Sony xbr65x900c sound yes, no backlight or image.
  • Diah
    • Feb 2013
    • 6587
    Re: Sony xbr65x900c sound yes, no backlight or image.
    if you by mistake touched next pin to 18... then need to do this
    pin 17 = PANEL_PWER_ON it should read >3.0V okay.. if no change IC
    pin 19 = power on >3.0V okay
    then while the tv out from wall check pin 18 of this IC if it read short with chassis... if yes then need to replace the IC
    If BL_MUTE (R9174) is 0V and pin 18 read >3.0V and its not shorted with chassis... need to replace IC91017
      • 12330
      • U.S.
      #182
      ok, 17 and 19 have 3 volts, 18 has 0v, while testing when the music was on i would touch 18 and music would stop and go back to orange green blinking, tiny work, taped needle to probe.
        • 12330
        • U.S.
        #183
        tested 18 not shorted.
          • 12330
          • U.S.
          #184
          cn9000 not marked but i got 12 volts on the 7th 8th and 9th pin counting from left to right, those are all on the top, bottom pins will be hard to get at but i will if needed.
            • 12330
            • U.S.
            #185
            https://www.shopjimmy.com/sony-a-207...ftware-update/
            • Diah
              • Feb 2013
              • 6587
              common... each function pin of this IC should have test point arround the IC. so no need to do it direct on the pins. turn off the tv and test each pin you like to find its test point to avoide shorting later.
                • 12330
                • U.S.
                #187
                https://www.shopjimmy.com/sony-15st0...r-xbr-65x900c/
                  • 12330
                  • U.S.
                  #188
                  https://www.shopjimmy.com/sony-6871l...a-t-con-board/
                    • 12330
                    • U.S.
                    #189
                    this one says G1C looks to be the same as my G1B: https://www.shopjimmy.com/sony-1-474...-supply-board/
                    • Diah
                      • Feb 2013
                      • 6587
                      if pin 17 =>3.V mean the panel if its in place you should see image via tourch or if you turn on one line BL with yours tester.
                        • 12330
                        • U.S.
                        #191
                        those are better than i can take with this lighting situation, winter here, just about every day is cloudy dark and dreary, lol.
                        • Diah
                          • Feb 2013
                          • 6587
                          what are you talking about.... yours PCB okay... never touch it or messure any on it..LOL afraid your eyes will shorted it.. i asked about yours LED driver boards..
                            • 12330
                            • U.S.
                            #193
                            "If BL_MUTE (R9174) is 0V and pin 18 read >3.0V and its not shorted with chassis... need to replace IC91017" is this resistor R9174 near IC91017?
                              • 12330
                              • U.S.
                              #194
                              lol, ok, just threw that sub powerboard in there in case you wanted to see it.
                              • Diah
                                • Feb 2013
                                • 6587
                                yes down side IC little to the left... check the r if its Lor H as its mute BL
                                  • 12330
                                  • U.S.
                                  #196
                                  ld board is in post #187.
                                  • Diah
                                    • Feb 2013
                                    • 6587
                                    okay understand let clear the supject of the IC9017 pin 18 first.
                                      • 12330
                                      • U.S.
                                      #198
                                      ok, i cant find R9174, theres lots of tiny things around IC91017, but my weaker eyes cant see it even with a magnifying glass.
                                      • Diah
                                        • Feb 2013
                                        • 6587
                                          • 12330
                                          • U.S.
                                          #200
                                          Thanks, think i got the right one, it read 562 in diode mode, it jumps around in ohm mode just like some other same looking ones I tried to measure on the board.
                                          • domix
                                            Sony KD - 65XF9005 - No image, sound OK
                                            by domix
                                            at tv KD - 65XF9005 i have a problem.
                                            Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                                            is this a common problem for this tv?
                                            i attached pictures of inside. Supply board looks okey, no blowed caps....
                                            07-21-2025, 06:37 AM
                                          • rimwall
                                            Sony KD-65x7500D - double image - Tcon or Panel?
                                            by rimwall
                                            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                            11-18-2025, 02:09 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • shahnld
                                            Sony kdl 65xg9505 green amber blinking
                                            by shahnld
                                            Good Day.
                                            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                            01-03-2024, 03:05 PM
                                          • alegatorul
                                            sony bravia kdl-43w756c, no power, no sound
                                            by alegatorul
                                            the charger brick has 19,2-19,3 vcc
                                            changed the inverter board same result.
                                            where should i start?
                                            cheers
                                            11-15-2025, 10:00 AM
