The Hall of Shame - Badcaps Photo Montage
This is a sticky topic.
  • japlytic
    • Oct 2005
    • 2086
    Re: The Hall of Shame - Badcaps Photo Montage
    If a large can capacitor (like the Elna a few posts ago) feels lighter than expected, you could have a fake on your hands.
    • ferynov
      • Dec 2006
      • 18
      #242
      in my case fake ELNA is very weight, because inside them filling up with something like bitumen / asphalt that stinky.
      • lti
        • May 2011
        • 2547
        Here are some good ones...
        The first two are a FU-YU and a Jackcon pulled from an Emerson ghetto blaster that was made in 1999. I think the first brand nane would be more appropriate if they left out the first U.
        Next, there is a JEC that was pulled from a set of computer speakers. I measured 11.38V across it, and it is only rated for 10V.
        Finally, there is another set of computer speakers that is full of Fujicon caps. The two that are bad are the output coupling caps.
        • lti
          • May 2011
          • 2547
          I just remembered that every Fujicon cap except for the four 0.47uF 50V caps were bad. I don't have an ESR tester, but they all had very low capacitance. The 0.47uF caps gave me the correct capacitance value.
          • moola
            Banned
            • May 2011
            • 20
            #245
            Skywell caps are bad too. I should be able to provide a picture. Should I?
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              #246
              Successful recap-Dell Dimension E521. Rubycon 6.3/1800 MCZ's with some Pannys
              edit: Yes I know its an nvidia 6 chipset with some KGZ's. but if the thing has lasted this long with a COMPLETELY blocked airflow, those KGZ's are probably going to be OK. Most of them are under 470uf, everything else is rubycons (except for the pannys I put in)
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                And you're calling other people nerds?
                https://www.badcaps.net/forum/showpo...2&postcount=12
                WATCH OUT! - This guy is a nerdist!
                Mann-Made Global Warming.
                - Dr Seuss
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  #248
                  its sarcasm. get used to it
                  i'm a nerd too, but not like you. You make money, have better equipment, have much more XP, have gotten laid
                  • B757
                    • Jul 2011
                    • 10
                    #249
                    Smithfield (90nm) Pentium D's in an SFF case can apparently kill a Rubycon:
                    Also some swelled up KZJ's.
                    It's an SFF Dell Optiplex 745.
                    • c_hegge
                      • Sep 2009
                      • 5219
                      I'd say it's time for a poly-mod.
                      • B757
                        • Jul 2011
                        • 10
                        #251
                        Sorry, new here, but I presume you're saying I should replace them with polymers?
                        I'm definitely going to upgrade to Core 2 if I resuscitate this thing. An E6300 is $30 used and is faster, uses less power, and runs cooler.
                        • c_hegge
                          • Sep 2009
                          • 5219
                          Yes, I meant replace with polymers.
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            #253
                            Another explanation: The KZJs bulged (they have heat issues) and the Rubycon took all the ripple... Combine that with the heat of the Pentium D in as SFF case and here is what made it fail.
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              As far as I know legitimate MCZ come in black with gold lettering, not black with white lettering.
                              May have been previously recapped by someone that got counterfeit caps on ebay.
                              - Dr Seuss
                              • c_hegge
                                • Sep 2009
                                • 5219
                                No, MCZs do also come in black and white like B757's board. I have seen it and so has topcat. My guess would be that the black and white ones are
                                from a Malaysian or other non-japan rubycon factory.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Unless the vents are shaped like these.
                                  http://cgi.ebay.com/NEW-Rubycon-6-3V...item53e79d0c90
                                  There is too much crud on that cap to see the shape of the vent.
                                  - Dr Seuss
                                  • Uranium-235
                                    Comrade Glimmer
                                    • Aug 2007
                                    • 5042
                                    • US
                                    #257
                                    those are so fake its funny, it looks like they're not even trying, look at that one with the label pulled up almost all the way up
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Not to mention the wrong vent.
                                      - Dr Seuss
                                      • KeithMcC
                                        • May 2011
                                        • 3
                                        #259
                                        These are 250V 150UF Samyoung caps in a plasma TV.
                                        I didn't notice the bulgy ones until I looked at them at a low angle.
                                        When I put a straight edge across them they were bulging the thickness of the plastic sleeve.
                                        • Pentium4
                                          CapXon Be Gone
                                          • Sep 2011
                                          • 3741
                                          KZG caps from a Biostar S939 mobo
