Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
Hey, yes exactly the same issue. The tech was referring it as a panel issue. Fix was $400. Issue in the address board/chips attached to panel is what my tech told me.Hello Jingasharo, I realize you have been kind enough to respond to my inquiry but I wanted to ask another question. Did your TV repair have same two black lines as my tv and other OP? Second question is can you give a range for repair $$? Reason for asking is pretty good TV repair guy told me it's 90% a defective display panel. I've seen over 20 of these same TV's online in the States with same exact issue. I'm guessing this is a complex repair as this TV guy wanted nothing to do with it. Regardless thank you to all of you who took the time to respond. I will absolutely share. All the best!Last edited by jingasharo; 12-16-2023, 01:20 AM.Comment
Thank you Jingasharo for returning the answers to my questions. It was unnecessary for anyone to imply you are not trying to be helpful. You took the time to try to be as helpful as you could and for that I can only be appreciative. I wish you well in future projects. Be well.Comment
by x_orange90_xJust bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by iglitareHi,
Or is it always a bad/shorted... -
by thelankanguyThe TV shows a black screen with no image.
TCON ribbon connectors were disconnected individually for image and there was no half image even.
Later both ribbons were disconnected and TCON voltages were tested.
12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
There is also a short to ground in this circled inductor.
Is this a TCON issue or something else ?... -
by stav242I was asked to look at a Sony KD-55X8509C as it was not powering on, no lights.
On inspection, there was no physical issues.
I seated all cables and repowered the TV, then the LED light flashed Green / Amber.
- this seems to indicate repairing required, done by Firmware update.
so downloaded the latest Firmware from Sony website and wrote to 4Gb USB drive.
Inserted the drive and repowered the TV.
LED changed to white flashing/pulsing ... and it sat there for over an hour.
i was unsure what was happening so repowered the TV and now it just... - Loading...
