Ue65f9000
+ More Options
Posts
  • gazza544
    • Nov 2013
    • 19
    • United Kingdom
    Ue65f9000
    Hello, I wonder if anyone could shed some light in the repair to the mainboard for this tv please, the mainboard is a bn41-01950c and also has a one connect box, after the apps logo is displayed the tv becomes unresponsive and the red led flashes in the bottom right hand corner of the tv, it then starts again and does the same, if it is this board at fault then does anyone know what the fault is with it
    As I can't find a replacement in the uk.
    Thank you.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Ue65f9000
    Maybe eeprom. You could try spraying freeze spray on it and see if it comes on. Is a one connect box a tuner? If so try disconnecting it and see if it comes on.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Re: Ue65f9000
      Have you read through Nick's posts on the "One Connect" problem sets
      https://www.badcaps.net/forum/showth...=one%2Aconnect
      • gazza544
        • Nov 2013
        • 19
        • United Kingdom
        Re: Ue65f9000
        Hi thank you, yes I have read it and is a confirmed main board however I can't find a replacement for less than £400, I could probably repair the mainboard if I knew why it was doing it, but haven't' got much on it to be fair.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Re: Ue65f9000
          It may be more cost effective to keep an eye out for a smashed screen set.
          • CDRW
            • Aug 2017
            • 5
            • Ukraine
            Re: Ue65f9000
            I had such a problem, rebooting in a circle. the problem was solved by re-rolling nand flash on the programmer. 15 minutes of work.
            • Unspun01
              • Jun 2011
              • 349
              Re: Ue65f9000
              What do you mean "re-rolling"? I'm not familiar with this term.
              And which specific eeprom chip are you re-flashing? There are a few eeprom chips I think. Can you list the PCB IC number?
              • OCBSlimz
                • Nov 2017
                • 16
                • France
                Re: Ue65f9000
                Unspun did you find a solution for this ?
                • Unspun01
                  • Jun 2011
                  • 349
                  Re: Ue65f9000
                  Hi OCBSlimz:
                  I have a different problem. My TV does not freeze, or lock up, or reboot. The problem with my TV (UN65F9000) is a white screen with yellow/cyan artifacts (with or without the One Connect device attached) and no functionality whatsoever.
                  See the link to the thread below:
                  https://www.badcaps.net/forum/showthread.php?t=63109
                  The solution is Mainboard replacement or repair (specific part number is BN94-06654B. Board markings are BN41-01950C, BN97-07631A. Your numbers may be different).
                  I am still trying to resolve the issue for my problem as of today's date. However, if your TV has a problem with freezing, or lock ups, or reboots, then your solution is also Mainboard replacement or repair, but you may be able to reprogram a new Nand flash or EEPROM chip as indicated by CDRW in his earlier post.
                  CDRW: Can you please let us know which specific IC you replaced or reprogrammed?
                  • WOLVERINE69
                    • Aug 2018
                    • CANADA
                    Re: Ue65f9000
                    Originally posted by Unspun01
                    Hi OCBSlimz:
                    Hi were u able to repair or had to replace the main board?
                    • Unspun01
                      • Jun 2011
                      • 349
                      Re: Ue65f9000
                      I successfully repaired my UN65F9000 TV with working mainboard replacement (TV was stuck on was white screen with cyan/yellow artifacts)
                      I plan to repair the old board when I can. I strongly suspect embedded eMMC memory IC1801 as highlighted in the image I attached below. eMMC = "embedded Multi-Media Controller" with flash memory and a flash memory controller integrated on the same silicon die.
                      IC1801 may be corrupted from a bad update? or like other garbage EEPROM designs, maybe deteriorated internally which is causing the inability to read or write program contents.
                      If I can read the contents of the eMMC chip from my working board, and re-program to a new chip for my faulty board, I think I can repair it... But I have no idea how to read/re-program the IC.
                      • magneh
                        • Apr 2014
                        • 607
                        • Portugal
                        Re: Ue65f9000
                        Hello all!
                        I have a ue65f9000 that turns off by itself after a few minutes.
                        I can browse sources, go to the menu, all eco options off, and TV still turns off by itself.
                        It turns on right away if I press the power button.
                        Does this indicates a Mainboard issue?
                        Has anyone faced similar problem?
                        Thanks for any inputs!
                        • KYBOSH
                          Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                          by KYBOSH
                          I picked this one up today.
                          Previous owner says no signs of life.
                          TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                          Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                          The TV model is QN65LS03BAFXZA - version: CB06
                          The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                          I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                          Will keep you all...
                          04-05-2025, 08:32 PM
                        • Mirenia
                          Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                          by Mirenia
                          I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                          I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                          In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                          The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                          03-30-2025, 06:47 AM
                        • vinceroger69
                          sharp lc-49cug8052k
                          by vinceroger69
                          Hi guys anyone have a link for the latest software update for sharp lc-49cug8052k i have tried updating it in the tv menu says upto date but its from 2018 issue apps etc freeze and apps slow to respond freeview and same apps played through firestick/hdmi playback all work ok
                          Edit have now done a factory reset tv still doing the same thing on apps the app freezes then after a while tv reboots and goes back too normal freeview tv channel. so guess it is a mainboard fault as davi.p suggested.
                          10-16-2024, 05:45 AM
                        • howardc64
                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                          by howardc64
                          • Prior owner tried a replacement main board. No difference.
                          • Samsung 2x red blinking standby LED = panel fault
                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                          07-19-2025, 10:54 PM
                        • Devonavar
                          Vizio M43-C1 - How closely do I need to match the mainboard number?
                          by Devonavar
                          I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
                          I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
                          Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
                          So, I've ruled out the PSU for now.
                          The reboot loop...
                          08-14-2022, 08:46 PM
