Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
  • Daren87
    • Aug 2023
    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the replacement and tested these same caps on the underside of the board and I'm finding these same caps are also shorting to ground on both sides.
    Help me understand… is this not a problem? Is this replacement also bad? (From eBay) is there a case where caps are supposed to have both sides with continuity to ground? I tested these before installing the replacement board.
    After installing the replacement the TV gave me a 5 blink code again. After this it now just alternates white and red blinks. Screen doesn't turn on anymore. Also wondering if this other board needs to be firmware updated along with the rest of the TV?
    I know the screen could be bad and ruin any new Tcon that's installed but I'm also wondering if I got a bad Tcon from eBay with shorted caps?
    Looking for some clarity/direction here. Any thoughts are greatly appreciated!
  • videotronics
    • May 2013
    • 22
    Re: Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
    Hello Daren, a low pass filter could have inductor coils to ground on both sides, can you locate a schematic for the board? I am learning to diagnose t-cons, will you tell me what voltages and waveforms to expect on the inputs and outputs of the board?
    • jingasharo
      • Dec 2023
      • 8
      Hi. Did you find the solution? My Z8H 75" got the exact same issue today. I was playing and suddenly white screen. I must tell you that after the most recent update, maybe about 1-3 months ago, the TV started behaving weirdly. It was very slow on loading the menu and apps and generally overall slow while switching in between menus. and today this happens..I found this 1 person with a similar issue https://www.reddit.com/r/TVRepair/co...on_left_snowy/
      Edit: now the tv blinks 5 red lights and no screen.
      • EazyBone
        • Jun 2023
        • 1351
        • United states
        Start new thread, give pictures. Can you use multimeter and take back off? Is there vertical lines on yours also or just fully white. Blink code?
        • jingasharo
          • Dec 2023
          • 8
          Hi, I can use a multimeter but i have someone whos repairs TVs, I'll bring it in and get it checked. And yes I have exactly the same screen as the pics uploaded by OP.
          • EazyBone
            • Jun 2023
            • 1351
            • United states
            Very interesting that it's exactly the same wow. Sounds good
            • jingasharo
              • Dec 2023
              • 8
              Got the tv back and its fixed.
              • EazyBone
                • Jun 2023
                • 1351
                • United states
                So what was the solution?
                • Benbuke21
                  • Dec 2023
                  • 9
                  Hello, I’m new to this forum. I literally had the exact same experience this week with my 2020 Sony Z8H 75 inch TV. I mean exact same screen as prior posts here. Mine went from showing the screen with the two black bars to the no screen with 5 red blinking lights. If I’ve broken forum rules by posting my apologies but would be super interested if Jingasharo feels comfortable sharing what the fix is? Thanks
                  • EazyBone
                    • Jun 2023
                    • 1351
                    • United states
                    Your fine, it was probably the TCON board since 5 blink indicates that generally. But let's see if he answers
                    • Benbuke21
                      • Dec 2023
                      • 9
                      • Benbuke21
                        • Dec 2023
                        • 9
                        Thank you for your feedback EazyBone! Have a wonderful Holiday!
                        • jingasharo
                          • Dec 2023
                          • 8
                          Hi Guys, It was issue with the "address board". Look at the first pic uploaded by OP. You'll see the 2 chips on at the bottom which are part of the panel, to which the ribbon cable and tcon board are attached to. I think thats where the issue is. Other than that, Rest of the boards on the TV were completely fine, including the Tcon Board. Click image for larger version
Name:	Screenshot at Dec 13 16-50-41.png
                          • Benbuke21
                            • Dec 2023
                            • 9
                            Thank you so much for getting back regarding your issue! I really appreciate it. I have read the address boards are attached to the panel so I’m assuming entire panel replacement or replace defective chips? Thank you again for following up with photo, very helpful. Have a terrific holiday and be well.
                            • jingasharo
                              • Dec 2023
                              • 8
                              yes only fix the addres board. Fix the components on it. the panel does not need to be replaced. that would be almost the price of the tv LOL.
                              • EazyBone
                                • Jun 2023
                                • 1351
                                • United states
                                Appreciate feedback, but just saying components need to be replaced isn't extremely helpful. Can you find out what. Needed addressing?
                                • jingasharo
                                  • Dec 2023
                                  • 8
                                  I have pointed to the right component. A good tech should be able to figure out the rest.
                                  • Benbuke21
                                    • Dec 2023
                                    • 9
                                    Thank you Jingasharo for your reply. Appreciate your photo as this is the closest I’ve come to locating the issue. Thanks again and be well. I will follow up if I learn anything with more specificity.
                                    • nomoresonys
                                      • 12220
                                      • U.S.
                                      So post clear focused pictures of the address boards, if a person can't post a good picture then it's not likely they can fix electronics.
                                      • Benbuke21
                                        • Dec 2023
                                        • 9
                                        Hello Jingasharo, I realize you have been kind enough to respond to my inquiry but I wanted to ask another question. Did your TV repair have same two black lines as my tv and other OP? Second question is can you give a range for repair $$? Reason for asking is pretty good TV repair guy told me it’s 90% a defective display panel. I’ve seen over 20 of these same TV’s online in the States with same exact issue. I’m guessing this is a complex repair as this TV guy wanted nothing to do with it. Regardless thank you to all of you who took the time to respond. I will absolutely share. All the best!
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • iglitare
                                          Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                          by iglitare
                                          i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                          Backlight seems to work, Sound (Setup menu after reset) works.
                                          If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                          Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                          With my small knowledge i would think at least the cables are good.
                                          Can this happen because of a bad tcon board?
                                          Or is it always a bad/shorted...
                                          09-04-2025, 07:13 AM
                                        • thelankanguy
                                          Sony KD-55X9000F TCON Issue
                                          by thelankanguy
                                          The TV shows a black screen with no image.
                                          TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                          Later both ribbons were disconnected and TCON voltages were tested.
                                          12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                          There is also a short to ground in this circled inductor.
                                          Is this a TCON issue or something else ?...
                                          12-13-2024, 12:27 AM
                                        • stav242
                                          Sony KD-55X8509C white flashing/pulsing LED
                                          by stav242
                                          I was asked to look at a Sony KD-55X8509C as it was not powering on, no lights.
                                          On inspection, there was no physical issues.
                                          I seated all cables and repowered the TV, then the LED light flashed Green / Amber.
                                          - this seems to indicate repairing required, done by Firmware update.
                                          so downloaded the latest Firmware from Sony website and wrote to 4Gb USB drive.
                                          Inserted the drive and repowered the TV.
                                          LED changed to white flashing/pulsing ... and it sat there for over an hour.
                                          i was unsure what was happening so repowered the TV and now it just...
                                          01-08-2024, 07:39 AM
