Calculating ESR from tan delta -- tan delta's dependence on capacitance
  • Junkrepair
    • 40
    I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
    I found this nice little description of the conversion:
    Calculating capacitor ESR from Tan(delta)
    https://forum.digikey.com/t/calculat...-from-tan/2633
    It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula for ESR. It gives an example Rubycon datasheet that states:
    "When capacitance is over 1000uF, tan delta shall be added 0.02 to the listed value with increase of every 1000uF"
    The Sacon datasheet says something similar but even more ungrammatical:
    "Note Above DF Specifications shall be 2% added for every 1000uF capacitor exceeding 1000uF."
    https://www.badcaps.net/forum/attach...8&d=1686507774
    The Sacon datasheet gives a tan delta of 0.22 for a 6.3V 1000uF cap.
    I have these questions:
    1) For a 6.3V 3300uF cap, would tan delta be increased by
    a) ((3300-1000)/1000)*0.02
    or by
    b) ((3300-1000)/1000)*0.02*0.22
    or by something else ?
    2) For a capacitance less than 1000uF, say 470uF, would tan delta be decreased below the value for 1000uF?
    3) What is "DF Specification" mentioned in the Sacon datasheet?
  • Junkrepair
    • 40
    Re: Calculating ESR from tan delta -- tan delta's dependence on capacitance
    3) DF = dissipation factor
    • lti
      • May 2011
      • 2558
      That datasheet does show ESR on page 5.
      • Junkrepair
        • 40
        So you are saying that ESR and impedance (20 deg and 100 kHz) are the same? I'm not finding it stated that simply elsewhere.
          master hoarder
          • May 2008
          • 12175
          ESR and impedance are not the same, but they are more than close enough for these type of consumer electronics and thus can be considered equivalent. Same with most ATX SMPSs.
          I can't give an answer to your specific questions in post one... but all I will say is, don't sweat it with reading too much into Sacon's datasheets. They were/are garbage caps to begin with and probably never met that spec anyways (or not for too long after leaving the factory, either way. ) By the looks of it, they are just "average" low ESR caps. Given the age of this motherboard, you can just use something like Panasonic FM/FR/FS series or equivalent from other manufacturers (Nichicon HV/HW, Rubycon ZLH/ZL/ZLG, United Chemicon KZH/KZM.) Actually, from experience, I can tell you that even "lower" grade low-impedance caps will work (the likes of Nichicon HE, United Chemicon KY/KZE, and Rubycon ZLQ.) As for caps around the CPU (particularly those filtering V_core), you can also go with polymers with down to half of the capacity of the originals... though if you can get closer to the capacity of the original caps, that would be better.
          • lti
            • May 2011
            • 2558
            Yeah, people interchange impedance at 100kHz with ESR a lot. Caps usually specify impedance at 100kHz or 120Hz instead of ESR.
            These are an ultra-low-ESR series similar to Nichicon HM or Rubycon MBZ. None of those are made anymore, so you'll have to pick something close. You can even go for polymer caps of similar capacitance at that point, but such large polymer caps are harder to find. I see a lot of people using slightly higher impedance caps, but still as low as they can find.
            • AleXis6
              • Feb 2021
              • 69
              • Belarus
              an example impedance vs ESR (I found a datasheet with both)
              • Junkrepair
                • 40
                Thanks for all the replies. You've cleared things up a lot. I'm working on selecting some specific caps. I'll have some more questions.
                  MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
                  This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-07-2024, 03:40 AM
                  MSI Delta 15 A5EFK-081AU Notebook 15 Specification for Upgrade or Repair
                  This specification for the MSI Delta 15 A5EFK-081AU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-081AU boardview and 15 A5EFK-081AU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-07-2024, 06:11 AM
                  MSI Delta 15 A5EFK-046UK Notebook 15 Specification for Upgrade or Repair
                  This specification for the MSI Delta 15 A5EFK-046UK Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-046UK boardview and 15 A5EFK-046UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-07-2024, 05:50 AM
                  MSI Delta 15 A5EFK-088NL Notebook 15 Specification for Upgrade or Repair
                  This specification for the MSI Delta 15 A5EFK-088NL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-088NL boardview and 15 A5EFK-088NL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-07-2024, 04:30 AM
                  MSI Delta 15 A5EFK-036XFR Notebook 15 Specification for Upgrade or Repair
                  This specification for the MSI Delta 15 A5EFK-036XFR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-036XFR boardview and 15 A5EFK-036XFR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-07-2024, 04:10 AM
