thing put out, and having so much over. The error I was getting in windows logs was "Reset to device, \Device\RaidPort0, was issued." Even though there was no raid enabled, I think this bandwidth confused amd's driver and the bios (which I updated to latest when this first started happening) thinks there is something wrong. I researched this and tried all kinds of power stuff but pretty much all of what I saw didn't relate to this chipset. Or even win10
    How I know. When I got the 2017 driver in, it actually locked up much less, but I used the speed tester with the samsung magician software and thats exactly when it started resetting, when it bus was seriously full.
    I don't think it's a win10 issue. I think it's a motherboard bios issue in the end. Win10 works great from a fresh install. It's what they've been using since the free upgrade offer
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3264
      • Singapore
      #82
      hp system huh? im just going to put it down to oem bios weirdness causing all sorts of strange fockups. guess the too new and modern ssd isnt compatible with the hp system...
      have u tried swapping the sata cable tho? i had a bad/dodgy sata cable causing data transfer errors during high disk throughput. if the sata cable quality is dodgy, it can cause udma crc errors and sata link resets during heavy disk io throughput if the controller detects too many data transfer io errors.
      • FALKLAN
        Running Line Voltage and Integrating LED Pods - Automotive
        by FALKLAN
        Howdy everyone! I hope all is well where ever you are!
        I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
        I am uncertain how to convert this line into a switched 12v output line for the LED pods....
        02-05-2025, 12:30 AM
      • rumpumpel1
        ThinkPad X1 Carbon 4th Gen running only at 400 MHz
        by rumpumpel1
        Oberservation:
        X1 Carbon 4th Gen runs very slowly. Task manager shows the CPU running at 400 MHz.
        In rare cases (1 out of 20) it runs at normal speed.
        It does so when running on battery or only with the charger.
        When both are connected - charger and battery (50% charged) - the system switches between charger and battery once per second.
        The laptop does exactly the same thing when running Windows or Linux, so OS level problems can be ruled out.
        Flashing CleanME and a different BIOS made no difference.
        Intel's XTU utility...
        09-18-2023, 06:13 AM
      • Kambi13
        Samsung NP370E4K No backlight running on battery
        by Kambi13
        Hi all, need some help. I have a Samsung NP370E4K-KD2BR, which as a 5th Gen Intel CPU that works fine when running with the charger plugged in, but has soon as I remove it and it's running on battery the screen backlight goes off.
        Tried different battery - no change
        Tried different screen - no change
        Removed the plastic film from the screen inverter and looked for pwm signal which as about 3.3v when running with the charger plugged in, when I take it off the voltage drops down to 2.232v, so my best guess is that the EC is not providing the correct voltage....
        09-04-2023, 11:06 AM
      • Skgod
        Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu
        by Skgod
        Hey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
        Black screen, freeze
        The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
        When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
        So can anyone tell me what would be the possible cause?...
        10-16-2024, 08:11 PM
      • Comp_Pro
        820-01949 Running Slow Fast Fan ASD Software Download?
        by Comp_Pro
        Hello all,
        I'm trying to repair this A2251 macbook pro. Board is 820-01949. The original issue was liquid damage which all cleaned up well and the board was not heavily damaged. Unfortunately after liquid damage cleaning the computer is running extremely slow and the fan is running at full speed. Even the cursor is lagging. Because of this I can't use the built in hardware diagnostic to give me a clue as to what is happening. Does anyone know if Apple Service Diagnostic software is available for this model? Any other clues which could help me out? Seems to me there is an issue with...
        11-30-2023, 05:33 PM
