Philips 65PUS8518/12 distorted image after main board replacement
  • tuner2000i
    • Jun 2018
    • 26
    hello everyone,
    I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
    The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
    I am able to access 2 menus, 062596 + OK and Home+1999+backspace to enter factory menu. I am however unable to change the Panel ID which is set to 2. I tried all buttons and I can not change that value. Also I tried 062598 + Home + 016 and 062598 + Menu + 016 and nothing happens.
    I also replaced three 8 pin small chips on the board which I thought are eeprom's hoping that the settings will also update but with no luck. I am not sure where these settings are stored. If they are in the nand I do not have a reballing machine to do it anymore.
    I searched the forum for NVM file and i could not find any. I attached the NVM dump from the 55PUS8518 board if that helps.
    Any help will be kindly appreciated.
  • tuner2000i
    • Jun 2018
    • 26
    I found some SM which is not from this model but it said the code 062598 + Home + 016 should be entered from a normal RC remote. The original tv remote is both IR and bluetooth. Even though I disabled the bluetooth i tried today with a remote which is IR only again without success.
    • lotas
      • Jan 2016
      • 5296
      • Russia
      After software updates this method no longer works, the only option is to find NVM for your TPM23.1E LA chassis and for your model and panel or look for a motherboard for your panel.
      • tuner2000i
        • Jun 2018
        • 26
        thanks for the reply lotas, at least i am not wasting my time with the remote buttons anymore. I found another board but before buying, does anyone here have this NVM, if yes please share even in DM. I was not able to find anywhere NVM's newer than 2019
        • lotas
          • Jan 2016
          • 5296
          • Russia
          Unfortunately, there isn't one, but if there was, I would help you.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4688
            • Italy - Milan
            Which are the keys you press to navigate to menus in service?
            • tuner2000i
              • Jun 2018
              • 26
              I pressed Home+1999+backspace. I fixed the TV, i managed to obtain the NVM file from a local tv service. if anyone needs it, send me a DM
              • lotas
                • Jan 2016
                • 5296
                • Russia
                Yes, you found the NVM file quickly, you are lucky.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • hartleyhare5
                  Samsung QE65Q9FN — BN44-00944A (65A board) MOSFET failure (relay clicking on one connect) — advice before power-up
                  by hartleyhare5
                  Post body:
                  I'm working on my Samsung QE65Q9FN (65" Q9FN QLED, European model) with relay clicking and no picture. The power supply board in the display itself is the BN44-00944A, known on the board itself as the 65A board (silk-screened designation). There is also a second board, the 65B, which looks identical but is only partly populated for the LED power.
                  Symptom: Continuous relay clicking on the one connect — TV will not start up, no picture. However the standby LED is on constantly — so the standby supply rail appears to be alive and the...
                  03-26-2026, 03:47 AM
                • canadaboy25
                  Panasonic TC-P54VT25 No image. A or D board?
                  by canadaboy25
                  I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                  I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                  01-17-2021, 01:06 AM
                • spantor
                  Activate power board Philips 40PFH40009/88 tv
                  by spantor
                  Hello partners.
                  Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
                  The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
                  02-11-2024, 05:07 PM
