Philips 50PUS6272/05 image flipped and upside down
  • rash.m2k
    • Apr 2010
    • 64
    Seems this tv works all fine but the image is mirrored and also upside down, other than that seems to work all fine.
    Is this a bad tcon or mainboard?
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Philips 50PUS6272/05 image flipped and upside down
    have you fitted a new mainboard ? as this could cause it there maybe a way in the service menu etc too flip the image i think the menu is 062596 but dont alter anything yet as not sure there is a flip optionched this
    have you watched this? https://www.youtube.com/watch?v=UGz126wYCO4
    • rash.m2k
      • Apr 2010
      • 64
      Nope this is the original board, i have seen that video but there is no option in the menu
      • vinceroger69
        • Mar 2012
        • 6714
        can you upload pictures of your service menu screens
        • rash.m2k
          • Apr 2010
          • 64
          See attached, can't find anything about flipping the image
          • chrismurphy
            • May 2014
            • 251
            • australia
            reload firmware or go to service menu and select correct model screen
            • rash.m2k
              • Apr 2010
              • 64
              I have updated the software the screen selected is the correct one, I haven't changed the board it matches the screen
              • arge45
                • Dec 2020
                • Inglaterra
                Hola!
                Guys, Im having the same problem. Philips sent me a file to do a forced upgrade but no success on that. The image is flipped and mirrored still.Can you please share the OP1 and OP2 values. Also, sharing your experience resolving this would be very appreciated.
                • zen
                  • 511
                  Hi all
                  Been here before myself
                  The N V M with red dot next to the L V D S lead has corrupted . It holds the display data .
                  Tried re entering screen code , which is a 3 digit number , normally printed onto label at back of TV .
                  In my case screen blanked & lost picture all together .
                  To recover , managed to pull data from a working set , then program up chip on fault TV .
                  Will check to see if i have files .
                  Post the display type & part number , cheers Xen
                  • zen
                    • 511
                    Have just attached a bin file for the N V M i mentioned.
                    It's for the exact display type in picture posted & should restore image .
                    • mjn2710
                      • Jan 2021
                      Hi! I am having the same issue with the flipped image and cannot solve. Is there something I should try to do with this file?
                      • zens electronics
                        • Jan 2021
                        • 31
                        If your TV uses same display and main board , program the chip i mentioned with bin file provided .
                        • Diah
                          • Feb 2013
                          • 6343
                          not every normal user will have knowledge and tools for this tips. the best easy downgrade or update the firmware... it will take a place at NVM
                          googling will find allot sources of firmware depending on chassis and model No, for example
                          • zens electronics
                            • Jan 2021
                            • 31
                            Yes, sorry , i didn't consider that .
                            • Davi.p
                              • Sep 2009
                              • 4266
                              • Italy - Milan
                              Hi, re enter option codes in service menu, you will find them on the back cover sticker.. bye.
                              • William1967
                                • Nov 2017
                                • 203
                                • Netherlands
                                Press 062598 menu followed by the setoption number you find on the rear cover. Wait for 30 seconds and remove the power cable for a short time, reconnect the power. All options must be correct now also the display option.
                                • zen
                                  • 511
                                  Hopefully the above will work .
                                  Unfortunately in my case ended up with a completely blank display , due to data corruption of N V M i mentioned , which is why i needed to reprogram chip using good data from a working set .
                                  • William1967
                                    • Nov 2017
                                    • 203
                                    • Netherlands
                                    The way I explained works without a working display. The tv has a lot of pre programmed options onboard, you only need to program it with the so called OPTION CODE.
                                    • malekservis
                                      Philips 58PUS8536/12 Backlight ok, no image
                                      by malekservis
                                      the TV turns on fine, seems to be working, but shows no image outside of a thick white vertical line as it turns on that also disappears almost instantly, and then it's just backlight. I've tried unplugging either side, but still can't get an image. I suspect it's a panel issue, but thought i'd ask some smarter people to confirm. I haven't found any weird readings, but then again i'm just randomly poking around with a multimeter.
                                      Any information would be appreciated....
                                      08-07-2024, 07:48 AM
                                      HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                      This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                      09-12-2024, 02:20 PM
                                    • Kartowl
                                      philips 47pfl6158k/12 image faded away, sound still coming from TV
                                      by Kartowl
                                      Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                                      04-23-2024, 12:57 AM
                                    • Raulnn
                                      Tv Philips 55PUS6031 no image, backlight ok
                                      by Raulnn
                                      good night! I have this TV, with quite poor build quality. It has a tcon integrated into the panel, a single flex from the tcon to the panel, and the 2 panel controller boards joined by glued flexes. There is no way to separate them.
                                      The symptom is that the image is not visible, but the backlight works. How to know if the problem is in the main or in the tcon-panel? I can't override zones.
                                      05-14-2024, 02:11 PM
                                      HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
                                      This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                      09-06-2024, 10:56 AM
