Philips 32PFL4901/F8 BA5DFGG0201 1 Backlight is present but no image
  • alro7779
    Alex
    • May 2025
    • 65
    • Mexico
    Hello there!
    Have this Philips with no image at all. When I plug it to the outlet, it turns on without pressing the power button, and after a moment, it turns off, then starts again. I checked the 12v and 3.3v voltages on the main board connector that goes to the T-con, but it only has the former (12v). Any clues, guys?
  • alro7779
    Alex
    • May 2025
    • 65
    • Mexico
    EDIT: When I disconnect the T-con flex cable, the turning on and off loop continues. Can it be a problem with the main board?
    • alro7779
      Alex
      • May 2025
      • 65
      • Mexico
      EDIT: The power supply is sending 21v, 12v and 3.3v to the mainboard, but the latter just sends 12v to the T-con.
      • alro7779
        Alex
        • May 2025
        • 65
        • Mexico
        EDIT: Now when I press the power button, it does not turn on. Checked the voltage on the connector that goes to the control panel, and there is 3.3v, but it doesn't respond when I press the power button. What could it be this time?
        • lotas
          • Jan 2016
          • 4785
          • Russia
          So where will you get the image, if your LVDS cable is damaged, replace the cable and check if something has not been shorted or damaged by a non-working cable.
          • alro7779
            Alex
            • May 2025
            • 65
            • Mexico
            Thanks for your response!
            The problem started before having the LVDS cable damaged. However, I know I do need to replace that 30-pin ribbon cable. However now I'm dealing with this new issue... it does not turn on (no standby light nor backlight). I've found a shorted diode on the primary side of the power supply, next to a mosfet. Checked the leds with a tester and they do light on; 44 volts shows the tester and I remember getting only 21 volts on its connector after pluggin' it in to the outlet.
            PS.- I'm trying to find the schematic of the power supply. The model number is BA4GF0F0102 2 (only found a similar one... the BA3AF0F0102 1)
            Cheers!
            • lotas
              • Jan 2016
              • 4785
              • Russia
              Cheers!
              BA4GF0F0102 2
              • alro7779
                Alex
                • May 2025
                • 65
                • Mexico
                Thank you a million times for the schematic, man! 😀
                By the way, is there a section here for schematic requests?
                Cheers!
                • malekservis
                  Philips 58PUS8536/12 Backlight ok, no image
                  by malekservis
                  the TV turns on fine, seems to be working, but shows no image outside of a thick white vertical line as it turns on that also disappears almost instantly, and then it's just backlight. I've tried unplugging either side, but still can't get an image. I suspect it's a panel issue, but thought i'd ask some smarter people to confirm. I haven't found any weird readings, but then again i'm just randomly poking around with a multimeter.
                  Any information would be appreciated....
                  08-07-2024, 07:48 AM
                • Salem Aboshala
                  820-00138-A got image but no backlight
                  by Salem Aboshala
                  Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
                  I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
                  History: my laptop backlight stopped working without any reason.
                  Symptoms:
                  I have image on screen using my flashlight.
                  I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
                  Keyboard backlight still working and can be adjusted normally.
                  Since two days I tried to follow all similar...
                  06-11-2024, 03:02 PM
                • zaurus81
                  Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
                  by zaurus81
                  This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
                  The board is equipped...
                  01-16-2025, 03:54 AM
                • chestercc
                  Philips TV Backlight Repair
                  by chestercc
                  So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
                  My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
                  The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
                  11-18-2022, 01:15 PM
                • ohren
                  Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
                  by ohren
                  I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
                  The setup is basically:
                  Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
                  Transistor is switching the 3.5 V supply on the power board....
                  12-05-2024, 11:10 AM
