UN55KS8000 T con or screen?
  • Gdog215
    • Mar 2018
    • 29
    • Usa
    Looking for opinions before I buy this tv.
    You live and you learn right?
    • 12096
    • U.S.
    Re: UN55KS8000 T con or screen?
    Could be tcon or bad connection, really hard to tell sometimes, boils down to getting it pretty cheap in case it's a type of panel problem that can't be fixed.
    • William1967
      • Nov 2017
      • 203
      • Netherlands
      This set has no t-con , the LVDS cables go directly to the display. Disconnecting one by one does not help either with this tv, that could only be done with the tv's with a t-con.
        • 12096
        • U.S.
        Could be bad tab bonds, check youtube for tab bond testing and repair, must be at least 100 videos on the subject.
          • 12096
          • U.S.
          Thinking 75 bucks would be a maximum, then if it's not fixable you might recoop by selling parts but 180 is way too much to gamble on.
            The LCD panel has integrated T-CON.
            The FRC is on the main board.
            • Gdog215
              • Mar 2018
              • 29
              • Usa
              They were asking $240 lol but could possibly get it lower. Looked like an easy fix but this time I'll pass.
                • 12096
                • U.S.
                Ok, your picture looked just like the one in this ebay ad: https://www.ebay.com/itm/FOR-PARTS-O...-/123738852757
                  Looks like Samsung has lots of unhappy customers, Samsung should have recalled all these sets.
                  https://us.community.samsung.com/t5/...ts/td-p/416621
                  • jason123
                    • Oct 2015
                    • 1056
                    Any idea what the problem ended up being with this one? I got a TV that looks exactly the same. Have you tried replacing the main board, or is this a bad panel?
                    • jason123
                      • Oct 2015
                      • 1056
                      Seems the fix is to replace resistors and ESD / TVS Diode pack
                      The video shows removal of the diodes.. I'd like to replace them (if I can see the darn things) and the IC is labeled 4263H and I can't seem to find that.. Any idea what this chip is?
                      https://www.youtube.com/watch?v=YyDcPpGNA-Q
                        • 12096
                        • U.S.
                        you have to remove the long metal piece to expose the boards, like in the video, those resistors and any diode packs are on the long thin panel driver boards.
                        • jason123
                          • Oct 2015
                          • 1056
                          They are.. I just don't know what to replace them with. The creator of this video simply took them off.. I would like to replace them
                            • 12096
                            • U.S.
                            ok, I thought you were wondering where they were, when I saw the picture of the mainboard there, lol.
                            • jason123
                              • Oct 2015
                              • 1056
                              No problem. The area has the flex cables, and using hot air, can cause more of a problem replacing them.. that's why I see they simply removed them. Let's hope there isn't any large transients on these circuits, and I'll go with replacing the bad resistors only. fingers crossed.
                                • 12096
                                • U.S.
                                1206 100 ohm, maybe get 4 or so, replace the resistors, if no joy might need to remove the diode packs, might only need to remove one diode pack maybe both, might both be ok.
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  They are 51 ohm resistors not 100, they are marked 51R0.
                                  The diode is ESD7004.
                                    • 12096
                                    • U.S.
                                    yes they are, the people replacing them were using the 1206 100 with success, that's what I would use but op can use whatever he wants of course.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4287
                                      • Italy - Milan
                                      Diodes: uClamp6514P (UCLAMP6514P.TNT) or alternative uClamp4014P (UCLAMP4014P.TNT) by Semtech
                                      • jason123
                                        • Oct 2015
                                        • 1056
                                        Thank you.. On order
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • alltvrepairs
                                          Lg TCon test pins for screen test
                                          by alltvrepairs
                                          i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                                          Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                                          Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                                          Appreciate your help....
                                          06-13-2025, 06:33 AM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
