Sony xbr65x900c sound yes, no backlight or image.
  • diif
    • Feb 2014
    • 6978
    • England
    #341
    Re: Sony xbr65x900c sound yes, no backlight or image.
    Maybe I'll use difs reflow profile, I hear he's never had a return on ANY of his reflows.
    It's diif, and you read not heard about the quality of my reflow work. I'm flattered you've been thinking about me though.
      • 12192
      • U.S.
      #342
      Right, sure DID NOT hear about it, as nobody ever verified it, AND wasn't thinking about you at all, til I read what you think about Mr. Trump. I had no idea that you are qualified to JUDGE Mr. Trumps integrity AND such an authority on the subject of AMERICAN politics. AND I don't give a flying f#%K what your name is. YOU are one of the very few people here that I NEVER could stand, period, exclamation mark. As much as I'd like to, I won't be responding to any more of your little remarks, It's against the rules AND a waste of my time. Don't know how you got off the ignore list in the first place.
      • diif
        • Feb 2014
        • 6978
        • England
        #343
        If it hadn't been for your pissy comment and getting my user name wrong, I wouldn't have commented. The poor attitude is yours not mine, I'm glad you won't be commenting further though.
          • 12192
          • U.S.
          #344
          Moderators can you do something about this HARASSMENT?
            • 12192
            • U.S.
            #345
            Thanks Unspun for replying on the other xbr thread, no I wasn't getting 12 to the tcon, Diah helped me bypass to get signal from powerboard to tcon, then there was 12 v at tcon fuse, so I guess tcon on is one of the signals that the mainboard isn't sending. It may be because I can't seem to update it properly for some reason.
              • 12192
              • U.S.
              #346
              Now I think I killed the mainboard, put the tiny parts back on, they seem to measure the same as they did before I took them off. But I heated the 9 memory chips around the sonyx1 and the x-reality pro chips to about 440 f, put the board back in, now tv is dead, I just hope I didn't kill the mainboard because I couldn't figure out how to do the firmware update/pair or because the dl board was bad.
              • german_20ar
                german_20ar
                • Jan 2020
                • 4
                • Argentina
                #347
                Hello, I have a Sony xbr-65x900c + It turns off and flashes 4 times red light sometimes it turns off after 30 seconds sometimes it takes 3 minutes it's relative! Can you help me, please! Thank you very much
                Hola, Tengo un Sony xbr-65x900c + Se apaga y parpadea 4 veces luz roja a veces se apaga a los 30 segundos a veces demora 3 minutos es relativo! Me pueden ayudar por favor! Muchas Gracias
                  • 12192
                  • U.S.
                  #348
                  There's a pretty easy test you can do to determine if it's a backlight issue, I would NOT play a tv for normal use with this bypass because it could burn everything down, because it bypasses a safety feature and they're there for a good reason, just look on youtube for xbr65x900c 4 blink fix, BUT I don't call it a fix, just a way to troubleshoot, there's a few of them they involve grounding the bl_error wire.
