Sony xbr65x900c sound yes, no backlight or image.
    • 12330
    • U.S.
    #141
    Re: Sony xbr65x900c sound yes, no backlight or image.
    Well I'm going backwards, I put 3 iffy zeners with the over 8xx testing in diode mode in, have 170 on the big 450 v 220 uf testing cap but now have no stby or acdet voltage at the connector pins.
      • 12330
      • U.S.
      #142
      Hooked up 2 500v 120uf caps, have 168v on main caps, bridge is ok 160 dc and 120 ac, still not getting the stby or acdet on connector pins like before which just seems odd, can not seem to turn this board on with jumpers, guess I'll throw it back on the tv and see what I get.
        • 12330
        • U.S.
        #143
        Ok, Diah, I think I figured it out, IC 901 is reading short, diode mode on 4 pins in relation to neg of main cap, that seems bad. Yet when I tested for vcc and the other voltages they all tested good, hate to dig that off and scrounge up another if that isn't the problem, did I do that diode test correctly?
        • Diah
          • Feb 2013
          • 6565
          good but to late lol
          your reading could be had error... look of its pins.
            • 12330
            • U.S.
            #145
            I still can't figure out these powerboards, I have 168 v at the drain of Q600, but there's 3.5 on Q601 drain, not sure if that's normal, that's just with powerboard plugged in, removed from tv, still no stby or acdet on pins of connector. Was watching a youtube video, his IC only beeped ie showed continuity on one of the IC pins, mine beeped on the whole side, 4 pins, but it seems like the whole side is connected to the big cap, seems like they maybe should all beep???
              • 12330
              • U.S.
              #146
              About ready to throw money at a new board just to try to figure this one out, just a terrible hair pulling out nightmare.
              • vinceroger69
                • Mar 2012
                • 6714
                #147
                I have done thiis a few times brought another board to fault find mind easiest way at times.
                  • 12330
                  • U.S.
                  #148
                  Hate to do it but I tested the shit out of this thing, can't find the problem, I don't even have a light on front now.
                  • Diah
                    • Feb 2013
                    • 6565
                    we do know you... you have short patience .. so doesn't matter if you don't catch the cause with this tiny work... you were not the only.
                      • 12330
                      • U.S.
                      #150
                      No, patience isn't my long suit but I'm willing to keep at it, just can't figure out why it went from almost working to nothing but the 168 everywhere it should be but nothing else much.
                        • 12330
                        • U.S.
                        #151
                        With the temporary cap in I was getting the stby and acdet at first then it was gone, I put two 500v 120ufs in, on lead wires, have no stby or acdet and can't force it on, head scratcher???
                          • 12330
                          • U.S.
                          #152
                          Ok, what do you think about this, powerboard on bench, main caps have steady 166v, checking drain of q600, q601, q800, q801, neg probe on - of bridge rectifier and + probe on drains I might get 166v, if i take it off and put it right back on it might say 0v or 5 volts or 3.5v, ever have that problem? could it be a voltage regulator?
                            • 12330
                            • U.S.
                            #153
                            Took readings, what do you think of the difference?
                            old board shows continuity from - of bridge rec. to pin 1 of IC901 which is G/OCP, new board does not, guess that means IC901 is bad??
                              • 12330
                              • U.S.
                              #154
                              IC901 datasheet: https://datasheetspdf.com/datasheet/STR-A6069H.html
                              • Diah
                                • Feb 2013
                                • 6565
                                yes. for me it had leak
                                  • 12330
                                  • U.S.
                                  #156
                                  Thanks Diah, guess I blew it by not investigating that IC close enough, do you think it could be a bad ld board that is keeping the backlights off?
                                  • Diah
                                    • Feb 2013
                                    • 6565
                                    i know the screen out, did you got sound? and stable white indicator ? or at least the optical audio lit red on
                                      • 12330
                                      • U.S.
                                      #158
                                      plugged it in it flashed green/orange for about a minute then went out then turned green for a few seconds then went out, turned it on with remote, have stable white dim indicator and android music.
                                        • 12330
                                        • U.S.
                                        #159
                                        Still have 2.3v on bl-error pin measured on smaller powerboard called G1B.
                                          • 12330
                                          • U.S.
                                          #160
                                          On connector CN601 on G1B board theres 39.5v on pin 1 and 2, and theres 12v on pin 9.
                                          • domix
                                            Sony KD - 65XF9005 - No image, sound OK
                                            by domix
                                            at tv KD - 65XF9005 i have a problem.
                                            Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                                            is this a common problem for this tv?
                                            i attached pictures of inside. Supply board looks okey, no blowed caps....
                                            07-21-2025, 06:37 AM
                                          • rimwall
                                            Sony KD-65x7500D - double image - Tcon or Panel?
                                            by rimwall
                                            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                            11-18-2025, 02:09 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • shahnld
                                            Sony kdl 65xg9505 green amber blinking
                                            by shahnld
                                            Good Day.
                                            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                            01-03-2024, 03:05 PM
                                          • alegatorul
                                            sony bravia kdl-43w756c, no power, no sound
                                            by alegatorul
                                            the charger brick has 19,2-19,3 vcc
                                            changed the inverter board same result.
                                            where should i start?
                                            cheers
                                            11-15-2025, 10:00 AM
