Philips 58PUS8536/12 Backlight ok, no image
  • malekservis
    • Mar 2017
    • 19
    • czech republic
    the TV turns on fine, seems to be working, but shows no image outside of a thick white vertical line as it turns on that also disappears almost instantly, and then it's just backlight. I've tried unplugging either side, but still can't get an image. I suspect it's a panel issue, but thought i'd ask some smarter people to confirm. I haven't found any weird readings, but then again i'm just randomly poking around with a multimeter.
    Any information would be appreciated.
  • malekservis
    • Mar 2017
    • 19
    • czech republic
    This IC on the right hand side driver board gets quite hot, but i can't find any shorts there, or what the IC is. The markings are 211607 2531.
    • Raulnn
      Tv Philips 55PUS6031 no image, backlight ok
      by Raulnn
      good night! I have this TV, with quite poor build quality. It has a tcon integrated into the panel, a single flex from the tcon to the panel, and the 2 panel controller boards joined by glued flexes. There is no way to separate them.
      The symptom is that the image is not visible, but the backlight works. How to know if the problem is in the main or in the tcon-panel? I can't override zones.
      05-14-2024, 02:11 PM
    • andrhouseolly
      Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
      by andrhouseolly
      Hi.
      I kindly ask you to help me solve the problem.
      Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
      The board turns on, there is no image.
      Read more. When the power supply is connected, the front panel indicators light up briefly.
      When you press the power button, the button indicator lights up. The board works
      there is no image, there is no matrix initialization, there is no image on HDMI.
      When turned on, the fans do not spin, but when they warm up they start spinning.
      When you turn off the button, the fans spin up to full speed for a short...
      05-11-2024, 03:14 PM
    • frannyjunk
      Hisense 40H4F no backlight but turns off after splash screen
      by frannyjunk
      So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
      TIA.
      Today, 10:59 AM
    • pseudorc
      Philips 43PUS8550 no image, backlight working
      by pseudorc
      Checking voltages at TCON
      Vin 12 V ok BUT ALL OTHER VOLTAGES 0
      VGL1 0
      VDD
      vcc19
      VGH 0
      when connection to Left half screen cable disconnected - then other half becomes white and voltages shows down below
      VGH 27.96
      VCC19 1.89
      HVDD 8.31
      VGL1 5V
      VGL2 3.8
      TCON board has been replaced with similar (bought from Ebay)
      Is this LCD panel issue ? the parts showing parts no is lg 6870s-2704d
      Many thanks...
      09-02-2024, 03:08 PM
    • Salem Aboshala
      820-00138-A got image but no backlight
      by Salem Aboshala
      Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
      I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
      History: my laptop backlight stopped working without any reason.
      Symptoms:
      I have image on screen using my flashlight.
      I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
      Keyboard backlight still working and can be adjusted normally.
      Since two days I tried to follow all similar...
      06-11-2024, 03:02 PM
