damn. I'm disappointed these high quality caps made my power supply worse
  • link626
    • Feb 2019
    • 36
    I thought my tv power supply was stable. It's been stable for a few weeks since I swapped in nichicon, united cc, panasonic caps to replace the cheap china caps.
    But today it caused my tv to have a flickering spasm again.
    what a letdown.
    I swapped back my backup power board which has cheap china caps, and the tv backlight stopped flickering.
    Sometimes these high quality caps just don't make things better.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: damn. I'm disappointed these high quality caps made my power supply worse
    what a letdown.
    Three items:
    1. Capacitors aren't the only thing that fail in PSUs. Trasistors and MOSFETs like to blow up as well!
    2. Did you get legit caps? If you got them on eBay or alibaba/aliexpress, then they very well may be fakes.
    3. Were they the right caps? The ESR has to be close, the voltage rating high enough (more is fine, less isn't unless you're sure the rail won't go too high), and the temp. rating high enough (in a TV, I would go for 105C or higher, 85C will burn/blow from the heat!). Just matching size and capacitance isn't enough.
    This all assumes the recap went well and the soldering was good... if the joints failed or something got overheated from a really rough install, all bets are off.
    sigpic
    (Insert witty quote here)
    • link626
      • Feb 2019
      • 36
      soldering was good.
      legit caps bought from mouser.
      all 105C rated, exact same capac and voltage specs as the original china caps.
      most of these new caps are low ESR, but I'm not sure if the original china caps were low ESR. I'm guessing the chinas were general purpose.
      I'm gonna swap back the cheap china caps and see if the flickering goes away.
      With the china caps, the original board did not cause backlight flicker.
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5043
        • US
        Did you take ripple into effect, not just ESR?
        Also, PSU caps don't need to be low ESR. Low ESR tends to be used for things like motherboard PSU's. If your ESR is too low, that can cause problems. Switching PSU's won't operate right without the esr and especially ripple being within a certain amount as the original caps (though the temp being higher is always better)
          • Jul 2011
          • 6070
          what a letdown.
          Can you please tell us what series of capacitors did you use
          • link626
            • Feb 2019
            • 36
            how do I account for ripple?
            I didn't intentionally buy low ESR caps. They were just the only ones available of the same dimensions as the old caps.
            These were the caps I bought...
            Mfr. #: EKYA101ELL470MJC5S
            UCC 100V 47uF 480mA ripple
            Mfr. #: UHE1E681MHD6TO
            nichicon 680uF 25 Volts 1400mA ripple
            Mfr. #: EEU-FR1H100B
            panasonic 50VDC 10uF 250mA ripple
            Mfr. #: UPZ2W820MNY9
            nichicon 450V 82uF 730mArms 730mA ripple
            Mfr. #: URY2C330MHD1TO
            nichicon 33uF 160V 130mA ripple
            Mfr. #: EEU-FC1H101B
            panasonic 100uF 50volts AEC-Q200 615mA ripple
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5043
              • US
              There are generalized caps used for power supplies, as well as some high ripple ones used too. Find who made your old caps, look at the series, and look at the usage. If they're "general", try to find decent quality general usage ones that have a close matching ripple. You will generally not see low ESR type caps used in PSU's except on the PFC controller circuit
              • brethin
                • Dec 2008
                • 1907
                The last thing to look at is size, when you can match the other 4 specs then look at size.
                • link626
                  • Feb 2019
                  • 36
                  That's the problem
                  the old HEC brand china caps have no spec sheets on google.
                  • link626
                    • Feb 2019
                    • 36
                    This power board has low clearance, and all caps must be under 16mm in height, or else the back cover wouldn't fit.
                    there weren't a lot of choices.
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      what a letdown.
                      Backlight flicker isn't regularly caused by bad capacitors... and much less if they weren't bad to begin with.
                      You need to do more troubleshooting on your end. Shottgunning parts (swapping without having identified which components are failed) is not the best way to troubleshoot (though in some situations, it does make sense.)
                      As for the discussion regarding the replacement caps not having "proper" ripple current specs or generally made for PSUs - that's irrelevant to the problem here. If the original HEC caps were truly failed and the cause of the problem, then any GP (general purpose) cap replacement would have at least gotten the set to work fine, and certainly for more than just a few weeks.
                      So again, I highly suspect the issue with the backlight flicker here isn't related to the caps at all and O/P should check the backlight system of the TV. If it's an LED-backlit TV, check for open/shorted or just plain-intermittend LEDs in the backlights (well, that's certainly easier being said than done. ) A bench PSU with high enough voltage and variable current output would be the best way to check the strips. The LED driver circuit could also have components that are bad or drifted out of tolerance. If it's a CCFL backlit TV, one or more of the CCFLs may just be approaching its EOL. Or it could be that there is a bad solder joint somewhere. A few good pictures of the bottom side of the PCBs may help spot those.
