Samsung LCD TV no picture backlight on no 12v at tcon
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    hi
    i have a samsung lcd tv
    it powers on with sound and backlight but no picture
    all voltages from PS are good 12v 3.3v and 5v
    whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
    i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
    no 12v at the tcon fuse
    i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
    the odds of having 2 main boards with exact same problem is rare but could happen
    could this actually be a bad tcon board? ..maybe is shorted out and not allowing main board to send the 12v?..or is this not a possibility.
    thank you
  • shelby5041
    • Feb 2009
    • 1505
    Re: Samsung LCD TV no picture backlight on no 12v at tcon
    i think issue may actually be tcon...if i remove the tcon cable from the main board i now have the 12v at main board check point....so maybe tcon is shorted out which causes to lose 12v at main board to tcon?
    • shelby5041
      • Feb 2009
      • 1505
      It was faulty tcon causing main board to shut 12v off
      Replaced tcon ..$8...now works great
      • Asraf Atb
        by Asraf Atb
        01-27-2025, 05:02 PM
      • mrautom8
        Samsung TV UN75H6350AFXZC main board schematics?
        by mrautom8
        Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
        Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
        While relay is on, all voltage rails are present and steady (scoped) on main board.
        I love a good logic puzzle but getting lost without any schematics.
        No shorts on ANY capacitor main board.
        Thermal camera shows 3.3V inductor getting warm instantly but...
        10-19-2025, 06:32 PM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • Lee M.
        Samsung UN75RU8000FXZA bad main board?
        by Lee M.
        When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
        11-08-2023, 07:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
