Philips 50PUS6272/05 image flipped and upside down
  • rash.m2k
    • Apr 2010
    • 64
    Seems this tv works all fine but the image is mirrored and also upside down, other than that seems to work all fine.
    Is this a bad tcon or mainboard?
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Philips 50PUS6272/05 image flipped and upside down
    have you fitted a new mainboard ? as this could cause it there maybe a way in the service menu etc too flip the image i think the menu is 062596 but dont alter anything yet as not sure there is a flip optionched this
    have you watched this? https://www.youtube.com/watch?v=UGz126wYCO4
    • rash.m2k
      • Apr 2010
      • 64
      Nope this is the original board, i have seen that video but there is no option in the menu
      • vinceroger69
        • Mar 2012
        • 6714
        can you upload pictures of your service menu screens
        • rash.m2k
          • Apr 2010
          • 64
          See attached, can't find anything about flipping the image
          • chrismurphy
            • May 2014
            • 251
            • australia
            reload firmware or go to service menu and select correct model screen
            • rash.m2k
              • Apr 2010
              • 64
              I have updated the software the screen selected is the correct one, I haven't changed the board it matches the screen
              • arge45
                • Dec 2020
                • Inglaterra
                Hola!
                Guys, Im having the same problem. Philips sent me a file to do a forced upgrade but no success on that. The image is flipped and mirrored still.Can you please share the OP1 and OP2 values. Also, sharing your experience resolving this would be very appreciated.
                • zen
                  • 511
                  Hi all
                  Been here before myself
                  The N V M with red dot next to the L V D S lead has corrupted . It holds the display data .
                  Tried re entering screen code , which is a 3 digit number , normally printed onto label at back of TV .
                  In my case screen blanked & lost picture all together .
                  To recover , managed to pull data from a working set , then program up chip on fault TV .
                  Will check to see if i have files .
                  Post the display type & part number , cheers Xen
                  • zen
                    • 511
                    Have just attached a bin file for the N V M i mentioned.
                    It's for the exact display type in picture posted & should restore image .
                    • mjn2710
                      • Jan 2021
                      Hi! I am having the same issue with the flipped image and cannot solve. Is there something I should try to do with this file?
                      • zens electronics
                        • Jan 2021
                        • 31
                        If your TV uses same display and main board , program the chip i mentioned with bin file provided .
                        • Diah
                          • Feb 2013
                          • 6614
                          not every normal user will have knowledge and tools for this tips. the best easy downgrade or update the firmware... it will take a place at NVM
                          googling will find allot sources of firmware depending on chassis and model No, for example
                          • zens electronics
                            • Jan 2021
                            • 31
                            Yes, sorry , i didn't consider that .
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4543
                              • Italy - Milan
                              Hi, re enter option codes in service menu, you will find them on the back cover sticker.. bye.
                              • William1967
                                • Nov 2017
                                • 217
                                • Netherlands
                                Press 062598 menu followed by the setoption number you find on the rear cover. Wait for 30 seconds and remove the power cable for a short time, reconnect the power. All options must be correct now also the display option.
                                • zen
                                  • 511
                                  Hopefully the above will work .
                                  Unfortunately in my case ended up with a completely blank display , due to data corruption of N V M i mentioned , which is why i needed to reprogram chip using good data from a working set .
                                  • William1967
                                    • Nov 2017
                                    • 217
                                    • Netherlands
                                    The way I explained works without a working display. The tv has a lot of pre programmed options onboard, you only need to program it with the so called OPTION CODE.
                                    • porfyriadhs
                                      Samsung ue46f6670 flipped image
                                      by porfyriadhs
                                      hello i changed the mainboard with another one but the image is flipped . i try to enter service menu, but there is no hv flip option . Can someone help please i tried everything...
                                      08-26-2025, 04:58 AM
                                    • alro7779
                                      Philips 32PFL4901/F8 BA5DFGG0201 1 Backlight is present but no image
                                      by alro7779
                                      Hello there!
                                      Have this Philips with no image at all. When I plug it to the outlet, it turns on without pressing the power button, and after a moment, it turns off, then starts again. I checked the 12v and 3.3v voltages on the main board connector that goes to the T-con, but it only has the former (12v). Any clues, guys?...
                                      08-07-2025, 11:53 AM
                                    • tuner2000i
                                      Philips 65PUS8518/12 distorted image after main board replacement
                                      by tuner2000i
                                      hello everyone,
                                      I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                                      The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                                      07-15-2025, 01:15 PM
                                    • malekservis
                                      Philips 58PUS8536/12 Backlight ok, no image
                                      by malekservis
                                      the TV turns on fine, seems to be working, but shows no image outside of a thick white vertical line as it turns on that also disappears almost instantly, and then it's just backlight. I've tried unplugging either side, but still can't get an image. I suspect it's a panel issue, but thought i'd ask some smarter people to confirm. I haven't found any weird readings, but then again i'm just randomly poking around with a multimeter.
                                      Any information would be appreciated....
                                      08-07-2024, 07:48 AM
                                      HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                      This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                      09-12-2024, 02:20 PM
