Sony xbr65x900c sound yes, no backlight or image.
    • 12330
    • U.S.
    #321
    Re: Sony xbr65x900c sound yes, no backlight or image.
    i did that: did the hold power and vol - , plugged in was green/orange for about 15 seconds went solid green let go of buttons, about 10 seconds later started green/orange again. i'll try it again BUT give it more time this time.
      • 12330
      • U.S.
      #322
      tryin now, doing reset, blinked orange/green for only a few seconds, went solid green pretty quickly this time, let go of buttons, blinking orange/green for a while, stopped for a few seconds then back to orange/green blinking, watching the indicator now.
        • 12330
        • U.S.
        #323
        ok it stopped, indicator light is off. it was anyway for 15 seconds then solid green for 5 seconds, now its off again.
          • 12330
          • U.S.
          #324
          guess its time to cook the mainboard like a pizza.
          • Diah
            • Feb 2013
            • 6574
            ist dead??
              • 12330
              • U.S.
              #326
              did not cook it, but its same as before, music no picture or backlight, heated some crap with a hairdryer, no change but i didnt expect any, theres 2 pretty big heatsinks covering the chips.
                • 12330
                • U.S.
                #327
                theyre selling the e-nand some places for like 60 dollars, seems VERY high to me, dont know if that would fix it, looks like a used mainboard is probably more than the value of this tv if working.
                  • 12330
                  • U.S.
                  #328
                  wonder if this is a good candidate for a universal mainboard?
                  • Diah
                    • Feb 2013
                    • 6574
                    where are you thinking.. just try replace your tiny friends IC9017 LOL
                      • 12330
                      • U.S.
                      #330
                      guess i could try that, not much to lose, mainboard seems to be the problem, not paying 150 or 200 for a used mainboard thats likely to go bad anyway.
                        • 12330
                        • U.S.
                        #331
                        guess ill get an ic9017 from ebay, plus got to get a microscope for sure.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          #332
                            • 12330
                            • U.S.
                            #333
                            looking closer at the mainboard, found a tiny cap short near ic9403, not short off board, coil for ic9403 read short to ground both sides, removed coil, with coil removed 1 of the coil pads read short to ground, before removal of coil and cap ic9407 was reading short from pin 5 to 6, after removal of cap and coil, the short from 5 to 6 of ic9407 is gone. Looking at ic7702 pins 3,4,6,7 all read short to ground, removed ic7702 and only pad 3 is short to ground and pads of ic on the board read short from 3 to 4,6,7 that is measuring from pad to pad. I think ic7702 is 9d6a3w or 906a3w, couldn't find a datasheet or any info. about such a chip, it's very small. you think this could be a condition caused by bad bga solder contact? the thermal paste was dried up and useless under the 2 big heatsinks.
                              • 12330
                              • U.S.
                              #334
                              No clues? If I could understand hindi, I would have had it fixed by now, are they really that far ahead of the rest of the world?
                              • Diah
                                • Feb 2013
                                • 6574
                                good if you catch hindi..LOL .. all what i know you have the following all related to BL
                                2.3v on bl-error High.
                                on G1B board theres 39.5v on pin 1 and 2 which it should >60.V
                                on main boards U COM IC9017 pin 17 PANEL_PWER_ON 0 Zero.
                                on main boards U COM IC9017 pin 18 BL_ON 0 Zero
                                you are now testing caps or coil on MB... we said it could be the IC defect because you said as sure yours edge BL strips all good.
                                  • 12330
                                  • U.S.
                                  #336
                                  thats mostly right but 17 does have 3.4v on ic9017, I don't think the backlights are making these shorts on mainboard, did short testing with mainboard out of tv. I think post #333 tells the tale of what could be wrong but I'm not sure what it means. probably just going to reflow the chips under heatsinks and see if those shorts go away. don't have the 20/20 or the patience for this micro-soldering bs, its micro to my eyes anyway, when a hobby turns into a chore, might be time for a new hobby.
                                    • 12330
                                    • U.S.
                                    #337
                                    Maybe I'll use difs reflow profile, I hear he's never had a return on ANY of his reflows.
                                    • Diah
                                      • Feb 2013
                                      • 6574
                                      since when you have 3.4V on pin 17 IC9017 ?? if you where correct then you should have >12V on T-con fuse.. but you have 0.11 as you said.. !!
                                      on pin 19 you have 3.4 and this is power on and its correct
                                        • 12330
                                        • U.S.
                                        #339
                                        ok, 17 and 19 have 3 volts, 18 has 0v, while testing when the music was on i would touch 18 and music would stop and go back to orange green blinking, tiny work, taped needle to probe.
                                        Have had 3 volts on 17 ever since you suggested to test them back on post #182 here.
                                          • 12330
                                          • U.S.
                                          #340
                                          Was starting to think maybe a bad harness but that would not explain the bad readings of caps and those 2 ics on mainboard because it was out of the tv during those tests..
                                          • domix
                                            Sony KD - 65XF9005 - No image, sound OK
                                            by domix
                                            at tv KD - 65XF9005 i have a problem.
                                            Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                                            is this a common problem for this tv?
                                            i attached pictures of inside. Supply board looks okey, no blowed caps....
                                            07-21-2025, 06:37 AM
                                          • rimwall
                                            Sony KD-65x7500D - double image - Tcon or Panel?
                                            by rimwall
                                            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                            11-18-2025, 02:09 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • shahnld
                                            Sony kdl 65xg9505 green amber blinking
                                            by shahnld
                                            Good Day.
                                            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                            01-03-2024, 03:05 PM
                                          • alegatorul
                                            sony bravia kdl-43w756c, no power, no sound
                                            by alegatorul
                                            the charger brick has 19,2-19,3 vcc
                                            changed the inverter board same result.
                                            where should i start?
                                            cheers
                                            11-15-2025, 10:00 AM