                      Other than that, good job with the recap. The replacement caps you picked are actually suitable for PSU use.
                      Now, if the TV runs really hot, more special caps may be needed... but that's unlikely to be the case.
                      • link626
                        • Feb 2019
                        • 36
                        I have another power board with original HEC caps that I swapped in
                        and the backlight does not flicker at all right now.
                        so my conclusion is the backlight is fine.
                        Even the original powerboard would not flicker like this before I replaced the caps.
                        That's why I'm thinking something is wrong with the combo of new nichicon/chemicon/pana caps I put in.
                        The new caps also caused the transformer to make buzzing noises it didn't used to have
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          I still wouldn't conclude that.
                          Consider this: every time you take out / swap the power supply, you're also moving around connectors and parts inside the TV. A bad solder joint or connector could easily cause this kind of intermittent problem to make one board seem good and the other one not.
                          I'd give it more time and use before concluding that. Also, consider the ambient temperatures in the room too. Now that Fall is coming and we get cooler weather, this too can affect any intermittent joints and connections.
                          Re-check your soldering then, along with the entire rest of the board that you worked on for possible solder joint damage from handling on other parts.
                          The cap series you used are overall quite normal for PSU use. Probably only the 100V 47 uF UCC KYA and the 33 uF 160V Nichicon RY may not be the best choices when it comes to low ESR caps, as those two aren't exactly low-ESR. But Panasonic FC and Nichicon HE are fine for PSU use. FR, FS, and FM I would say it depends on the PSU - most will work fine with them, but I have found there are PSUs that would become louder / whine after recapping with FR/FS/FM. So I don't usually recommend those, though they should work in pretty much all cases (and I personally have not seen a PSU that hasn't.)
                          As for Nichicon PZ - that's not low-ESR... but that's your input bulk cap, and it's standard for those not to be low-ESR. In fact, PZ is just a smaller version of the PT series, and the PT series is what the PlayStation 3 uses in their power supplies on the primary side (i.e. same application as in your PSU.)
                          So if you do suspect any problem with the caps, you can test your theory by swapping caps between PSUs and seeing if the problem follows. If not, then it's not the caps. On that note, if you do decide to swap caps around, try starting with the Panasonic FR first, then the UCC KYA and Nichicon RY.
                          • Robin21
                            LENOVO T490 High quality photo of CPU area needed
                            by Robin21
                            Does anyone have a motherboard from the Lenovo T490 model FT490/FT492/FT590/FT531 NM-B901 and could take a picture of the CPU area, including all the components around it? I would be very grateful.
                            During the CPU replacement process, I messed up all the resistors and capacitors, and now I can't get it to work again. The motherboard was powering up before, but now it doesn't, even with the newly installed CPU. All voltages are okay, and I don't have any shorts, so I'm assuming I'm missing one of the resistors.
                            I've also followed the schematic and Broadview,...
                            09-25-2024, 06:55 AM
                          • Biruslapio
                            Samsung's AU series "high quality" panel internally melting
                            by Biruslapio
                            I got this 55 inch AU7X00 TV, it was rebooting and showed no image only a blink of the backlights.
                            I assumed it was either panel or motherboard. Turns out it was the panel, and after applying some tape on the ribbon cable that goes to the left side of the screen, the TV turned on with image, then I suddenly noticed a dark spot and the pixels were turning black on the left edge, I was sad and thought I smashed the screen somewhere, found nothing visually, it looked in perfect condition and if it was there before it would've been noticeable while I was inspecting the TV the first time....
                            07-12-2024, 10:08 AM
                          • DXseekerMO
                            Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                            by DXseekerMO
                            Hello everyone!
                            Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                            I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                            Yes
                            0%
                            1
                            All backlight strips are the same quality
                            0%
                            1
                            No
                            0%
                            0
                            12-16-2021, 03:58 PM
                            Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                            by sam_sam_sam
                            I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                            I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                            I tested the battery cells there are installed right now and they are testing good with no issues that I...
                            02-04-2025, 08:08 PM
                          • DynaxSC
                            Extreme High Current & Low Voltage Short Killer ??
                            by DynaxSC
                            Hi Folks
                            I'm looking for a extreme high current short killer solution for a reasonable cost.
                            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                            After taking off the socket, the shorts dissappear again.
                            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                            10-15-2024, 10:13 AM
