Trying with the original board (MU6120) and detaching the upper flat I managed to get half the image right, if I detach the lower flat you can see the other half
Oke, thank you very much for the time! You have any idea what the problem could be? Voltages are all present and oke. The standby led flashes once about every 8 seconds
If the problem was in this firmware, then the standby indicator would not light up at all, you may have a problem in the panel, first disconnect the cable between the power supply and the motherboard and turn it on, only the backlight should light up, then connect it back and disconnect the LVDS cable from motherboards and panels and reapply power and test the TV's response.
The panel is not the problem.
The backlight and the panel are good.
maybe the chip itself is bad. I will write my old dump back to a good chip and look what it does.
maybe the bga is the problem.
I have a samsung UE43MU6125KXZT with a BN41-02568B that have the power LED off, With the CH341 I have read the memory and in attachment you have the BIN file. Is possible to Fix?
The memory is 25Q40CLSIP, I als have some problem to et the QE to 1......
