Anything worse than GSC???
  • Shocker
    Banned
    • Dec 2011
    • 635
    Maybe, somewhere, there's a capacitor brand that's even worse than GSC. In fact, I doubt there isn't. Any examples???
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Anything worse than GSC???
    Maybe Canicon or Sacon...
    • Shocker
      Banned
      • Dec 2011
      • 635
      Sacon is another name for GSC. I don't know about Canicon.
      • Hemingray
        KABOOM!
        • Jul 2010
        • 143
        fuhjyyu?
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Guys,
          GSC, evercon, and sacon IIRC are one and the same.
          sigpic
          (Insert witty quote here)
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Guys,
            sigpic
              A failed GSC... Okay, CapXon... seriously, I've replaced more of those than any other capacitor in TVs and monitors. Rubbish!
              • c_hegge
                • Sep 2009
                • 5219
                GSC/Sacon is the worst IMO. Fuhjyyu is a close second. Teapo is probably next.
                • Rulycat
                  • Apr 2010
                  • 724
                  Sapcon are pretty bad.
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    Sacon FZ is a crappy crap by itself...
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      "Chhsi" seems to be as bad.
                      And 1000 uF+ Lelon is in a similar league.
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                        master hoarder
                        • May 2008
                        • 12175
                        The absolute worst is Rulycon (the fake Rubycon). The eletrolyte in those caps will break down regardless of whether they are run near their limits or not. In fact, they will go bad without being used.
                        BIG GAP
                        Second place I award to Stone caps. They will bulge at the slightest presence of heat.
                        A not so distant third, I would say Sacon FZ and maybe Evercon too (but not GSC). While they may be the same company, GSC *at least* don't go bad just by sitting around and they don't make a loud popping sound like Sacon FZ does when they fail.
                        I still have a Jetway N2PAP-LITE motherboard (circa 2003) with the original GSC ME caps. Works fine. I use it every now and then to test hardware and play some older games.
                        Fourth: CapXon. Heat them up a bit, and they'll hatch.
                        Fifth: All other crap caps. I don't consider Fuhjyyu that bad. Sure there were lots of failures in the early Antecs, but keep in mind that those older Antecs had retarded fan speed controllers, so it's not all Fuhjyyu's fault.
                        I have a Macron Power MPT-301 PSU that originally had all Fuhjyyu caps. Got it for free because the fan was stuck. The stuck fan caused some serious darkening of the PCB near the secondary heat sink. Guess what? - Those Fuhjyyu caps that were near it were bulged, but those that were a bit more far away were not. I fully recapped this power supply in 2008 or so. This year, I finally tested those Fuhjyyu caps. The bulged caps obviously tested bad on ESR, but the non-bulged ones tested fine - that's nearly 4 years after they have been pulled out of that power supply. So Fuhjyyu is far from being the worst.
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          Like *cough cough* my 2005 SmartPower 2.0 500W.
                          The fan controller for the outer fan is one of the worst on the planet!
                          Arc A770 16 GB
                          • dmill89
                            • Dec 2011
                            • 2534
                            Nothing a resistor can't fix. See my post on a fan mod and recap of a SmartPower 2.0 350w.
                            But yah, the way they come set up from the factory is pretty bad. It causes them to run hot even under a light load, putting similar stress on the components as running it at near 100% all the time.
                            • lti
                              • May 2011
                              • 2553
                              My mom has a boombox with a mixture of Rulycon, Jackcon, and an assortment of unknown no-name caps. The Jackcon caps had failed, but the rest were still good.
                              I have an old ISA card with GSC caps on it. I don't know how old the card is, but the caps are still good.
                              The worst caps I have seen are Jackcon, these, and "SS" brand caps, as shown in the pictures below.
                              • Pentium4
                                CapXon Be Gone
                                • Sep 2011
                                • 3741
                                Aren't Viva pretty terrible too? And CapXon are pretty bad but seem to do decently in power supplies.
                                • Scenic
                                  o.O
                                  • Sep 2007
                                  • 2642
                                  Nope.avi
                                  Open up any recent (past 5 years or so) Fortron ATX PSU, or one based on a FSP (like almost all Zalman, most be quiet, some Cooler Master, ...). You're guaranteed to find bad CapXons, even if the unit isn't even 2 years old..
                                  Same thing happens in a lot of LCD monitor PSUs.
                                  CapXon seems to be the modern capacitor plague for PSUs of any kind, much like Sacon was (is?) for graphics cards.. (or Fuhjyyu for Antecs)
                                  They'll last a bit longer than 1 1/2 years till they start to bulge. By the time the 2 year warranty runs out, it's just a matter of weeks or months till the device stops working properly.
                                  For recent Fortron PSUs, it seems like there's always a 25V 100uF cap in the 5VSB circuit that dies first, preventing the PSU from starting up (ticking or completely dead). Most of the time, some of the secondary side caps are already puking as well (oddly enough, the ones on 3.3V seem to go first)
                                  edit: @ lti: that's not an ISA card.. that's the controller board out of a CD-ROM drive lol
                                    CapXon are the worst in power supplies! Never, ever say they are good!!! I have pulled loads of them from LCD TVs and computer PSUs. They bulge like nothing else after about 2 years. They are completely incompetent when it comes to engineering a good cap.
                                    • Wester547
                                      • Nov 2011
                                      • 1268
                                      • USA.
                                      Has anyone here seen CapXons bulge if used as primary capacitors in PSUs or just on the secondaries?
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        Not in my own equipment (I don't like CapXon and I replace CapXon primaries when possible), but if you have a look around the Audio forum here, you're bound to find more than a dozen amplifiers with bad CapXons on the primary.
                                        Also, IIRC, there was a picture somewhere (not sure if on badcaps.net or elsewhere) showing the 2 CapXon caps of a PC PSU completely burned, and it wasn't the MOVs or anything else that caused it either - it was the CapXons.
                                        CapXon caps also like to go O/C or high-ESR when used on the primary of a PSU with APFC.
