LG 65uf7690-uh picture problems
  • nwelec
    • 61
    • usa
    When both sides of the Tcon are connected the TV picture looks like picture one and according to the person who owns the tv originally the problem was on top. If I disconnect the left cable to the Tcon then it looks like picture two and if I disconnect right side it looks like picture three. Now with either side disconnected the picture that is showing will start to fade. I am pretty sure bad panel but I have not ruled out the Tcon and am asking for advice. There are no side tabs so tab removal is out of the question.
    Re: LG 65uf7690-uh picture problems
    Panel problem, since the tab bonding boards are on the bottom edge of the panel, you should inspect them, also inspect the side tabs (Gate drive) if it has any.
      • 12206
      • U.S.
      Looking like panel issue, the cutoff tape method might get you a good image.
      • nwelec
        • 61
        • usa
        Thanks for the quick replies, sorry I did not answer earlier I never got a notification that it was answered.
        • Wilderone
          • May 2018
          • 76
          This is the Mainboard, I did one recently.
          Common fault for the UF series.
          Notice the menus are still okay.
          There are revised boards available from LG suppliers.
          • nwelec
            • 61
            • usa
            The difference is my menu is not ok so that usually is the panel.
            • budwich
              • Jul 2015
              • 3097
              as suggested, try the "tape cutoff" method (placing a bit of tape on the tcon cable to block certain pins) and see if you can get a proper picture.
              • vinceroger69
                • Mar 2012
                • 6714
                This video maybe worth watching https://www.youtube.com/watch?v=j7vl7-vZEL8
                • nwelec
                  • 61
                  • usa
                  Thanks for the response but still does not fix the tv issue. No mater where I put the tape the video still has lines in it.
                    • 12206
                    • U.S.
                    Cut tape works on a lot of m, try turning down your backlights not brightness if possible, see if the double image clears up any.
                    • nwelec
                      • 61
                      • usa
                      After playing with the panel I found that the right side connector if pushed on clears up the picture so I am going to play with it to see if maybe it is just some bad solder.
                      • Fly_Among_Stars
                        VIZIO E70-E3 Half picture with half TCON
                        by Fly_Among_Stars
                        I have a VIZIO E70-E3.
                        Symptoms: Black screen, no picture, but LED backlights are working.
                        I probed the power board and voltages are as listed on the board.
                        Main board appears fine, too.
                        I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                        There are two separate ribbon cables feeding the LCD.
                        If both are connected, the screen is black.
                        If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                        04-24-2023, 08:20 PM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • shelby5041
                        Samsung LCD TV no picture backlight on no 12v at tcon
                        by shelby5041
                        hi
                        i have a samsung lcd tv
                        it powers on with sound and backlight but no picture
                        all voltages from PS are good 12v 3.3v and 5v
                        whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                        i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                        no 12v at the tcon fuse
                        i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                        the odds of having 2...
                        10-08-2021, 08:21 AM
                      • halen
                        Hisense H55U7B vertical stripes
                        by halen
                        I have Hisense H55U7B TV with no picture, only big vertical stripes. I did several tests and I'm not sure, where is problem.
                        1. Connected tcon to 12V, white, red, green, blue, black picture visible in cycle on full LCD without error
                        2. Connected only left side of LCD to tcon, big stripes
                        3. Connected only right side of tcon, visible normal picture on the right. Working as expected.
                        Where could be problem?
                        Tcon RSAG7.820.7932/ROH
                        Main board RSAG7.820.8698/ROH
                        Jan
                        06-18-2025, 03:58 AM
                      • Vahalaru
                        Visio E600i-B3 will not power on.
                        by Vahalaru
                        [B]Background[/B]
                        I recently fixed our Samsung black screen of death by watching YouTube videos and reading through previous threads. Removed a few ceramic capacitors and fixed a short on the back side of the tcon board. So my father and law asked me if I could try to fix his visio. He said that it wouldn't power on. When he first brought it to me I plugged it in and there was a standby light. When I hit the power button the TV booted up and everything worked. I hit the power button again and then I saw what he ment. Since then I have not been able to get it to power on or have a standby...
                        08-24-2021, 07:23 PM
